Analog Presta gauge
Analog Presta gauge
Old 03-16-24, 07:26 AM
Weogo
Bikes: 2022 HudSki Doggler
Quoted: 17 Post(s)
Liked 14 Times in 8 Posts
Analog Presta gauge
Hi Folks,
My wife has a lovely old Presta gauge from Zefal:
no battery presta gauge
It holds a reading till you push a button and release it.
The range is fine for her road bike.
It's fairly compact and light, no battery needed.
Does anybody know of something similar, with a maximum of around 30~40PSI, 2~3Bar?
I have an accurate gauge at home. All I need is a reasonably CONSISTENT gauge when out riding.
Thanks and good health, Weogo
Weogo is offline
Old 03-16-24, 10:25 AM
Rick
Quoted: 626 Post(s)
Liked 400 Times in 276 Posts
Jaco makes some presta gauges that also glow in the dark. They are probably not as light but they are accurate and don't leak air like the presta/schrader digital ones. This one looks smaller. It looks like they come in 30psi, 60psi, and 160psi. I have a 60psi Accu-Gage
Rick is offline
Likes For Rick:
Old 03-16-24, 12:12 PM
skidder
Pennylane Splitter
Bikes: Yes
Quoted: 1804 Post(s)
Liked 1,445 Times in 994 Posts
Try an auto parts store. Some auto tires go up into the 40 psi range (hybrid auto tires), and I think the gauges go higher (maybe 60psi?) I just estimate with a "2-finger squeeze" if out on the road and deal with more exacting pressure when I get home.
EDIT: You'll need an adapter if you have presta valves and buy an automotive gauge.
skidder is offline
Old 03-16-24, 12:26 PM
One Wheel
Quoted: 117 Post(s)
Liked 52 Times in 40 Posts
I have a couple like this, mine have max 60 and max 160 psi. I'm pretty happy with them.
https://miltonindustries.com/product...SABEgI7jfD_BwE
One Wheel is offline
Old 03-16-24, 01:29 PM
Weogo
Quoted: 17 Post(s)
Hi Folks,
The Zefal really is quite small, and weighs less than one ounce.
Am looking for something similar size/weight.
I've though of trying a plastic 'pencil' style schrader gauge with a Presta adapter; not sure how good a seal the adapter would have...
Anybody ever seen a presta pencil gauge?
I definitely know the 'two-finger squeeze' and may just continue relying on this.
For the poor and gravel roads around here am running 2.25" / 57mm tires on 40mm wide rims at less than 30PSI, so 25~30PSI feels about the same.
Weogo is offline
Old 03-16-24, 01:48 PM
Koyote
Quoted: 6972 Post(s)
Liked 10,971 Times in 4,692 Posts
Here you go.
Koyote is online now
Likes For Koyote:
Old 03-16-24, 01:55 PM
One Wheel
Quoted: 117 Post(s)
Originally Posted by Koyote
Here you go.
That's the gauge that I have, plus a rubber collar. My 160 psi gauge weighs 3.0 oz/ 84 grams, the 60 psi gauge has a larger dial and weighs 4.6 oz/ 129 grams. They're nice tools, but definitely more along the lines of something I would keep at home rather than carry on a ride.
Old 03-16-24, 02:07 PM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4739 Post(s)
Liked 1,533 Times in 1,004 Posts
These list for about $2
Sy Reene is offline
Old 03-16-24, 02:52 PM
RCMoeur
Cantilever believer
RCMoeur's Avatar
Quoted: 536 Post(s)
Liked 1,842 Times in 834 Posts
My experience with Schrader press-on gauges and Presta valves using adapters hasn't been great, as many adapter / gauge combinations won't depress the Presta center stem to get a reading. Pumping isn't an issue, as Presta valves are designed to easily open to allow higher-pressure air to enter, but it doesn't equate to having access to the air in that tube to measure it once the pump chuck is off.
