Where is the serial located on a Surly DT?
Old 09-12-19, 07:50 PM
ExtremeSquared
Quoted: 7 Post(s)
Liked 6 Times in 5 Posts
Is the serial hidden beneath the BB cable guide? I'm wondering if it's absent because it's a warranty frame. It's not where it used to be.
ExtremeSquared is offline
Old 09-13-19, 01:39 AM
schoolboy2
Easily Led Astray
Bikes: Trek 5200, Trek Domane 5.2, Surly Long Haul Trucker
Quoted: 33 Post(s)
Liked 10 Times in 9 Posts
I have an LHT and it's under the BB, and often unreadable due to thick paint.
Happy Hunting!
Opinions are like noses, everybody has one.
schoolboy2 is offline
Old 09-13-19, 06:46 AM
djb
Quoted: 2741 Post(s)
Liked 975 Times in 798 Posts
are you the same person and is this the same frame from a similar question from a while back?
djb is offline
Old 09-13-19, 10:38 AM
ExtremeSquared
Quoted: 7 Post(s)
Nope. This is an 8 year old account.
And thanks. It is there -- it's just shallow enough it needed a flashlight at an oblique angle to make out.
Old 09-13-19, 03:50 PM
djb
well, I'm glad that you are not losing your mind, and also glad that you are serialed.
djb is offline
Old 09-14-19, 12:44 PM
seeker333
seeker333's Avatar
Bikes: yes!
Quoted: 282 Post(s)
Liked 38 Times in 36 Posts
Here's how you interpret Surly LHT/DT stampings (from an old post):
"My 2006 LHT (not a Deluxe) had the serial number M6012345 (M for Maxway, 6 for 2006, followed by 6 digits which I believe are a simple serial number indicating order of production.
My 2012 Disc Trucker is stamped M12012345, again M=Maxway, 12=year of manufacture and the following 6 digits are serial number. This whole M12012345 serial number is stamped on the right/drive side of the underside of bottom bracket, and on the left/nondrive side is the stamp DISC700-56, indicating brake type, nominal wheel size (700 or 26) and nominal frame size as described in Surly's published geometry tables."
seeker333 is offline
Old 09-14-19, 06:03 PM
BigAura
BigAura's Avatar
Bikes: all steel stable: surly world troller, paris sport fixed, fuji ss
Quoted: 623 Post(s)
Liked 55 Times in 33 Posts
From my LHT, AFAIK it's the same place for all Surly bikes
BigAura is offline
Old 09-17-19, 01:56 AM
ExtremeSquared
Quoted: 7 Post(s)
Yep it's there, but no way it'd show up in a photo like that. It's near invisible under the paint.
Old 09-18-19, 01:08 AM
PDKL45
PDKL45's Avatar
Bikes: Merida Speeder
Quoted: 233 Post(s)
Liked 165 Times in 115 Posts
Those frames don't have wet paint applied to them, they're powder coated, so that while they're a bit more resistant to chipping and scratches, the layer of color is thicker, obscuring the serial number to an extent. Glad to hear you got it sorted out, OP, despite the thicker color layer.
PDKL45 is offline
vintagerando
Classic & Vintage
9
07-01-19 09:58 PM
horatio
Classic & Vintage
11
03-17-19 08:15 PM
everlast1266
Classic & Vintage
3
09-03-17 07:11 PM
beckieanne
Framebuilders
1
01-21-14 05:33 PM
DRietz
Classic & Vintage
3
08-31-10 06:33 PM
