Correct Seat Tube Measurement
Bikes: '72 Paramount 15-9, '74 Schwinn Paramount P10-9, '73 Schwinn Super Sport, 1983 Schwinn Voyageur SP,17 Motobecane Cafe Noir, 1970 Raleigh Competition Tourist, 1999 Rans V-Rex
Quoted: 220 Post(s)
Liked 83 Times
I picked up an old Jetter bike for $3.00 because I liked the paint. Trying to find a seat tube.
Seat tube OD = 32.9m or 1.295"
Seat tube ID = 25.4mm or 1.0"
What diameter seat post am I chasing?
Thanks!
Thanks!
Quoted: 790 Post(s)
Liked 1,767 Times
If it's an older high ten frame set the seat post size is mostly likely 25.4mm which was the most common size on these. This seems to match your measurements if there's a coop or friendly bike shop in your area you can get them to verify the size and pic up a basic post for $5-10.
Quoted: 4722 Post(s)
Liked 3,036 Times
I wouldn't even consider that hi-tensile steel. 3.75mm is an incredibly thick tubing wall, unless the OP is advertently measuring the lug outer diameter, as opposed to the seat tube outer diameter. Normally, there would be about 0.2mm diamterical clearance between the tube and post,suggesting a 25.2mm post. However, that would be rare. More likely, it it uses the very common 25.4mm and the seat tube is measauring slightly under it's true nominal diameter due to distortion, pinching, corrosion, etc.
Quoted: 220 Post(s)
Liked 83 Times
Thanks!
