Go Back  Bike Forums > Bike Forums > Fatbikes
Fat bike upgrades
Fatbikes Designed for use in sand, mud or snow, Fat bikes are the right choice for true all-terrain riding. Check here for the latest on these fun, adventurous two-wheeled machines.
Fat bike upgrades
Old 09-17-19, 04:09 PM
Rajflyboy
Rajflyboy's Avatar
Bikes: Orbea
Quoted: 917 Post(s)
Liked 205 Times in 170 Posts
Fat bike upgrades
What do you recommend?
Rajflyboy is offline
Old 09-17-19, 06:24 PM
moses
Tires
moses is offline
Old 09-17-19, 10:08 PM
MarcusT
MarcusT's Avatar
Quoted: 766 Post(s)
Liked 616 Times in 344 Posts
I guess it depends on which fat bike you have. Maybe everything, maybe just the bar grips.
On my mid range; tires, saddle, grips, pedals
MarcusT is offline
Old 09-18-19, 12:59 AM
Happy Feet
Happy Feet's Avatar
Quoted: 2236 Post(s)
Liked 1,314 Times in 707 Posts
What bike and what do you want to do with it?
Saves asking others to write a bunch of stuff that might not apply.
Happy Feet is offline
Old 09-18-19, 06:21 PM
Rajflyboy
Rajflyboy's Avatar
Bikes: Orbea
Quoted: 917 Post(s)
I just have a cheap redline bike I take to the beach occasionally
but this cheap bike is very fun and I’d like to do a few things to it
thinking going tubeless and putting lighter tires on it. Maybe a better front brake.
Anything I’m missing here?
https://www.walmart.com/ip/Redline-B...Blue/846818614
Old 09-18-19, 10:21 PM
MarcusT
MarcusT's Avatar
Quoted: 766 Post(s)
It's difficult to justify spending more on upgrades than what the bike cost new.
I would suggest sell (or return) the bike and take the money you would have spent on upgrades to buy a high end, used fat bike
MarcusT is offline
Old 09-18-19, 11:01 PM
Happy Feet
Happy Feet's Avatar
Well.. if the goal is just the occasional beach ride then it may fit the bill. Sort of like a boardwalk cruiser for sand. No one expects high performance.
Before looking at brakes I would ask if they are up to the job as is. If so hold off at least until they wear out the pads. At that time look at some better quality pads as they probably came with low end ones. Some people want a better overall system but if you are just doing the beach occasionally the Tektro's are probably fine for now.
A good swap is the saddle if it is uncomfortable. I say this because the saddle can travel from bike to bike so it is an investment that doesn't stay with the bike. Keep the original in case you sell it. The same reasoning can be applied if it has crappy pedals.
One reason people up grade is to lighten the bike. Without knowing the specifics I would look at the seat post and bars to see if they are steel or Aluminum. Not a big investment to swap either. I would also take off the kickstand.
The rims are already drilled so the next step is lighter tires but that is a bigger cost so again, maybe wait until you wear the originals out. At that time you might read up on tubeless to save a little more weight.
The other upgrade I see that may make a difference is the derailers and shift levers if the drivetrain is clunky and they are low end Shimano. An upgrade to mid grade components could make for smoother shifting.
Other than that, there's not much else to do.
Old 09-19-19, 03:25 PM
prj71
Quoted: 2975 Post(s)
Liked 1,180 Times in 770 Posts
^^^This.
You bought a Bike Shaped Object (BSO) from Walmart.
prj71 is offline
Old 09-19-19, 07:43 PM
Rajflyboy
Rajflyboy's Avatar
Bikes: Orbea
Quoted: 917 Post(s)
Thanks for your thoughts. Good stuff.
I have an MTB and a gravel bike hat I ride most often. The cheap Fat Bike is mostly just for beach trips but I have taken it on single track where I live and it’s a total blast. Lighten the bike up a bit and a few upgrades will make it a lot better for my needs. Someday I will ante up and get a high quality fatty to add to the stable.
Let me say it again (this inexpensive fat bike is loads of fun). Lots of bang for the buck.
Likes For Rajflyboy:
Old 09-19-19, 07:48 PM
Rajflyboy
Rajflyboy's Avatar
Bikes: Orbea
Quoted: 917 Post(s)
Originally Posted by prj71
^^^This.
Is this a BSO from Walmart?
https://www.google.com/shopping/prod..._Q,prmr:1,cs:1
Old 09-25-19, 12:30 PM
Boogie85
Every LBS owner tells me wheels are the biggest upgrade you can make.
Boogie85 is offline
Old 10-03-19, 01:57 PM
Rajflyboy
Rajflyboy's Avatar
Bikes: Orbea
Quoted: 917 Post(s)
[QUOTE=Boogie85;21137983]Every LBS owner tells me wheels are the biggest upgrade you can make.[/QUOTE ]
Thats what it appears from riding this thing. Too much rotational mass with wheels/tires. I’m thinking good tires/tubeless will be first change.
lhill
Fifty Plus (50+)
0
08-11-18 02:16 PM
StarBiker
Fatbikes
2
01-09-18 12:14 PM
CanadianBiker32
Mountain Biking
12
06-22-15 02:37 PM
joco
Electric Bikes
10
02-28-13 01:56 PM
