View Poll Results: Lights & Reflectors: How much is enough?
Reflectors only (yikes!)
1
0.40%
Rear light only
2
0.80%
Front & rear blinking lights
26
10.36%
Front headlamps and rear blinker
85
33.86%
Multiple headlamps and taillights
56
22.31%
All of the above
25
9.96%
All of the above and more
56
22.31%
Voters: 251. You may not vote on this poll
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
Most cyclest have very modest gear to help them be seen at night. Do you have;
Rear light only
Multiple headlamps or taillights
All of the above
Rear light only
All of the above
Uke-I don't understand why you would remove both reflectors.
I have added reflective tape all over my bike. I run a crap-ass but sufficient to be seen, 3LED front light.
I am actually ordering a P7 today to use up front.
In the back, I have two PB superflashes, and a PB bilkie7, along with a reflector, and reflective tape.
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
Oops, I said "multiple headlights and taillights" but realized I meant "all of the above." I think reflectors, when they work, are the best; a 2 inch strip of 3M high intensity in the beam of a headlight will kick back more light than all but the most insane of active lights, and have the advantage of being physically larger than a light. But active lighting is necessary too. On the back I insist on multiple lights since I wouldn't know if one went out; I've gotten to work and found my battery dead before, and that makes me nervous. I run one steady, one blinking. On the front I only run one light at a time, but I have another mounted as backup. Since I'll know immediately if one dies, I can just flip the other one on.
Work: the 8 hours that separates bike rides.
Bikes: 2007 Giant Cypress DX, Windsor Tourist 2011
Quoted: 24 Post(s)
Reflective tape on your 'diamond', rear blinky, front headlight, pedal reflectors and either clothing with reflective tape, or a reflective vest. That's what I recommend for night time riding.
My way of thinking is as follows: You already have the lights. So why NOT have the reflectors? Why would you possibly limit your visibility? What if a light breaks? Or batteries die because you needed to go on an unexpected longer trip?
What if reflectors only increases your visibility by 1%? You want to lose that 1% for what gain?
I'm not criticizing your choice to remove the reflectors. I'm just trying to grasp why someone would go through the effort to make a bike visible, but remove the extra visibility material that was already supplied with the bike.
it's easy if you let it.
^ Because I find the gains from the lights supersede the gains from the reflectors by such a degree that the losses from the reflectors (weight, stability, bar space) outweigh benefits of keeping them on the bike.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
Depends on the specific bike but typically...head light with standlight or auxiliary LED marker, rear steady on taillight and PB Superflash. Plus whatever reflectors came on the bike. I also typically wear an ANSI Class 2 reflective vest or jacket. Somewhere along the way you are going to hit the point of diminishing returns or get run over by someone that is so distracted they wouldn't notice a nuclear explosion if it occurred in the lane next to them.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Depending on what bike I use and it's intended purpose determines how much lighting and reflectivity I want to do to it. My winter commuter definitely fits the "all the above and more" catagory whereas my one summertime road bike is stripped bare for use on sunny day excursions and fits the "reflectors only" catagory only because it came with reflective decorative tape on it's wheels.
Prisoner No. 979
Prisoner No. 979
Sophomoric Member
Some folks get a little overexcited by lights, IMO. I have one LED headlight in front and 2 PBSFs on the rear. I have a little reflective tape on my bacpack. Enough already!
"Think Outside the Cage"
Bike ≠ Car ≠ Ped.
Nothing wrong with reflectors at all, IMO, but from that kind of angle, I don't think anything makes much of a difference.
If I were to live with a minimum of visibility, it would be a headlight, even in the daytime. There are more risks where I'm going than where I've been. But, I run with at least a headlight and taillight, and just live with whatever reflectors came on the bike. I might add some reflective tape to cranks and wheel rims, though, with the intent of being more visible from the rear.
The Thing Itself
I have a front headlight (Fenix L2D) that can be either flashing or steady, which I set to one or the other depending on lighting and one or two SuperFlashes on back, again depending on lighting. I removed the reflectors on the bike too, but I wear reflective anklebands after sunset (largely to comply with the law).
Why remove the reflectors? Well, the front and rear because they were right where I was going to put my front and rear lights, and cause I know that they're useless unless something's shining on them. I figure that so long as my lights are working, they're doing a better job than the reflectors ever could, and I carry both extra lights and extra batteries, just in case (or for when it's really inky black).
The removal of the spoke reflectors is much harder to justify. I admit it. I just wanted my bike to look cleaner. I do, however, doubt the effectiveness of them in the first place, as they're only lit when (a) someone's shining a light on them to begin with, and (2) when that person is shining the light on my side. That means that they're really only working at night when I'm passing someone with headlights on a road perpendicular to the one that I'm on. If that's the case, they should have already seen my headlight (usually flashing) and they should still be able to see my ankle reflectors.
In other words, I'm somewhere between two of the options presented.
Liked 6 Times
1) I head west down 2nd Ave. on my way home. It takes some jogs to go around a supermarket while simultaneously morphing from a WOL to a NOL. Overtaking traffic and traffic coming in from my right at the first jog both get a partial side view. Given that the road narrows, they need to merge left instead of staying in my lane.
