Non-Bike Use for Bike Parts...Waddya Got ?
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
How about a presta tubed wheelbarrow. The tire was flat, so I had a presta 26" mtn bike tube, inserted it in a "figure 8", and pumped it up. The tire's lumpy from uneven tube distribution, but good enough for moving weeds and wood chips.
Likes For Homebrew01:
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,865 Times
I don't know if this counts as a "use" or not, but a friend made this "steampunk laser gun" for my wife, incorporating a set of Campy shifters he found at an antique shop.
My Bikes
My Bikes
Likes For Andy_K:
Quoted: 964 Post(s)
Liked 1,451 Times
Home-built a crossbow as a teenager, pull weight was 200lb so I couldn't pull it back by hand, so I incorporated a BB shell and crank as a winch. Or as a proper medievalist would call it, a cranequin.
Likes For scarlson:
Bikes: Indeed!
Quoted: 1506 Post(s)
Liked 3,463 Times
Choke Lever on Bruce Gordon's custom Vespa that my son is restoring.
Brent
Brent
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
I used to keep a LH crankarm in a rear rack bag between the seats in my old truck, in case I needed a cudgel for any reason.
Non omnino gravis
The 16" wheels+tires from the 2-kid trailer I used to tow my kids to school in are now on my Swisher walk-behind string trimmer. They slipped right on. Same axle size and everything.
I repaired the neighbor's lawn mower with old shift housing, a Jagwire MTB brake cable, and the fixing bolt from a terrible Bengal mechanical disc caliper.
I have some drawers in my workshop that use old Trek aluminum water bottle cages as handles.
Quoted: 18353 Post(s)
Liked 4,502 Times
Hmmm... I'll have to go take some photos, and hunt down other photos soon. I burnt up my Fiat 500 Starter Motor Cable long ago, and it has been replaced by a bicycle brake cable. Occasionally needing replenishing as the drilled bolt cuts through it.
I've also used brake and shifter cables as wires for picture hangers, been doing that for eons.
I've got to have a few more bike parts around here.
Spokes can be as versatile as wire hangers.
The Bike Coop has a set of 16" or 20" wheels that they use for the reusable tags for their bike valet. Clip the tags to the spokes in the wheels when not in use, then clip one to the bike, and give one to the customer when the bike comes in.
I didn't do the config, but my powder coat booth uses a wheel like a steering wheel to allow the powder coating rack to be turned.
Bike related, of course, but my heavy hauler trailer uses two 16" Schwinn OCC wheels.
I bought this bird feeder a while ago. I'm considering whether I want to keep it as a bird feeder, or restore it as a bike wheel.
...addicted...
Here's a rear derailleur, chain, and large cog from a mid '90's kids mtb that my dad and I installed on the oiler servicing the Nasal 3B powerhammer in his blacksmith shop.
Likes For rocks in head:
Liked 2,446 Times
I used Presta valves on a plumbing project about 30 years ago. Replumbed one end of the house and had to pressure test the hot and the cold lines before going live so drilled the copper caps to fit valves removed from tubes and capped the 1/2" copper supply lines and pressurized to see if they would hold overnight and they did.
seńor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3870 Post(s)
Liked 6,461 Times
I've never used them (knock wood), but I have two bludgeoning tools at the ready. The mace, a long and gnarly mtb seatpost, is near the bed. And the battle axe, a Campy GS drive side crank arm, is hanging on the kitchen wall.
Quoted: 796 Post(s)
Liked 746 Times
I have to admit I've swung around a crank with a single chainring attached and thought it'd make for a good weapon in a bad situation.
Liked 2,446 Times
Likes For thumpism:
Shifting is fun!
Bikes: Yes, please.
Quoted: 2193 Post(s)
Liked 4,587 Times
Shimano shifters, kept my cheap lawn mower alive for another four seasons or so:
Likes For non-fixie:
car dodger
1989 Schwinn Paramount OS
1980 Mclean/Silk Hope Sport Touring
1983 Bianchi pista
1976 Fuji Feather track
1979 raleigh track
"I've consulted my sources and I'm pretty sure your derailleur does not exist"
1983 Bianchi pista
1979 raleigh track
Likes For norskagent:
small ring
Quoted: 437 Post(s)
Liked 925 Times
chainring picture hanger
72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
Likes For droppedandlost:
Quoted: 3803 Post(s)
Liked 3,324 Times
Liked 3,324 Times
now i wouldna wish to get in the way of a quarrel from that thing!
do you have a collection of arbeletes?
as a youngin' had an x-bow with a draw weight of eighty lb nominal - that were eno' (!) it was strong eno' to cause the trigger/latch mechanism to fail - excite-a-mente it were...
Liked 3,324 Times
forum member @1simplexnut posted these images from Aotearoa in another thread.
they show a jogging/cycling path created from a disused rail line.
along one stretch of the path a fence of sorts has been fabricated made of derelict cycles.
Quoted: 964 Post(s)
Liked 1,451 Times
I used to! Powered by all manner of things, from ganged rubber bands (first iteration) to inner tubes to trampoline springs. I also had several trebuchets and mangonels, one of which was wrist-mounted like a slingshot but more accurate. I was an absolute terror to my neighbors as a child. This was the king of them all, made from a truck leaf spring, and the only survivor from my collection. It was (and still is) slightly scary to shoot, but the trigger's a rolling-nut good for 500lb I think. The cranequin could pull that as well. The first bolts/quarrels I fletched up were too weak and split down the middle when I shot them, both halves taking diverging trajectories with a mist of splinters flying generally downrange! These days I shoot with Harvard Archery Club. They "get it" when it comes to homebuilt bows.
Likes For scarlson:
Old kids bike with a 26" wheel in the seat post as wine glass holder. The handlebar now also had Edison style bulbs.
Likes For Harhir:
I'll often use the little leftover scraps of bar tape to tape handles of other varieties. For instance that way, I can feel like I'm cross training when mowing the lawn.
Likes For Bianchi84:
Likes For Glennfordx4:
Insane Bicycle Mechanic
Quoted: 797 Post(s)
Liked 694 Times
I found an extra-crappy MTB wheel abandoned on the I-205 bridge one day. A little shopping at the hardware store, some pop-rivets, and a post sunk in concrete later... artsie-fartsie windmill:
Jeff Wills
Jeff Wills
Likes For Jeff Wills:
