Frame pump with flexible valve
Old 08-12-20, 06:52 PM
TheCharm
Bikes: 2015 Surly Disc Trucker & 2011 Trek 7.3fx
Quoted: 13 Post(s)
Liked 9 Times in 4 Posts
Good day:
I carry a Zefal HPX-4 frame pump on my Disc Trucker as depicted here. I'm looking for a similar frame pump with a flexible length of hose for the valve connector. This pump just affixes to the valve step. It's rigid and (knock wood) it's only happened once where I wasn't minding my aggression and I snapped the valve stem as I was filling a tube after a flat. Whoops. I always carry at least two tubes so I was good, but I'm just looking to mitigate the risk.
My bike has Presta valves, but I'd like the ability to swap to Schrader, as I often stop trailside and help folks get going again and I like options.
I carry a Road Morph on my other bike and it's fine pump, but I'm looking to see if I can find anything that fits on the nub that's underneath my top tube. My top tube is around 550mm, FWIW.
If there's a better forum to solicit ideas on this, let me know. But bike wrenches usually have a good, broad view of what's out there.
TheCharm is offline
Old 08-12-20, 07:16 PM
shelbyfv
Quoted: 1810 Post(s)
Liked 1,182 Times in 672 Posts
IMO you won't find a better frame pump than what you have. To prevent damaging the valve, position it at the top of the wheel and stabilize the wheel, valve and pump with one hand, operate the pump with the other. I don't have a pump peg so I use a Lezyne mini pump with a hose. The hose presents it's own set of problems because it threads onto the stem. Sometimes the valve core will loosen as the hose is unscrewed.
shelbyfv is offline
Likes For shelbyfv:
Old 08-12-20, 07:35 PM
sean.hwy
Bikes: Topstone AL 105 / SystemSix Carbon Ultegra
Quoted: 89 Post(s)
Liked 53 Times in 40 Posts
I have fixed a few flats on the side of the road with LEZYNE Sport Drive HV Bicycle Hand Pump. Works great.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
sean.hwy is offline
Old 08-13-20, 02:09 AM
TheCharm
Quoted: 13 Post(s)
OK, got it. It is a nice pump - seems to move a decent amount of air. I typically run my tires around 65-70 psi and never have any trouble getting them up to pressure. If I'm using this trail or roadside, I'm fixing a flat and typically pump it up before I put it back on the bike. But maybe that will be a necessary step to mitigate the risk of a snapped valve.
TheCharm is offline
Old 08-13-20, 05:35 AM
shelbyfv
You don't need to put the wheel back on the bike. I probably didn't describe it properly. Hold it however is comfortable and you can get a solid grip on everything.
shelbyfv is offline
Likes For shelbyfv:
Old 08-13-20, 06:09 AM
commo_soulja
commo_soulja's Avatar
Bikes: are fun to ride
Quoted: 24 Post(s)
Liked 19 Times in 14 Posts
Lezyne mini pumps FTW - flexible swappable (Presta/Schrader) head that lives conveniently in the pump with a way smaller footprint of your old school baton frame pump. Comes in either HP or HV so select based on your intended use. They're the only mini pumps I use now and I've had many since the 90s. Avoid the digital pressure gage versions - those tend to crap out after a while. Stay analog!!!
commo_soulja is offline
Old 08-13-20, 06:41 AM
HillRider
Bikes: '''96 Litespeed Catalyst, '05 Litespeed Firenze, '06 Litespeed Tuscany, '12 Surly Pacer, All are 3x8,9 or 10. It is hilly around here!
Quoted: 1438 Post(s)
Liked 260 Times in 209 Posts
That is exactly the problem I ran into using my Lezyne Road Drive mini-pump. After 150 strokes to get reasonable pressure, unscrewing the hose also unscrewed the valve core and both it and all the air came out. GRRRRRR. Otherwise it's a good, well made pump.
For me the optimum combination is a mini-pump used to do the initial inflation to say 20 psi just to assure the tire is seated and the tube holds pressure. Then I use a 16gm threaded C02 cylinder with a screw on valve head to bring the tire to full pressure. Much less work and no threat to the valve stem. Those cartridges are obscenely expensive if bought at a bike shop but not bad if bought in boxes of 20 or so from Amazon. My mini-pump, the CO2 valve and three cartridges weigh less than a Road Morphe.
HillRider is offline
Likes For HillRider:
Old 08-13-20, 06:55 AM
aggiegrads
Quoted: 191 Post(s)
Liked 102 Times in 75 Posts
I found that the trick is letting the pressure out of the hose. The newer versions from Lezyne have a bleed valve, but you can achieve the same effect on most models by unscrewing the hose from the pump first and then unscrewing the hose from the valve.
I really like the valve on the Silca Tattico, but it doesn’t do Schrader valves.
aggiegrads is offline
Likes For aggiegrads:
Old 08-13-20, 08:21 AM
Pop N Wood
Bikes: 1982 Bianchi Sport SX, Rayleigh Tamland 1, Rans V-Rex recumbent, Fuji MTB, 80's Cannondale MTB with BBSHD ebike motor, 70's vintage Schwinn Continental and Suburban
Quoted: 219 Post(s)
Liked 163 Times in 109 Posts
I've never used one but Lezyne also makes frame mounted "floor pumps" with screw on hoses
https://www.backcountry.com/lezyne-m...xoCks4QAvD_BwE
By the way, on that Zefal pump I grab the base of the pump with my left hand than loop my thumb over the top of the tire. That not only prevents shear forces on the stem but it allows pushing the stem out of the rim hole to get a better grip.
Pop N Wood is offline
Old 08-13-20, 08:29 AM
HillRider
Mine has the bleed button but that didn't help. The threaded chuck still caught the valve stem and unscrewed it completely.
Old 08-13-20, 08:51 AM
_ForceD_
_ForceD_'s Avatar
Bikes: Several...from old junk to new all-carbon.
Quoted: 600 Post(s)
Liked 144 Times in 95 Posts
I had the same problem, breaking stems, with traditional static-head frame pumps. Then I saw this Schwinn pump in a department store and thought I'd give it a try. The head/hose retract into the pump piston rod. The head is both Schreader and Presta. No more broken stems, and I'm able to pump a road bike tire up to desired psi. I wish I had gotten several of them...one for each bike. I've never seen them again, and can't find it on the interwebs. There are no other identifiying markings on it...i.e. part number, etc...just the SCHWINN name.
FWIW...I have also made my own extension hoses using a Schreader-Presta adapter, the the Presta valve stem from an old tube...and some good glue that have worked. But, broken valve stems is also part of the reason why finally started carrying a CO₂ inflation system with me.
Dan
_ForceD_ is offline
Old 08-13-20, 09:33 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,278 Times in 798 Posts
BITD We Hung the wheel from the pump with valve at 12:00 so not pushing the valve stem sideways
the pump head can have something behind it..
A more careful technique can be learned..
fietsbob is offline
Old 08-13-20, 10:42 AM
davidad
Quoted: 441 Post(s)
Liked 65 Times in 59 Posts
I have good luck with this one and it is repairable when necessary(once in 20 years).
https://www.topeak.com/us/en/product...-morph%C2%AE-g
davidad is offline
