Why was Chromoly phased out?
#151
Quoted: 4227 Post(s)
Liked 2,488 Times
Aluminium can be very durable...I have a 13 year old aluminium framed MTB with a rigid steel fork and the frame is still solid, despite all the abuse and hard riding....Airplanes are also made out of aluminium.
#152
"How can we make bicycles that have a limited durability factor?" "Aluminum." "Take the squishy material used for beverage-packaging and turn it into bicycle frames/forks." "Brilliant!" Relegate bicycles to recreation. Save the steel for the cars, which bicycle riders will still need to buy for tasks that would've otherwise been possible on a bicycle, had the frames/forks been able to accommodate cargo racks/baskets. Don't include a chainwheel guard, gotta have people wearing tights, to reinforce the notion that riding a bicycle has limited usefulness. "Sounds great!"
#153
QR-disc must die!!!
Bikes: '99 Trek 520, '20 Kona Sutra (FOR SALE 48cm), '21 Simon-Bikes mini-velo and a chromoly-framed folding bicycle with drop-bars and V-brakes, that rolls even while folded.
Quoted: 397 Post(s)
Liked 199 Times
Aluminum frames can be more durable than steel or titanium. Durability and longevity depend entirely upon design geometry and quality control of welds.
#154
Oh and I also have two aluminum-framed motorcycles that endure far greater stresses than any bicycle which have gone over a hundred thousand miles without any stripped threads or stress failures. The material is about as sound as you can get from an engineering perspective.
#155
QR-disc must die!!!
Quoted: 397 Post(s)
Liked 199 Times
I've never had any issues with bottom bracket threading on my aluminum bike frames. and there are millions of aluminum engine blocks out there that make hundreds of horsepower dependent entirely upon the strength of the threading that holds the cylinder heads in place. While correct torque specifications are arguably more important in aluminum threading than steel, the resultant mechanical fastening can be just as robust as if you were threading into steel.
#156
Never had any issues with my rack bosses over the past decade of heavy rack usage on an aluminum frame. Again, proper torque spec is key. Once it's torqued down with some blue loctite, it's set it and forget it.
#157
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
#158
Mad bike riding scientist
Quoted: 6218 Post(s)
Liked 4,217 Times
Stuart Black
Stuart Black
#159
Tragically Ignorant
Liked 9,098 Times
#160
Are there any chromoly hardtail 29ers that use replaceable derailleur hangers (let's say around the thousand dollar range)? Most steel alloy bikes I come across, haven't seen any of them with replaceable derailleur hangers. Wonder why.
#161
Quoted: 671 Post(s)
Liked 49 Times
I got a bit turned off against aluminum racks after I found a pannier attachment strap had actually gouged a notch in the rack. OTOH I haven't experienced things wearing into alu frame tubes; clamping accessories onto alu handlebars doesn't seem to cause damage.
#162
Liked 4,217 Times
All of Salsa’s line uses replaceable hangers. Even on steel bikes (the few made), replaceable derailer hangers are a good idea.
Stuart Black
Stuart Black
#163
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
#164
SE Wis
Liked 3,390 Times
FWIW here is a repair on a steel Lotus frame of Tange Champion tubing that broke at the bottom bracket. In addition, a gusset tube was added to reinforce.
Done by a motorcycle repair shop. Done about 10 years ago, as afar as I now the bike is still on the road
#165
Slowpoke
I won't buy anything but a steel bike with a steel fork. My #1 is 2019 steel gravel bike. Plenty of steel offerings out there from bigger companies like Kona, to tons of smaller builders. Steel IS real.
#166
Bikes: MBK Super Mirage 1991, CAAD10, Yuba Mundo Lux, and a Cannondale Criterium Single Speed
Quoted: 344 Post(s)
Liked 297 Times
It's a meaningless catchphrase that is intended to suggest there is something synthetic to aluminium or titanium, or that carbon fiber is really plastic. it's an effort to position steel as the "organic" material of choice.
#167
Liked 4,217 Times
In a less “religious” context, it was coined back when aluminum bikes started to come on the market to disparage aluminum. It’s meant in the manner as “real bicyclist don’t ride aluminum”. The saying is likely 40 years old by now and is the cry of people who have seen the market share of steel bicycles erode to the point of being a blip in the bicycle market. At this point it is a nostalgia sentiment.
Stuart Black
Stuart Black
#168
Tragically Ignorant
Liked 9,098 Times
It means "aluminum, carbon and titanium are really hard to rhyme.".
" Steel is teal" didn't catch on, however.
Likes For livedarklions:
#169
Quoted: 722 Post(s)
Liked 353 Times
I'm not very educated on the subject but I've noticed that I rarely, if ever, see Chromoly frames offered on new bikes these days. Is there a specific reason that it isn't used anymore?
I'm asking because I have a 1999 Specialized Crossroads with a Chromoly frame and I'm curious why the material isn't used much anymore.
but ride quality is wonderful.
#170
Liked 4,217 Times
Stuart Black
Stuart Black
#171
Generally, it is a dig at aluminum. In the minds of the Holy Steel Warriors, aluminum...the metal of the infidel...is soft, weak, and “shatters at the slightest impact” or, in the bicycle vernacular, “it asplodes”. It is not even worthy of the title “metal” in their eyes...even as those self same Holy Steel Warriors take weight off the steel by using aluminum in other critical places.
You use steel spokes though. Why not aluminum? They should be better right?
#172
Quoted: 2482 Post(s)
Liked 2,952 Times
With all that you still have the audacity to write that you do not put down people who ride or are fans of steel bikes. Their arguments do not matter because they're religious zealots? Cool beans.
By the way, SpeedofLite recently posted a PDF from a Bicycling Magazine article titled Road Test/Bike Review (1983) CANNONDALE Touring Bike.
The reviewers agreed that they thought highly of the Cannondale touring bike in many regards, including comfort.
Likes For Trakhak:
#173
Quoted: 3352 Post(s)
Liked 1,056 Times
Its MONEY people. The absolutely beautiful brazed lug frame went out of style because of money!!! It is cheaper to throw tubing into a fixture and have a robot weld them. This goes for both steel and aluminum.
But then we also have the carbon frames. The manufactures have brain washed the "real cyclist" into thinking they HAVE TO HAVE a carbon frame. Once again it is money. The manufactures can contract with some company in China that pay poor Chinese women to lay up a carbon frame, paying her probably 75 cents an hour. Thru channels they end up in you local bike shop and sell to the well heeled for $5000 and up. Money money money!!!!
I would really like to know just how much it cost a bike company in China to lay up a carbon frame bike. I would be willing to bet it is not very much.
#174
Liked 4,217 Times
I have not put down anyone...well, not put down anyone who didn’t start the put downs. You have made similar arguments towards aluminum that are equally as baseless. Aluminum has proven itself as a tough material capable of withstanding the (rather minor) rigors of bicycling over the last 40 years.
And for your “yabuts”, I never said that steel doesn’t have its place. I just said that aluminum has its place as well.
Stuart Black
Stuart Black
#175
Liked 2,952 Times
I've seen at least one wheel with aluminum spokes. The Hi-E company used to bring wacky designs to the bike industry trade show, and that was one of them. As I recall, it had something like 30 individual spokes, but each spoke ran continuously from a nipple on one side of the wheel through the hub and to another nipple on the other side of the wheel.
