Tire recommendations for CAAD12
Quoted: 2432 Post(s)
Liked 638 Times
You want the best you got to pay for the best.
https://www.competitivecyclist.com/v...NjQ2F0MTAwMDc1
Bikes: 2019 CAAD12, 2015 Specialized Sirrus Comp
Quoted: 562 Post(s)
Liked 64 Times
Please elaborate on why these tires might be a good solution for me.
Voice of the Industry
Quoted: 1188 Post(s)
Liked 8 Times
https://www.competitivecyclist.com/vittoria-corsa-control-g-plus-tire-clincher?skidn=VIT003Q-SKI-S700CXS25MM&ti=UExQIENhdDpSb2FkIEJpa2UgQ2xpbmNoZXIgVGlyZXM6MTo1OmNjQ2F0MTAwMDc1
A good look is just a good look. 320TPI...uber flexible shell.
Yup, get what you pay for.
Liked 638 Times
Well look at the specs. 320tpi handmade cotton casing. It's an open tubular. Doesn't get any more supple than that. Unless you're just set on a 28c, look at the Open Corsa CX, CC has them in 25c for a killer price. I've gone through two pairs and not one puncture. They don't show it but it has a PRB 2.0 protective belt. Mine measure 26mm on some narrow rims. The Road Bike Review test measured them at 28mm.
https://www.competitivecyclist.com/vittoria-open-corsa-evo-cx-iii?skidn=VIT0090-BK-S23C&ti=UExQIENhdDpSb2FkIEJpa2UgQ2xpbmNoZXIgVGlyZXM6MTozOmNjQ2F0MTAwMDc1
https://www.bicyclerollingresistance...sa-cx-iii-2014
Quoted: 562 Post(s)
Liked 64 Times
I know what tubulars are, but have never heard the term "open tubular" before. What does this mean?
Liked 638 Times
Open tubular is a type of clincher tyre that uses the unique construction method of high-end tubulars. Vittoria open tubulars have exactly the same production process and properties as the tubular, except for the sown-in inner tube. Open are handmade with aramid folding bead for optimal fit on the rim.
https://www.vittoria.com/us/road-tire
Quoted: 1067 Post(s)
Liked 259 Times
They're constructed the exact same way a tubular is but instead of being sewn with a tube inside that attach beads. They don't have a sidewall, when they're new they come completely flat.
If you look on a forum like "Slowtwitch" where the triathletes really obsess about what is fastest I don't think you will find any recommendations for a Corsa CX.
Advocatus Diaboli
Quoted: 4736 Post(s)
Liked 1,532 Times
2 flats in this first month. Verdict is still out for me. First flat was a tire radial belt wire.. and I kinda think those will flat almost any tire. 2nd one, not sure what it was but it was a pinhole sized tube puncture, and found about a 2mm gash in the bead of the tire.
I do like how they ride (coming from Mich Pro4 Endurances), and after initial install which was a wee bit difficult, subsequent installs on my rims have been super easy. Always nice to have easy tube changes on the road.
Probikeit has the best Vittoria pricing fyi..
Liked 638 Times
Neither tire will make either one of us faster or slower. I didn't compare it to the GP4000 or anything else. I have them, I love them so I posted it up. I've never ridden the GP4000 so I won't comment on it. I suspect you've never owned the CX. And for $34.95 I'll take it over the Conti any day.
Liked 259 Times
Liked 638 Times
And if you've had a GP4000 you didn't ride any faster. The test I posted a link to actually compares it to the Conti, read the end of the article. The difference in rolling resistance is less than one watt, and the author admits he was surprised because every other test he's seen had the CX ahead. It also outperformed the Conti in the puncture test. They're basically very equal tires but you can get the CX for almost half the price. I'm not too interested with what recreational triathletes say because the pro's are on tubulars anyway.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
I'd recommend trying a pair of Vittoria Rubino Pro G+. They are supple and forgiving with a beautiful ride and have reasonable flat protection. These tires can be pushed hard by ordinary riders and will make you feel like you are a pro. They won't suddenly slip out on you but are very predictable.
They can be found at around $37 each. Less if you are persistent in looking.
-Tim-
-Tim-
- Soli Deo Gloria -
Liked 736 Times
I've been using the Corsa Controls for the past month; not sure if you're recommending these or the CX tires..
Nice ride and easy install but I had 2 flats in less than 450 miles. Both times were tiny, almost microscopic pieces of glass which had to be located with magnifying glass and removed with tweezers. Others I ride with have said the same, that they tend to pick up every little bit of debris.
I also feel like 252 grams each is a bit heavy given the price and I went back to Rubino G+ Speed which are 198 grams each.
-Tim-
I've rode on the Continental 4000 IIs's and the Michelin Power Competition and Endurance. I had problems with the Continentals with sidewall flats. I had 2K miles on the Micheline Power Endurance and then I hit a screw that ruined the tire. I am currently on the Michelin Power Competitions and they run as smooth as the Conti's and I've had better luck with side wall problems.
Señor Blues
Tires are largely personal preference OP. Most have their favorites. For example, I have had great luck on Vittoria Rubio Pros with 150TPI. Fast, great puncture resistance, good durability and not too pricey. Great training tire. There are 'slightly' faster tires out there but have other trade offs.
Many believe there is some side wall integrity sacrifice for the rolling resistance of the Conti GP4000's. Many have had issues with side wall blow outs with them. Go out on the web. You don't read about this with Vittoria, or Michelins. I find Michelins also to be great tires but they seem to wear quickly.
No free lunch. I like Vittorias because of the ten's of thousands of miles I have gone on them with relatively low punctures, good durability and a relatively fast and durable training clincher that you can pick up for less than $40/tire.
Liked 638 Times
Yes. The term "open tubular" confuses a lot of people but they are clinchers. It's a tubular tire that's left "open" and has beads attached to mount on a clincher rim instead of being sewn together.
https://www.youtube.com/watch?v=VjizyLVnuq8
Lava
17
07-08-19 02:01 PM
Jarrett2
42
03-28-17 08:56 AM