2) when I'm stopped in an intersection waiting for an opportunity to turn left, it's good to be visible from the side. With reflective sidewalls, I can also prop my front wheel sideways so oncoming traffic can see it. My reflective vest and jacket also contribute. In this situation, my eGear Guardians on my fork blades also provide a little active side visibility.
3) when I turn onto Highway 195, a 4-lane divided highway, side visibility helps me show up to oncoming traffic from both sides. Since I often have to stop in the median before crossing the second half of the highway, I'm a sitting duck when people coming down the second half of the highway dive into the turn lane to turn across the median. Side reflectivity and active lighting are both possible defenses (turn bars and helmet light towards the traffic).
4) when I turn off of Highway 195 onto Hatch Road, side visibility helps me show to the oncoming traffic coming down 195, some of which will also turn onto Hatch Road. Given that the first 1/2 mile of Hatch has bottlenecks, it's helpful for them to know in advance that there's a cyclist just ahead of them somewhere. Those reflective sidewalls, rim tape and fenders that went swooping across their path are hard to mistake for anything else. Also, the people trying to turn left from Hatch onto 195 are about 70 feet to my left when they launch, far enough for side reflectivity to help them see me before they broadside me.
As a side note, a red rear reflector visible for 600 feet in low-beam headlights is a legal requirement in my state. My taillights might be far superior in many situations to my reflectors, but if someone hits me, I want to have everything I was legally required to have, in case it ends in court. I don't want to be paying hospital bills AND repairs to the front end of someone's BMW.
Anyway, my commuting bikes fit the "all of the above, and more" category. I could get by with less, but hey
don't forget X-mas tree lights. wrap that around your frame, over the reflective tape(has to cover entire frame, no need for paint). and don't forget refelctive bar tape, with red led bar ends.
is there a good way to light up the side. i feel ok front and back, but the side is lacking lights. i know plantebike has some week 3/5led amber lights, but that seems like a hassle carrying two of those around. i thought about ripping the parking lights off of my car(its illegal to drive with parking lights anytime of the day/night), but i'm wondering how do i set up a battery sorce. i wish i wasn't an electronics noob.
is it just me or does relfective tape seem more effective that reflectors themselves?
Riding 50 years
side visibility
My route crosses many short sidestreets, and nearly all my close-calls (even in daylight) have involved inattentive drivers crossing my path. Now that it's dark for the ride home, I've put little red valve-cap lights on my tires. Viewed from the side, they look like two circles of red. Following a suggestion here, I also put Christmas lights the length of my frame; looks goofy and fun, besides adding visibility.
Liked 6 Times
If you're curious why prismatic plastic reflectors have this problem, while prismatic reflective tape and enclosed-lens (glass-bead) reflective tape don't, read here.
Also, the typical bicycle reflector is a CPSC wide-angle reflector, where only the center portion reflects to the rear. And they're not very big to start with. If you just want maximum reflection to the direct rear (like when riding on a highway), then the DOT reflectors are better, because they're large and all of their reflector prisms are aimed to the rear.
For the moment, I have some active side visibility from the edges of my Seca 700's lens and my multiple taillights (which show from the side), and one of these zip-tied to each fork blade:
Señior Member
Quoted: 446 Post(s)
Liked 8 Times
Arguments for reflectors, IN ADDITION TO lights:
Reflectors work, ALWAYS. Their batteries do not go dead and their circuitry does not fail. They are visible from a much wider range of angles than almost any lights. They can describe a physically large area rather than coming from a single point, thus they can be more noticeable even if they are not really brighter. They can outline the shape of the bike and therefore let people know that it is a bicycle, which helps them to know how to deal with it - IE if they're coming from behind, the tell-tale motion of pedal reflectors or leg band reflectors says "bike" - and the driver can know that they're coming up FAST on a 15 MPH vehicle, rather than coming up much slower on a moped or motorcycle.
What is this demonry?!
Bikes: KHS Aero Comp.
Not me but if you cannot see this from the side...you are blind. If I saw a huge white spot in the road moving...I would assume something is behind it....Side visibility is nowhere as big of an issue as frontal and rear visibility.
EDIT: by the way these are the P7s, which I will be purchasing soon enough.
Liked 6 Times
In some conditions, that works. On snow, it's especially awesome. But try wet pavement, as the opposite extreme. We have some freshly-laid asphalt on my route, and it's like trying to illuminate a black hole even when it's dry.
No one sees anyone on wet, and besides I've got a car for rainy weather so in the end it's a non issue for me. I'd rather be comfortable on my commute by bike.
Liked 6 Times
Oh, I think they see me
I have a car too, but it doesn't fit into my pannier very well so if it rains on the way home, then I'll be riding in rain. And it takes a lot more than rain to keep me from commuting by bike. Torrential downpour with frequent lightning strikes... mmm... maybe I'll take the short route home.
The main point, at any rate, is that a headlight's bright spot on the pavement will not always look that way to people around you, so just be aware. You might still benefit from some additional side visibility enhancements.
