Inner tube size?
Inner tube size?
Old 10-14-19, 12:18 PM
Tranquility
Bikes: Miyata Six-Ten (Men's)
Inner tube size?
Hi There,
I may not have forgotten how to ride my bike but I've forgotten how to size the inner tube.
Can someone please tell me what size inner tube I need to buy for my Miyata 610. I'm including a few pix.
It's been three decades since I've done this so I guess I'm "allowed" to forget.
I've included a few pix of the tires. Thank you!
A friend made me the wheels ~ four decades ago.
Tranquility is offline
Old 10-14-19, 12:42 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,269 Times in 876 Posts
You have a nominal 27" tube. 8mm greater diameter than a 700c.
The boxes usually marked to fit both sizes.
You'd want something around a 622-28.
Bill Kapaun is offline
Old 10-14-19, 01:12 PM
CliffordK
CliffordK's Avatar
Quoted: 18378 Post(s)
Liked 4,512 Times in 3,354 Posts
I agree with @Bill Kapaun.
It is harder and harder to find tubes that are marked only 27", but some are marked for both.
While the tire may be only 8mm larger in diameter than 700c, the tube is about 2.5 cm longer in circumference.
Anyway, the 700c tube should still fit. I don't use 27" much, but I'd probably choose a bit smaller tube (20 to 25mm), and inflate it slightly as installing which will cause it to stretch as much or more in length as in diameter.
CliffordK is offline
Old 10-15-19, 03:10 PM
Miele Man
Quoted: 1324 Post(s)
Liked 927 Times in 640 Posts
1 1/8 = about 28mm. Most tubes today will say on the box the size of tire they're good for. Usually they say 27" x what the width is and 700C plus the width they're good for.
I use 700C tubes in 27" tires without any problems.
Cheers
Miele Man is offline
Old 10-15-19, 04:29 PM
caloso
caloso's Avatar
Quoted: 2952 Post(s)
Liked 3,106 Times in 1,417 Posts
Get a tube marked for 700c 25x28mm (622/28). Make sure you get the right stem too.
caloso is offline
Old 10-15-19, 04:35 PM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times in 422 Posts
Aren't those 27 inch tires on a 700 rim?
trailangel is offline
Old 10-15-19, 06:05 PM
Unca_Sam
The dropped
Unca_Sam's Avatar
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times in 696 Posts
Fine detective work! The pictures posted even show a poorly seated bead.
Unca_Sam is offline
Old 10-16-19, 06:03 PM
Tranquility
Hi Clifford,
So, what would be an appropriate inner tube I could buy on Amazon.ca for example?
Old 10-16-19, 07:13 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
I figured that was because of the flat tire for which he needs a new tube, but I think you guys are right.
The tire looks old, too. Might be worth getting new tires of the right BSD while you’re at it, OP.
ThermionicScott is offline
Old 10-16-19, 07:17 PM
Gresp15C
Gresp15C's Avatar
Quoted: 1062 Post(s)
Liked 665 Times in 421 Posts
Yikes, that's a blowout waiting to happen. This calls for new tires.
Gresp15C is offline
Old 10-16-19, 07:20 PM
CliffordK
CliffordK's Avatar
As far as tire size. Good question
The easiest thing is to measure the rim diameter (top of the brake track). Measure through the spokes, and around the hub the best you can (straight tape).
If the rim is about 640mm (top of the brake track), then it is a 27" rim.
If the rim is about 630mm (top of the brake track), then it is 700c.
Our local co-op has a V made with boards. Simply drop the wheel in to the V, and line it up with the line to tell the size or compare to other wheels.
