Brake lever compatibility on Moser
Bikes: Gunnar, Shogun, Concorde, F Moser, Pete Tansley, Rocky Mtn, Diamant, Krapf, Marin, Avanti, Winora, Emmelle, Ken Evans
Quoted: 273 Post(s)
Liked 416 Times
Cantis work with road levers right, so how well will canti flat bar levers work with caliper brakes? I think they're deore LX and 600 tricolour.
Blamester
Try them and see.
How big a job is it to cable it?
You might be o.k. you might not.
Good pads and clean rims.
Quoted: 273 Post(s)
Liked 416 Times
fair point, i'd just rather not waste the cables
Bikes: More bikes than riders
Quoted: 1443 Post(s)
Liked 759 Times
That combination should be compatible. Caliper brakes are also "short pull" to my knowledge, so you should be in the right ballpark. The two primary types of brakes (that I can think of) that require "long pull" levers are linear pull brakes (often called V-brakes) and MTB-specific mechanical disc brakes. I think pretty much everything else (including road-specific mechanical disc brakes) uses "short pull" levers.
I think there is some variability there, even within the "short pull" category, but you should be close, anyway.
Quoted: 1438 Post(s)
Liked 1,092 Times
Quoted: 273 Post(s)
Liked 416 Times
Yes, it is not a black-and-white thing but cantilever and calipers are grouped together pretty closely, far from V-brakes. Nice thing about cantilever brakes is that you can adjust the mechanical advantage some by varying the height of the straddle wire, if you are using one instead of the link wire, which must be swapped for a different one.
ordered some purple cables
