Can't locate clicking sound
Old 07-06-20, 11:05 AM
krecik
Quoted: 137 Post(s)
Liked 86 Times in 54 Posts
krecik is offline
Old 07-06-20, 03:14 PM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Quoted: 986 Post(s)
Liked 880 Times in 527 Posts
The OP seems to have vanished. Either he's solved his issue, or the diversity of answers from the BF crowd made his head spin.
Moe Zhoost is offline
Old 07-07-20, 06:20 AM
dkbiker
Hi All
First, thanks for all the answers and I am sorry for waiting so long before answering. I have been away on a little holliday, so I could not test the bike. There is a lot of good suggestions, and I have summed them up here:
Saddle/seatpost noise
Testet when standing in the pedals without touching the seat/saddle. The noise still appears. So, I guess it is not the seat.
One legged pedaling
I have tried pedaling with one leg at the time, and the sound appears with both legs.
Clipless pedals
I use flats and tried changing to clipless. Same sound appears with both pedalsytems.
Kickstand
No kickstand mounted.
Stem/bar
The stem/bar is built in one piece with the cockpit. So theres no separate stem. But maybe I should try to remove the cockpit and reapply grease when mounting.
Ice cubes clinking in your water bottle
Hehe good one. But theres no bottlemount.
Crank arm to the spider
Removed it and applied grease. Same problem.
Spoke intersection
Applied grease to all intersections. Same problem.
Does it click in all gears? Both rings?
Yes, all gears both rings, same "volume" and frequency in all gears..
Check the chain
Changed the chain. Same problem.
Excess front derailleur cable
Theres no excess cable.
Things I need to try out the coming days:
Try to remove the cockpit and reapply grease when mounting
Wheel/quickrelease reapply grease
Rear derailleur remove parts and clean properly.
Does it click if you pedal backwards?
Does it click if stationary, brakes applied, pressure on pedals? I will try it in a hometrainer, and see if I can make the same sound.
Tube valve stems rattling in an alloy rim hole
Change the bearings if they are separate from the bottom bracket.
Bottom bracket
Replace cassette
Again, thanks for all the good suggestions. I will let you know when I have testet some more.
Have a great day, and what a wonderful forum you have here !
dkbiker is offline
Old 07-07-20, 06:56 AM
Outrider1
Outrider1's Avatar
Bikes: Trek Emonda ALR 5
Quoted: 159 Post(s)
Liked 301 Times in 140 Posts
Originally Posted by fishboat
Change out your bottom bracket..I'd guess your sound will disappear. Mine did.
This
Outrider1 is offline
Old 07-07-20, 11:04 AM
Miele Man
Quoted: 1324 Post(s)
Liked 927 Times in 640 Posts
Loose chainring bolt or bolts?
Cheers
Miele Man is offline
Old 07-07-20, 11:33 AM
caloso
caloso's Avatar
Quoted: 2952 Post(s)
Liked 3,106 Times in 1,417 Posts
One time I had a mysterious clicking sound that only occurred while pedaling. Turned out it was the FD cable crimp hitting the crank arm. Duh. The clue should have been that only happened when I was in the small ring.
caloso is offline
Old 07-19-20, 07:48 PM
sovende
Bikes: TNTL (Too numerous to list)
Quoted: 184 Post(s)
Liked 147 Times in 115 Posts
I'm going to vote with those that suspect the bearings in the bottom bracket 👍. I'm experiencing a similar noise on one of my bikes. It only reveals itself when increased force is being applied to the pedals i.e. accelerating an/or climbing. It doesn't occur with every stroke but can occur with the power stroke on either pedal. I'm guessing dings in the bearing cup and one or more of the bearing balls too. When a bad bearing ball hits the ding in the cup, it "clicks". I'm going to disassemble the bottom bracket bearings and have a closer look. I may replace with a sealed unit 👍 if I don't see any obvious damage.
sovende is offline
Old 07-20-20, 12:22 PM
bblair
Bikes: Lynskey R230, Trek 5200, 1975 Raleigh Pro, 1973 Falcon ,Trek T50 Tandem and a 1968 Paramount in progress.
Quoted: 379 Post(s)
Liked 394 Times in 233 Posts
Many years ago, similar frustration with similar rebuilding.
Turns out it was the aglet on my shoelace hitting the bike on each revolution. Felt stupid.
bblair is offline
Old 07-20-20, 01:08 PM
BlazingPedals
BlazingPedals's Avatar
Quoted: 1513 Post(s)
Liked 734 Times in 455 Posts
Gets my vote too as most likely. Remove, lube all interfaces/threads/splines lightly, then reassemble.
BlazingPedals is offline
Old 07-30-20, 08:09 AM
sovende
Quoted: 184 Post(s)
Well, my decision to disassemble, assess & repair or replace as necessary just got moved from "might do when I find time" status to "I have to do before the bike is ridden again" status 😳. While out riding yesterday, the "clicking" noise that had been occurring occasionally during the "power stroke" changed to a "grinding" noise occurring during the full rotation of the crank while under load 😬. Not a good sound, to be sure!
Unfortunately, I was about 15 miles from home! The grinding started while climbing a relatively short, shallow rise and diminished greatly once I reached the crest. I considered making a "call of shame" but decided that since damage, probably requiring replacement of most bottom bracket components, had most definitely occurred, I would "limp" home barring a complete lock up of the crank. Whether or not that was a good decision remains to be seen 🙄.
In a perfect world, the bearing surfaces of the spindle and the bearing cups have been spared and I'll only need to replace the ball bearings 🙂. I'm guessing tho that this is NOT a "perfect world" situation and full replacement (with a sealed unit) may be my best option. As mentioned at the start of this reply, the issue has been elevated to near the top of my "to-do" list. More to come 👍.
sovende is offline
Old 07-30-20, 02:40 PM
BlazingPedals
Measure your spindle and get a sealed unit. They're inexpensive and they last a long time. Without yearly maintenance.
