Chrome Raleigh Pro Mk.IV: Ticking time bomb?
www.theheadbadge.com
Quoted: 2420 Post(s)
Liked 4,381 Times
Liked 4,381 Times
One more point - if this was being done commercially and with some regularity by a plating shop for a bike shop, I would bet the baking would have been done. The default would be to bake it.
Why are you concerned it wasn't baked? Is it because you don't have a record of the bake out?
Just so happened that this one and a few others seemed to be pretty well executed.
-Kurt
Quoted: 938 Post(s)
Liked 2,920 Times
All indications are that it was chromed later. Seems like the Mark I was only produced in white with Ruberg stripes even though earlier incarnations had chrome socks. I got the frame on the Classic Rendezvous list, 1970 "E" Serial. It had a Turin shop sticker on the head tube covering the holes from the original headbadge. The previous owner (not original) knew some people who knew some people that contacted the owner from the era to ask if they remembered anyone having them send out a Mk. I for chroming, but nothing came of it. It's a well-executed job. Smooth, slick, hardly any flaws or signs of wear or discoloration. A Raleigh Anniversary headbadge fit perfectly in the holes. It's a great frame, from the first ride it felt familiar as if I'd had it since new.
Your chrome plated frame looks fantastic, too. From what I can see in the photos, it looks as if some care was taken.
If I find some time, and if I remember, I will do more research on annealing hydrogen embrittlement. I have more resources at my employer. I might even be able to talk to some plating specialists. We have a cadre of PhD materials scientists & engineers who's work supports the plating shops.
It surely would be nice to be able to ride it with confidence, no?
I do not want to get your hopes up but if I get some info, I will pass it along to you.
Likes For Bad Lag:
FWIW, the higher the strength the more susceptible the steel is to hydrogen embrittlement. Reynolds 531 or Columbus SL are not high strength steels. A quick search shows 531 has a yield strength of ~50 ksi and a tensile strength of ~130 ksi. This is less than HRC 30 hardness and the steel is highly ductile. Generally below HRC 30 the susceptibility for hydrogen embrittlement, though not zero, is not considered high risk. Certainly for high stress applications (i.e. aerospace) baking would be required and if memory is correct, bake is built into the AMS plating spec (don't quote me on this one). I don't know anyone that works/worked in a production bicycle manufacture environment so have no idea if they would require a bake or not. I'll bet they didn't always do it, if at all, but that is just a best guess. Certainly something like 853 would require baking as its strength is significantly higher than good old 531 or SL.
You could bake the frame and fork at 325 F for a couple of hours, the chrome may oxidize a bit (start to turn blue), but can probably be buffed out, if it make you feel better.
Overall though the risk isn't zero, but it isn't that high, so I'd build and ride as it seems like the bike shop used this chrome plater for years.
Also inspecting for cracks is hard as this is not a fatigue type of cracking, that is crack initiates and grows relatively slowly (though I would as others have said carefully look at the bottom bracket shell and fork). When it cracks it just cracks or pops, which doesn't mean it breaks into 2 or 3 pieces and you crash.
Just some thoughts on steels and chrome platting and risk.
Liked 4,381 Times
