Raliegh SB1799 Team Issue repaint
Quoted: 1142 Post(s)
Liked 1,739 Times
I am in progress of painting Raliegh Team Issue frame #SB1799 and I have a question for some that has a TI.
What are the measure of the black and yellow bands?
Thanks!
Thanks!
Quoted: 1829 Post(s)
Liked 3,375 Times
A few quick measurements...
1. the black section is 7 5/16" long
2. the lower yellow section is about 49mm long.
3. The little black/white/black band that hides the red/yellow boundary is about 5 or 6mm wide.
4. On my 60cm frame, the lower yellow section starts about 6.5" above the top of the BB shell
5. the upper edge of the upper yellow section is about 4.25" below the top of the seat lug (on a 60cm frame)
Steve in Peoria
Steve in Peoria
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,600 Times
steelbikeguy, just out of curiosity, what are the criteria for switching between imperial and metric measurements?
Likes For non-fixie:
mycocyclist
Quoted: 910 Post(s)
Liked 812 Times
Out Of Sight
It's known as
"Hubble-ing".
Shifting is fun!
Bikes: Yes, please.
Liked 4,600 Times
Thank you! I had to look that up. I assume that, as long as the OP is not taking that Ilkeston vessel into outer space, he'll be fine.
Liked 3,375 Times
Looking back on it, it appears that the band dimensions were based on inches, which seems reasonable for the early 80's in an English bike factory.
I'm also assuming that the C&V crowd can convert from mm to inches and back with hardly a moment's hesitation.
Steve in Peoria
Shifting is fun!
Bikes: Yes, please.
Liked 4,600 Times
to be honest, I generally default to metric, but the 6" calipers just weren't going to work for some of that stuff.
Steve in Peoria
Steve in Peoria
Liked 3,375 Times
Likes For steelbikeguy:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,796 Times
I prefer to measure in parsecs.
Bikes: The keepers: 1958 Raleigh Lenton Grand Prix, 1968 Ranger, 1969 Magneet Sprint, 1971 Gitane Tour de France, 1973 Raleigh Tourist, 3 - 1986 Rossins, and a '77 PX-10 frame in process.
Quoted: 221 Post(s)
Liked 237 Times
Syke
“No one in this world, so far as I know — and I have searched the records for years, and employed agents to help me — has ever lost money by underestimating the intelligence of the great masses of the plain people. Nor has anyone ever lost public office thereby.”
H.L. Mencken, (1926)
Syke
Liked 5,796 Times
The guy who owns this website has performed probably the most detailed evaluation from analysis of more than 800 SBDU frames. The size, type and placement of decals changed over the years, including the seat tube bands.
An example of the differences:
Even though you didn't ask about the top tube decal, and maybe you already know this, but your bike is from 1977 and the top tube decal should read "Team Raleigh" rather than "Team" as shown in the first photo posted. The down tube transfer is also different I believe but Neil's website should have every detail you need if you're that way inclined.
Good luck with the restoration. I'd love to be doing what you're doing.
SBDU Ilkeston SB Frame Transfer Layout and Lug Detailing for TI-Raleigh Restorations (1974 – 1983)
https://raleigh-sb4059.com/2018/01/06/sbdu-ilkeston-sb-frame-transfer-layout-and-lug-detailing-for-ti-raleigh-restorations-1974-1983/An example of the differences:
Likes For old_dreams:
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
Liked 1,739 Times
Omg, raleigh-sb4059.com is a firehose of information. @old_dreams thanks for posting.
By any measure I've made some progress, I primed with grey 2k epoxy, did a couple of spots of fill with J&B weld. Then I did a second coat of epoxy prime, this time beige. I then masked for the black, and painted. The black paint is 2k epoxy flat black hotrod.
Liked 1,739 Times
I did go the the local paint outlet and had a match of the red mixed, I've got a full quart of that with a quart of reducer so I've got enough paint of a couple of frames+. To go along with the red I got a can of 2 stage clear coat. I haven't picked up the yellow yet.
Here is the black unmasked as well.
Quoted: 786 Post(s)
Liked 520 Times
Nice work. I appreciate your nice lug pics. Such fine workmanship on these bikes. So are you doing the black from a rattle can, and red from a gun?
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,832 Times
Likes For Wildwood:
Shifting is fun!
Bikes: Yes, please.
Liked 4,600 Times
Nice! Looking forward to the final result.
Liked 1,739 Times
Sometimes I forget I'm a highly trained graphic artist with a lithographic background. The masking above and below is the kind of hand work I used to do everyday.
Reverse masking the details is not difficult either. The detail is lightly taped over, etched here with pencil, pulled, cut just under sized, checked for fit, adjusted and placed lightly pressed on the edge to prevent seeping.
Likes For Mr. 66:
Liked 1,739 Times
Not much more for progress, but I did get the yellow paint yesterday so I decided to mask for it. I may paint today, unfortunately I need to set up a new booth and locate my real respirator and get gun ready.
Likes For Mr. 66:
Quoted: 786 Post(s)
Liked 520 Times
Nice work. If you are into lug masking porn, you should follow Chapman Cycles on Instagram.
Likes For jeirvine:
Quoted: 4233 Post(s)
Liked 2,948 Times
Cool. Can't wait to see it done.
Likes For himespau:
Liked 1,739 Times
https://www.instagram.com/p/B9pGYJDFMTt/
I did make some progress yesterday the yellow is laid. Red paint coming soon.
I decided to detail my helmet also.
Likes For Mr. 66:
