Riding with Prescription Glasses / Sunglasses?
Bikes: Fuji Sportif 1.0 LE
Hey guys,
Just registered on the forum and searched but still unclear on the best approach here and looking for opinions. I wear prescription glasses and have clip on sunglasses that attach to the top of the frame (but not very confident in the ability to stay on in in high crosswinds). I just got into road cycling and bought my first bike, I'm now working my way up to a 65 mile ride in about 4-5 weeks.
My question is, for riders with prescription glasses on long rides, what do you wear? Do you wear your normal glasses or do you have special prescription wrap-around type glasses? Do you have special sunglasses that you wear for sunny days? Are they separate and other prescription glasses or do you have some type of clip on or other set of glasses that go on top of your regular glasses?
Any general info or advice would be appreciated or links to products that you would recommend whether they be cheap add ons on specialty prescription glasses.
Thanks in advance!
Thanks in advance!
I've got a pair of Bolle Vigilante's with a prescription insert. I like them because I can easily change the lenses - dark for bright & sunny, amber for cloudy and clear for dark. I got them at Performance many years ago. My local optometrist filled the insert.
Bikes: the bikes own me
Quoted: 18 Post(s)
I wear my regular glasses when I'm commuting. They have transition lenses so they darken in the sun. I need my glasses to read and to see the fine details so I don't really like riding without them anymore.
I purchased a set of clear Rx and sunglass Rx glasses from a well-known online discount glasses provider. Couldn't be happier. The price is so good, I'm considering knock-off transitions from the same place for rides where the Wx changes.
Bikes: Trek Domane 4.3
I wear my prescription sunglasses. I picked up a pair of RayBans a few years ago and can't imagine being without them. They are incredibly comfortable and do the job they are suppose to do.
I have Rudy Project prescription sunglasses. My eyesight is so bad that I have to use inserts as they can't grind the outer lenses enough.
Tip if you need bifocals: Get the cheaper lined bifocals especially if you have to use inserts. With the line-less, progressive bifocals, you are constantly moving your head up and down to focus. Also the peripheral vision isn't so good. With the lined bifocals, you can basically just look down to read your bike computer/map/cue sheet and up to see the road. With inserts the outer lenses hid the dorky lined bifocal.
Bikes: 2006 Raleigh Cadent 2.0, 2016 Trek Emonda ALR 6, 2015 Propel Advanced SL 2, 2000 K2 Zed SE
Quoted: 115 Post(s)
When speeds got to the point where non-purpose built glasses were no longer viable I gave in and spent the money on decent prescription cycling glasses. The shape of lenses requires a bit more technology to get something to work if you have much correction at all, so it's just worth it to get something that will always be good enough.
I didn't want full wrap around, and wanted vents because of the local weather so I ended up getting Oakley Racing Jackets. One eye is just worse than Oakley themselves makes lenses for, so they're custom ground. It's amazing how "digital" prescription lenses are made, they do an unbelievable job of counteracting distortion due to big, curved lenses. I used ADS Eyewear, and their custom lenses ended up being cheaper than the Oakley lenses, and if they're any less bulletproof than the Oakley lenses I haven't seen it. I am not gentle with glasses and they have taken quite a beating in stride.
This. I actually had an older pair that work well for me, and if they fall/break I won't be too upset.
Quoted: 6556 Post(s)
Liked 58 Times
+1 Regular prescription glasses with Transition lenses. My only pair of glasses. Does everything.
Bikes: Salsa Ti Warbird- 2014/ November RAIL52s
Quoted: 67 Post(s)
DUX HELM
Replacement lenses are $40.00 a pop. Visor slides down cleanly over my glasses...
Unlike glasses, the visor will keep crap out of your eyes.
Quoted: 104 Post(s)
Liked 5 Times
I use prescription wrap-around sunglasses with Transitions-brand lenses. Wrap-around style really helps with wind and dust and high-speed descents. Some of the designer sunglass brands are very nice, but much cheaper options are usually available directly from your local optician. There are also online opticians like Sportrx.com that have good reputations.
Bikes: Kuota Ksano. Litespeed T5 gravel - brilliant!
I use prescription glasses but a helmet visor helps. My prescription sunglasses have been in use for over a decade and were a very worthwhile investment. But they aren't cheap and so I wear a eyeglass retainer to save them if they should ever fall off.
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
I got a pair of Rudy Project glasses that accept a prescription insert. That way i can change lenses from clear photo chromatic to solid dark and only need one prescription insert.
Decrepit Member
I use Randolph Engineering frames with cable temple pieces to prevent them from accidentally falling off. They're similar to Ray-Bans, but the rims are a little beefier to accommodate thicker prescription lenses. I have two separate frames, one with neutral grey tinted lenses and one with clear lenses.
Quoted: 741 Post(s)
Liked 412 Times
I wear contacts when I ride. That way, I can use non prescription sunglasses. The curve that is in Oakley and other manufacturers, limits the prescription that can be used.
Quoted: 27 Post(s)
+1 on the Rudy Project (Rydons) with insert. The only complaint I have against them is fogging in winter. The insert makes it impossible to clear the condensation by wiping (without removing the insert). So in the winter I switch to a pair of racquetball specs. No tinting, but then I'm usually riding in the dark, at least part way in the winter.
Oh! If your glasses have replaceable lenses, get a set of yellow. Great for cloudy or rainy days.
Quoted: 27 Post(s)
I have a complaint with my Rydons. The frame where it touches my ears is rather sharp and the frame also touches my helmet. As I move my head, there's a sawing action that was starting to cut into my ears. I had wrap some material on the frame there. I didn't have such a problem with my old RB3s and Exceptions. Other than that, they are great.
Quoted: 115 Post(s)
All that while riding much closer to the face than regular glasses. As someone who has work moderately strong prescriptions for most of their life I was pretty surprised.
My eyes are a bit sensitive to contacts, so my options there are limited. Obviously it'd be cheaper to have nonprescription lenses, Oakleys with prescription lenses cost the same as nonprescription with 3 or 4 sets of lenses. :/
I wasn't stuck on the brand, I just didn't want inserts and that narrows what you can choose from. I don't really want to be seen in those things not on a bike...
Bikes: P1 Domane Di2, SLR Emonda Di2, Trek Farley 9 Fatbike
Quoted: 10 Post(s)
Oakley RX for me, not cheap. Only thing I did wrong was wait two years to bite the bullet. will never go without again.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,173 Times
Oakley RX for me as well. The price is similar to regular glasses with the RX inserts but without all the hassles.
Bikes: 2001 Trek Multitrack 7200, 2104 Fuji Sportif 1.5
Quoted: 18 Post(s)
I bought a pair of Wiley x with the insert lenses, if I'm heading out into a good chance of rain I just wear my normal scrip glasses, the Wiley x and the insert lenses are just too many surfaces covered with water beads :-).
could get Rudy project from one of the specialty shops,would be about $600, maybe next year :-)
On Your Left
Liked 2,433 Times
