Wheel case for gravel bike
Quoted: 37 Post(s)
Hi, has anyone used a hard wheel case with your 700c x 38mm tires mounted? If so, what brand. The TriAll 3 Sports Wheel safe Pro case looks good, but I can't tell if it will hold my 700x38 wheels with tires mounted (tubeless, so don't want to remove--or deflate fully if possible).
Thanks for any thoughts,
Mark
Mark
Quoted: 37 Post(s)
In the event anyone reads this and also is interested, I spoke with the owner of TriAll 3 Sports today, and he said the case would fit 700c wheels with larger tires on them. I ordered one and will confirm this (hopefully!).
Mark
[UPDATE: I got the case, but it DOES NOT fit a 700cX35mm tire mounted, even deflated, much less a 38mm. The TriAll 3 Sports owner meant well but apparently hadn't actually tried it, and was wrong. I am not sure what the maximum sized tire, deflated, would fit in that case. Perhaps 28mm to be safe.]
Mark
KeatonR
11
06-27-20 05:14 PM
cosbike01
General Cycling Discussion
28
09-24-12 08:01 PM
