Pedal Extender Question
I recently purchased Stamp 7 pedals. The spindle has an 8 mm allen key. I then bought 15 mm pedal extenders. The hole in the extenders is not large enough for the allen wrench to go through the extender and into the end of the spindle so I can then tighten the extender before installing on the crank. The extender has the usual flat spots for a pedal wrench.
Has anyone encountered this? There doesn't seem to be any other way to tighten the extender on the pedal spindle.
Is it possible to buy an extender with a larger diameter hole for the allen wrench?
thanks
Bucksnort
thanks
Bucksnort
Quoted: 2026 Post(s)
Liked 1,095 Times
An 8 mm (or 11/32") drill bit should make the hole the right size.
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
I must be missing something here I thought you install the extenders on the cranks with a regular open end wrench and then install the pedals on the extenders using an Allen wrench. What am I missing here? I'm old and easily confused, but this is troubling me.
Quoted: 1438 Post(s)
Liked 1,092 Times
So Hillrider's suggestion to enlarge the holes should work if the (presumably) steel has not been hardened.
Very Senior Member
Quoted: 413 Post(s)
Liked 343 Times
The OP states "The hole in the extenders is not large enough for the allen wrench to go through the extender" So if the extenders are on or off of the crank he cannot tighten the pedals into the extenders.
Edit-I looked up the Stamp 7 pedals (they are biggies, aren't they?) and now I understand. Thank you dsbrantjr.
Liked 1,092 Times
Yes, there are no wrench flats on the pedals. And just to add to the confusion, you have to turn the hex wrench counterclockwise on the drive side, and vice versa, as a result.
Liked 1,095 Times
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Seems that some pedal extenders cannot be used with some pedals.
Likes For JanMM:
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 674 Post(s)
Liked 738 Times
Not quite. An 8 mm hex is measured flat face to flat face. You need a larger hole to fit the points of the hex. (Ask me how I know....)
These extenders have a large hole. In the questions section, they say a hex wrench will fit through them.
Bikes: Lynskey GR270
Quoted: 115 Post(s)
Liked 69 Times
Depending of your pedals, you may be able to grind a wrench flat. I did just that with a belt sander and some M785 pedals.
Liked 1,095 Times
Quoted: 8259 Post(s)
Liked 8,990 Times
I've used extenders since I had to have them custom made and I have not tried extenders with holes and I would be suspect of their strength.
I always use pedals with wrench flats but they are becoming more unusual. I don't like the stupid 8mm allen thing.
Liked 8,990 Times
Quoted: 741 Post(s)
Liked 818 Times
I've been using pedal extenders for years. On pedals without wrench flats, I screw the extenders to the pedal arm using the flats on the extender, then using a rag to protect the pedal shaft, take a pair of vice grips and snug the pedal to the extender. Never had a problem with them loosening (they kind of self tighten as you ride) or removing them the same way. I grease the threads before assembly just in case.
Edit: I just looked up Stamp 7 pedals. Wierd looking suckers. You would need a very thin vice grip to grab them. The drilled extenders may be your only answer.
This is an XT pedal without wrench flats with a pedal extender. The hex just in board of the pedal turns with the pedal, and is no help for tightening. I just grip the shaft with padded vice grips and snug it up. No big deal.
