7200 Lumen Lupine Alpha Road Light
#176
Quoted: 140 Post(s)
“...when tootling along on my local MUP”
If the OP is the least bit interested in being honest he should correct his misleading thread title.
This LUPINE light is not a “road light,” it’s specirically designed and marketed for MOUNTAIN BIKE RACING.
#177
Quoted: 642 Post(s)
Liked 1,526 Times
Out of curiosity, how many people following this thread would seriously consider a $1200.00 light?
#178
Non omnino gravis
#179
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
That means it will take bumps and wet weather. There is no reason you can't put it on a road bike. When needed turn it down, Has no one heard of different settings on a light? Go to the lupine pages and read about their lights. I guess it's more interesting to try and think of things wrong with the light than going to the web site and learning about it. However, this is normal BikeForums behavior. I might have done it myself, I guess I should not complain.
#181
Bikes: 2 many
Liked 323 Times
If I thought I could find better lights out there I would have one. I suspect Trekmogul ,and some others, would do the same.
#183
Bikes: 2023 Canyon Aeoroad CF SL, 2015 Trek Emonda SLR, 2002 Litespeed Classic, 2005 Bianchi Pista, Some BikesDirect MTB I never ride.
Quoted: 647 Post(s)
Liked 136 Times
#186
Was this video shot with the battery nearly drained? Was the light on it's lowest setting? Can you compare a lower lumens model from any other brand: say a 700 lumens?
Highest setting I assume?
#187
Bikes: Salsa Beargrease XX1, Trek Eqnuinox 9.9 SSL, Trek Madone 6.9 ,Trek District Carbon, Trek Boone7, Trek Fuel EX9.0,Trek Fuel 9.5, Trek Rumblefish Pro, Trek Remedy 9.9, Trek Equinox7, Trek District Belt
Quoted: 578 Post(s)
Liked 82 Times
Less then a month and ...? Umm ok
Trek Fuel EX9.0 Trek Fuel EX9.5 Trek Equinox 9.9SSL TTX Trek Madone 6.9 Pro Red Project One, Trek Boone 7, Trek Rumblefish Pro, Trek Remedy 9.9, Trek Carbon District
#188
Quoted: 578 Post(s)
Liked 82 Times
Show me one more expensive..? Please
#189
Quoted: 578 Post(s)
Liked 82 Times
Who said it was to much may I ask..? Did you buy one yourself..? I did and happy with it.. your claim is not mine i can say as i own one..
#190
Quoted: 578 Post(s)
Liked 82 Times
You're a man of your word: you posted a video. As I suspected, the results are very disappointing, especially for a $1,200 light. There is a distinct circular hotspot and then brightness washes out on the periphery.
That looks really nice. Far better than the lupine.
#192
Quoted: 578 Post(s)
Liked 82 Times
It is a $1200.00 light that works ok for me..
#193
Quoted: 578 Post(s)
Liked 82 Times
$1700.00 with 2 extra batteries more then a bike )
#194
Quoted: 479 Post(s)
Liked 277 Times
Well, I guess we're even... 'cause I don't get your joke.
Am I the $50.00 head lamp buyer in this one? If so, you're not terribly far off - my Cygolite 850 was around $80. But, from the videos/pics I've seen, apparently it's cranking out 7,200 lumens. Sweet deal really.
#195
don't try this at home.
Quoted: 973 Post(s)
Liked 511 Times
** cygolite 850 snapshot **
trekmogul, make a video with your car headlights on normal, then on bright, aimed at a building across a parking lot. Aim the Lupine to the side of the headlight beam.
Dimming
Any decent bike headlight doesn't get dimmer as the battery drains. It has voltage regulation, so it stays evenly bright until the battery can't sustain it anymore, and then the light drops to a lower output, then finally goes out.
Photo comparison
You can't compare lights unless the camera is set to manual, so that all the photos use the same exposure. Otherwise the camera tries to adjust exposures to make them all the same brightness.
The mtbr beam photos below had to make a short exposure so the brighter lights wouldn't over expose. So the lower lumen lights look very dark. All these lights would seem brighter to your eye than their photo shows.
Actual brightness
A lot of these lights have been tested by mtbr.com, using an "integrating sphere" that measures the lumens quite accurately.
The beam spread does make a difference on how far the light projects out, of course.
And some lights are a lot smoother than others -- which can have bright spots or sharp cutoffs at the edge.
The 2016 beam patterns thumbnails page -- there's a lot of differences.
From mtbr.com's 2016 tests, same camera, same exposure, same location.
Cygolite 450. Measured 405 lumens.
That's a lot less light than the others. (remember, these are all the same exposure.)
Lupine Betty. Claimed 5000 lumens, actual 4989 lumens.
This older light does seem to have somewhat sudden cutoff at the edges. But you could go 40 mph downhill and see far ahead (not that I'd want to do that at night, though.)
L&M 850. Claimed 850 lumens, actual 810 lumens.
Yes, 810 lumens isn't as bright -- who could have guessed?
Looks like more light is concentrated in the center of the beam, for distance coverage. The edges don't have a sharp cutoff--good.
Dinotte XML-3. Claimed 1600 lumens, actual 1573 lumens.
I have this light, a little newer version at 2000 lumens. It has a very wide, very smooth beam -- great for riding, but with a tradeoff of less reach far ahead on fast downhills. It works great for me, and the very long runtimes with the big battery are nice.
I run this at the 2000 lumen setting in the city, to compete with the mixed bright streetlights and dark shadows, and glaring car headlights. That's too bright for my night vision on dark country roads, where 500 or 1000 lumen settings work much better. (reflective signs are painfully bright at 2000 lumens!)
corrado33
1
10-28-14 01:50 PM
northerntier
71
11-12-13 11:05 AM
PaulRivers
12
06-04-10 01:20 PM
