Removing free hub
Bikes: Giant TCR Advanced Pro1, Giant TCR Advanced, Cannondale Synapse
Removing free hub
Hi,
This is the first time using the forum so apologies if anything is wrong.
I had excessive play in rear wheel. Stripped down the Maddux R3.0 cup and cone which was definitely a problem. After removing the freewheel, the rear hub was rough and needed to be stripped and cleaned. I've read several books, youtube etc and the only method found is using an allen key. My hub does not appear to be secured in this way. The bore is a plain diameter all the way through. Does anybody have any ideas or is this a fixed unit that can't be removed?
Thanks in advance ....
Thunder Whisperer
Bikes: '06 Kona Smoke
Quoted: 275 Post(s)
Liked 6 Times
Moved from Forum Suggestions & User Assistance.
Community guidelines
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
if it doesn't have a problem, leave it alone... if it does have a problem, replace the hub. there a ton of non-rebuildable freehubs... you may have one of those.... and you can find an entire hub much easier than finding a replacement freehub of exactly the correct type.
Thanks
Thanks maddog34 - I thought I was going mad or missing something really simple. Everything else just referred to removing it with an Allen key no suggestion that it might be non-rebuildable. New hub it is then. Great first trial of the forum - I'll be back !
Quoted: 1074 Post(s)
Liked 295 Times
From what it looks like here:JALCO (MADDUX) Industry Co., Ltd. ********************,????,??,?? Maddux makes rims, not hubs.
So what brand is the hub you're trying to fix?
If you've done the cup & cones, and removed the freewheel, then what are you trying to remove?
Do you mean you've removed the cassette, and now want to remove the f/h body?
Seems unlikely, but not impossible, that you should have a freewheel.
Some cartridge bearing hubs you simply pull the f/h body off.
Hi dabac, good point sorry about the newbie terminology. I have removed the cassette and now need to remove the free hub body. There isn't any branding on the hub but the groupset is a Shimano Tiagra which was fitted to my Cannondale Synapse 2014. So I'm guessing its Shimano.
Quoted: 1572 Post(s)
Liked 643 Times
Sapient
Cannondale Synapse with Maddux rims probably has Formula Hubs, should be a 10mm allen wrench.
Thanks for the advice and replies. I have a 10mm allen key and that just passes straight through the hub. There does appear to be some ridges, which I thought were part of the ratchet system. It could be the ridges that Retro Grouch is referring to. I'll get an 11mm key to see if that works and let you know. Thanks all for the help and advice
My SRAM Freehub requires an 11mm hex wrench/tool to remove. The inside looks like it would require some sort of splined tool but the hex wrench works well. I guess many are 10mm (Shimano type) but mine was 11. It looks very similar to a Shimano though.
Friendship is Magic
Bikes: old ones
Quoted: 26402 Post(s)
Liked 10,374 Times
...it's nice when you get one that is Shimano and 10mm, but there's no universal standard. In general, unless I have one that's pretty standard and easily identified, I find it difficult to find a replacement, so I tend not to mess with those.
Bikes: Gavia Verona. Scott Sportster. Diamant Photon.
Quoted: 43 Post(s)
But, what they really want is to have the end user to buy a new set of the same, often low quality, wheels.
Thanks for all the replies and suggestions. I am pretty sure now it's not a hex key fitting. I bought an 11mm key and it's too big to fit the bore. I'm going to go to a local bike shop but probably not worth paying for a repair when you consider the price of new. Looks like they've won by driving me down the replacement route ....
Really Old Senior Member
7/16"?