I have the same Zefal Presta gauge as depicted above. It seems to work OK. I also have a Slime brand Presta-head electronic gauge similar to the Schrader e-gauges, but it stopped working a while ago.
RCMoeur is offline
Old 03-16-24, 03:18 PM
Koyote
Oh, I’m sorry—I missed the part where he stated that he wants a gauge to take along when riding.
Old 03-16-24, 03:23 PM
One Wheel
Quoted: 117 Post(s)
Oh, I’m sorry—I missed the part where you stated that you want a gauge to take along when riding.
I'm assuming based on the statement in #5 that the gauge he's looking to replace is very lightweight that OP is looking for something to carry on a ride.
Likes For One Wheel:
Old 03-16-24, 06:48 PM
Rick
Quoted: 626 Post(s)
Topeak SMARTGAUGE D2X is only 56 g / 1.98 oz​​​​​​​.
Rick is offline
Old 03-16-24, 07:46 PM
Koyote
Originally Posted by Rick
Topeak SMARTGAUGE D2X is only 56 g / 1.98 oz.
I’ve had this gauge for about six weeks. It just quit working today.
Old 03-16-24, 08:02 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3590 Post(s)
Liked 3,401 Times in 1,935 Posts
Still using my Kingsbridge gauge from the 70s:
JohnDThompson is online now
Likes For JohnDThompson:
Old 03-16-24, 08:58 PM
ofajen
Cheerfully low end
ofajen's Avatar
Quoted: 646 Post(s)
Liked 1,044 Times in 667 Posts
I have one that looks pretty similar except for the dial color. It’s a Meiser Accu-Gauge. I’d still use it but the rubber lining wore out and won’t seal well. I have a new Accu-Gauge that works great. They have Presta models that go up to 15, 30, 60 and 160psi, depending on the range you need. Owned by Milton Industries in Chicago.
Otto
ofajen is offline
Old 03-16-24, 09:09 PM
Rick
Quoted: 626 Post(s)
I’ve had this gauge for about six weeks. It just quit working today.​​​​​​​
​​​​​​​Send it back for a refund if possible.
Rick is offline
Old 03-16-24, 09:19 PM
Troul
Troul's Avatar
Liked 2,979 Times in 1,920 Posts
in order to get one accurate & small enough in comparison, you'll need to grab a schrader valve gage setup that you can remove the end on to screw on the presta end. It'll likely require an adaptor/union fitting to interface the two.
-Oh Hey!
Troul is offline
Old 03-16-24, 09:37 PM
Rick
Quoted: 626 Post(s)
Lezyne DIGITAL CHECK DRIVE
Rick is offline
Old 03-18-24, 05:46 AM
noimagination
Quoted: 365 Post(s)
Liked 419 Times in 248 Posts
Sorry, but why in the world would you need a pressure gauge out on the road? Even in my basement, the gauge on my pump is only there to let me know when I'm close. Pump and pinch, adjust inflation if necessary.
At the worst, pump and sit on the bike and look at the tire contact patch. At the very, very worst, pump and ride a little, too squishy add more air, too rough let a little out. You'll be fine.
noimagination is offline
Old 03-18-24, 06:56 AM
Garthr
Bikes: Franklin Frames Custom, Rivendell Bombadil
Quoted: 117 Post(s)
Liked 209 Times in 127 Posts
I have one like this that was the first tire gauge I ever owned. From the 70's. Not my listing, and I had a hard time find any images for it ! https://www.ebay.com/itm/256227798764?chn=ps&srsltid=
Garthr is offline
Old 03-18-24, 08:40 AM
Weogo
Quoted: 17 Post(s)
Hi Noimagination,
I've been wrenching for about sixty years and have a pretty good feel for 'tight enough'.
And I own three torque wrenches for when they are useful.
I want to see how small differences at fairly low pressures affect riding.
Garthr, a gauge like that, with a low range, would definitely fit the bill!
Weogo is offline
Likes For Weogo:
