Suggest a light for side visiblity?
I use the dinotte 140 for rear and fenix l2D for front . I used to use Planet bike superflash for side visibility but it fell off my bike and I lost it ( my fault , not planetbike's fault ). Should I buy another superflash or is there anything better out there under $25?
Bikes: 2007 Specialized Roubaix
I haven't seen one in person, but check out https://www.niteize.com/productdetail...product_id=163
Mad bike riding scientist
Quoted: 6220 Post(s)
Liked 4,221 Times
Stuart Black
Stuart Black
The Marker Band from Niteize is only $12 at REI. Not a bad product at all.
Is that Marker Band an item that could be used prevent a pant leg from getting into the chain? I like the looks of Nite Ize products and would like to buy this one.
Liked 4,221 Times
Probably. It has a buckle to hold it on that is adjustable. I put mine on under the knee but I don't see why it couldn't be mounted on your ankle.
Stuart Black
Stuart Black
Non-Spandex Commuter
Bikes: Trek Soho S
You can get Planet Bike BRT Straps for less than $10 at Amazon
Bike ≠ Car ≠ Ped.
Before you spend money on side lighting (even if you'd just spend a few bucks), think a little more carefully about when you actually need it.
Liked 4,221 Times
I would second that. My leg light is more for rear visibility than for side visibility. The motion of the light going up and down is to get attention for overtaking drivers. I only wear it on the left side. For traffic at intersections, I have powerful froward facing lights. One of these is always a helmet light.
Stuart Black
Stuart Black
It is definitely needed , there are many times when you and a car approach at an intersection at the same time, so the car can't see your front light too well. Also useful if traveling on 6-lane roads ( 3 each way ) and you have to change lanes. I have only been without it for 100 miles and already several instances have come up where I knew it would have helped motorists see me better.
Bike ≠ Car ≠ Ped.
At an intersection, side lighting is only important if you're sitting in the middle in the path of oncoming traffic. And, while crossing several lanes, it's only important if you have someone nearby and traveling at the same speed. In either case, if you're in a position where a driver has to jump on their brakes to avoid hitting you, it's a dangerous position.
The trick is, we can't rely on motorists to see us, even if we're lit like a Vegas hotel sign. Most drivers do pretty darned well in staying aware, but all it takes is one who's distracted enough and our day is ruined. That's how my first car got totaled, in fact -- the driver was dealing with her crying baby and ran a red light, then smashed into the right rear of my car at maybe 30-35 mph.
Buy as many lights as you want. But, ride like a bike ninja just in case they still can't see you.
In case it is not obvious these require traditional cross spoke lasing. Mine works with 28-hole 3x. I don't know if it would with anything less unless you devise a way to mount it. They were definitely not designed for radial spoke configurations. I bought a pair intending to put it one on each wheel. I had to put both on the rear wheel because they are not designed for a 24-hole 2x wheel.
It's above your budget but a Monkeylectric may be tops for side visibility. 16 LEDs on each side of your wheel. Use coupon BIKECULT for 10% off. I've been using one since Sept. and love it.
Bike ≠ Car ≠ Ped.
Well, guess I'll make my light recommendations --
Mars 4.0. Much brighter main LED than the 3.0, doesn't need a tiny screwdriver to change its batteries, and has amber side LEDs, which won't be confused for red taillights at a distance.
If you're using generator lighting and have a rear rack, try to get a B&M Selectra. Besides a nice main LED, it has two small LEDs on the sides pointing outboard.
If the superflash fit well, then I'd suggest a Blinky 7. Since the Dinotte gives you plenty out back, and you're looking for SIDE visibility, the Blinky 7 fits the bill nicely with LEDs pointing at 45 and 90 deg relative to straight back.
THanks for all the replies, I researched all of them and decided on Monkeylectric. It came out to $56, but that provides visibility on both sides, so just $28/side. From what I read, they are bright and very cool, so should go a long way in diffusing any anger motorists try to unleash on you. I was concerned about the off-balance weight, but it does not seem like much an issue.
Sheldon Brown recommended mounting amber revolving lights on you helmet.
https://www.youtube.com/watch?v=cejqICVRO-4
I think it was his April 02 blog post.
An Army of Fred
Location: Lost South of Nowhere East of Edan On the Waterfront Far from the Madding Crowd (Biloxi, MS)
Bikes: 1992 Specialized Crossroads Trail
I use a combination of reflective tape, reflective sidewall tires, and a dual-tube Down Low Glow. Haven't had a problem with cars not seeing me at night.
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
reflective tape on the rims, crank arms, fork and seatstays.
can use red for the rear, white for the front, amber and blue for the sides.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
they have been excellent. I put around 1500 miles on them since I bought them. They're quite visible and have two power modes. the low power is plenty visible at night and the high power mode is good for overcast daytime visibility. I'm working on a new video to show them in action. Battery life is also very good, lasting between five and 15 hours depending which mode use it in.
Bikes: Litespeed Liege, Motorola Team Issue Eddy Mercxk, Santana Noventa Tandem, Fisher Supercaliber Mtn. Bike
Quoted: 14 Post(s)
Liked 11 Times
I personally use a PB Superflash on my seatpack but just added one of these for a little extra added visibility.. I just wrap it around my rear triangle, just above my rear brakes.. Nathan Acid Reflex Snap Band LED Light.. I also use it for running at night, just wraps around my arm.. It uses 2 small watch batteries for the leds.. It gives you 360 degrees of flashing leds...
https://www.pricepoint.com/detail/169...-Snap-Band.htm
