Caution
Bikes: TREK 8000,Trek Domane 4.5,Felt FR
Quoted: 21 Post(s)
Caution
For a year and a half I have been running a set of Mavic Ksyrium UST and a set of Mavic Ksyrium Pro UST wheels using Mavic Yksion Pro UST tires with great results.I have gone thru a couple sets of tires never having a problem. After reading all the BS about the new Continental 5000TL I broke down and ordered a pair. After two hours I can't get the tires on the rims. Even if I got stronger tire levers I might have a chance but I doubt it and having a flat on the road that the sealant wouldn't seal I would have to call for a ride because I knw I could never install a tube. I wouldn't recommend trying these tires. You might end up like me with a set of Continental 5000TL sitting on the shelf collecting dust. Getting ready to order a new set of Yksion Pro UST's that are no trouble mounting with my bare hands. THANKS
Quoted: 21 Post(s)
Caution
I have been using Mavic Ksyrium UST and Kysrium Pro UST wheels for over a year and a half. Having used a couple sets of Mavic Yksion Pro UST tires with out any problems. After hearing all the BS about the new Continental 5000 TL I broke down and purchased a pair. After two hours of trying I can't mount the tires. If I ever did get then mounted I know I would never be able to install a tube out on the road if I had a flat that the sealant wouldn't seal. I would have to walk or call for a ride. Now I have a set of Continental 5000TL's sitting on the shelf collecting dust. I getting to order a set of Yksion Pro UST's that I can mount by hand and air up with a floor pump. You have been warned!
Quoted: 878 Post(s)
Liked 726 Times
Obligatory Kool Stop tire bead jack plug. Or stick with tires you can mount by hand, that's perfectly ok too.
Quoted: 18378 Post(s)
Liked 4,512 Times
When I had a hole in my Schwalbe One fail to seal on an Ultegra 6700 or 6800 rim, I had a major hassle getting a tube installed.
I had only gone tubeless on one, and eventually swapped tires and mounted the Schwable One on the RS-10 wheel which was much easier.
Quoted: 21 Post(s)
goenrdoug you might be right they sure don't work on UST rims,I will try to mount them on regular at a later date so it won't be a waste of money
Quoted: 18420 Post(s)
Liked 15,564 Times
Likes For indyfabz:
Old fart
Quoted: 3590 Post(s)
Liked 3,400 Times
Quoted: 942 Post(s)
Liked 527 Times
Forum Moderator
Quoted: 3091 Post(s)
Liked 6,601 Times
Quoted: 1067 Post(s)
Liked 259 Times
Do the UST rims have much of a well in the centre to put the bead in when mounting?
I had a set of tubeless rims that were very shallow. Some tubeless tyres were absolutely impossible to mount.
Quoted: 20810 Post(s)
Liked 9,456 Times
Likes For WhyFi:
On my Vision 40 wheels, Continental GP5000 (tubeful) were the easiest mounting tires I've ever put on a modern bike. Never needed a tool or blow dryer or vaseline - and didn't need to pop a vein in my forehead straining to get them on, let alone have to bring out the Koolstop!
Advocatus Diaboli
Quoted: 4736 Post(s)
Liked 1,533 Times
So.. to go a bit OT: The UST standard was a 3-company sponsored launch from what I've read -- Mavic, Hutchinson and Michelin. Have I missed it, or does there not seem to be such a thing as a Michelin UST TL tire for road? Anyone have an idea why that is?
Liked 9,456 Times
Not sure on your specific question, but this reminded me that the new Schwalbe Pro One Souplesse are made to the newly-established ERTRO tubeless specs. From what I understand, the new standard is based heavily on the Road UST, so we might have some more firmly established goal posts, which would be good for everyone, and the promise for a broader tire selection for Mavic wheel owners.
Advocatus Diaboli
Liked 1,533 Times
Quoted: 4806 Post(s)
Liked 3,931 Times
Another option is the Crank Brothers Speedier.
https://www.crankbrothers.com/products/speedier-lever
FlashBazbo
5
08-08-19 02:54 PM
HCB
Road Cycling
10
01-24-15 06:33 PM
