Explain Like I'm 5: Don't I need a compression plug to oppose the stem bolt forces?
Quoted: 8 Post(s)
I'm 3 years new to cycling. I've had this bike (Canyon Endurace AL Disc 7.0) for 1 year with NO problems. I have, however, been doing some research and it seems like compression plugs are very much recommended for carbon steerers, as they provide a necessary opposing force to the stem bolts, thus preventing carbon crimping/failure over time. In fact, it seems that compression plugs that cover the entirety of the steerer (in this case 40mm in length) seem pretty standard on bikes. It doesn't look like Canyon ships their bikes with these plugs; they just come with this short (15mm) wedge at the bottom of the steerer that is only good for loading the bearings through tightening the stem cap. I'd like my carbon steerer to be safe. Should I remove this 15mm wedge and replace it with a 40+mm compression plug that covers the length of the stem and stem bolts? Something like this?: https://www.pro-bikegear.com/global/...RO_HS_GAPEXPAN
Thanks in advance.
Thanks
P.S. please correct me if I'm wrong with any of this...
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
Since you're 5...
- The grown ups that built the bike probably know what they were doing
- You're going to outgrow that bike in 6 weeks anyway so time to buy another.
- If you have a torque wrench and know how to use it you probably aren't going to squish that carbon tube anytime soon.
Quoted: 1851 Post(s)
Liked 678 Times
Since you're 5...
However, I believe in better safe than sorry, and if a compression plug can add additional support and strength and reduce the risk of a snapped steer tube, then I'm all for having one in there.
Non omnino gravis
Likes For DrIsotope:
Bikes: Shmikes
Quoted: 10152 Post(s)
Liked 5,843 Times
I confess to this form of weenie anxiety too. My Cervélo came with only a star nut.
Quoted: 3241 Post(s)
Liked 2,512 Times
Timely thread considering the CF steerer/fork failure that is being talked about.
I think any compression plug is helpful, and buttresses the steerer pretty well if it's somewhere in the range where the stem clamps.
Make sure a carbon steerer is cut well with a good carbon saw, and there's no excessive clamping during the cut. I'm convinced some of these get cracked before they're ever ridden because someone clamps down the cutting guide like they're about to saw a 2x4.
Bikes: SL8 Pro, TCR beater
Quoted: 981 Post(s)
Liked 583 Times
I wouldn't worry at all if your bike came factory set up like this. The video does also specify that if your bike didn't come with one, it's because it don't need one (which is logical, otherwise you would have one). I'd trust your manufacturer; its engineers are a little more educated than we are.
It's also funny how the guy in the video doesn't use a torque wrench. May be that's because the plug prevents the overtightening. Still, I would use one...
Likes For eduskator:
Quoted: 1975 Post(s)
Liked 232 Times
Where is the top cap? Does it have an extended length that fits snugly in the steerer tube? That provides the support needed as well and adds to the 15mm of the compression plug
climber has-been
Quoted: 3417 Post(s)
Liked 3,546 Times
Try to find a statement from a manufacturer that specifies using one of these full length compression plugs. Go ahead. I've searched for years for such a statement and have come up empty handed.
If the manufacturers aren't publicizing compression plug warnings, a safe conclusion is that it's a made up myth.
Ride, Rest, Repeat. ROUVY: terrymorse
Likes For terrymorse:
Quoted: 18883 Post(s)
Liked 10,646 Times
People have a lot of anxiety about this.
The handlebars and seat tube don't have compression plugs in them, and nobody seems to mind.
Likes For Seattle Forrest:
Bikes: Shmikes
Liked 5,843 Times
climber has-been
Liked 3,546 Times
Everyone, prepare yourselves emotionally for the new products that promise to keep your bars and and seat posts from "asploding".
Likes For Bigbus:
Bikes: 1975 Albert Eisentraut, 1992 Bill Davidson, 2006 Moots Compact, 2007 KHS Solo-One, 2010 Van Dessel Drag Strip Courage, 2013 Alchemy Xanthus, 2016 Breadwinner Lolo, 2018 Moots VaMoots RSL, 2019 Chapter2 Tere Disc, 2020 Chapter2 Ao Limited Edition
Quoted: 31 Post(s)
Liked 32 Times
Go ask your mother.............
Likes For tony2v:
Should Be More Popular
Quoted: 22579 Post(s)
Liked 8,919 Times
Liked 8,919 Times
Liked 10,646 Times
Liked 8,919 Times
Likes For datlas:
Quoted: 551 Post(s)
Liked 277 Times
Likes For tagaproject6:
Quoted: 981 Post(s)
Liked 583 Times
The top cap has no utility at all once the stem bolts are tighten to the proper torque... It can technically be removed. Your fork tube will not asplode if ridden without (your head might though if you continue overthinking the whole thing).
Liked 232 Times
the top cap used with those types of carbon steerer compression tubes prevent the tube from deforming on the open end where cracking generally occurs, it is necessary for proper function of the compression plug design
Likes For redlude97:
Liked 8,919 Times
My understanding has been that the top cap is really only needed to set the preload, but I don't have any "proof" other than that's what everyone says.
Anyone know if there is proof/evidence to prove the first statement and/or disprove the second?
Liked 232 Times
These two statements are totally contradictory.
