Are certain pads and rotors not compatible?
Old 08-13-20, 07:16 PM
Ryan_M
Ryan_M's Avatar
Bikes: 2020 Giant Roam 1... at least it was
Quoted: 11 Post(s)
My stock brakes were MT200 with B01S pads and Tektro TR160-2 rotors. I upgraded the brakes to M6000 with J03A pads but I kept the tektro rotors for now. They squeal like crazy! I took it apart and resurfaced and cleaned the rotors and pads and no difference. I put the B01S pads back in and total silence. Before I contact the seller who sold me the brakes is there a possible incompatibility with the new pads and existing rotors?
Ryan_M is offline
Old 08-13-20, 07:26 PM
aggiegrads
Quoted: 191 Post(s)
Liked 102 Times in 75 Posts
Once you have used one type of pad on a rotor, you need to stick with that type of pad.
If you change the pad type, you should change the rotor as well.
aggiegrads is offline
Old 08-13-20, 07:35 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,278 Times in 798 Posts
I changed pads from semi metallic to organic compound and kept the discs.. the wet squeaking stopped..
changed front from Avid caliper to TRP Hy Rd.. kept the disc.
so it's a matter of opinion more than fact...
Using bedded in pads vs new that you did not do the bedding in preparation ?
fietsbob is offline
Old 08-13-20, 07:41 PM
Ryan_M
Ryan_M's Avatar
Quoted: 11 Post(s)
They're both shimano resin though. Might be different compounds though. However, I resurfaced both so that would remove any bedded in material from the old pads. Shouldn't it?
Ryan_M is offline
Old 08-13-20, 09:59 PM
aggiegrads
Quoted: 191 Post(s)
Yeah, sorry, i thought the two pads were different materials. Different compounds could presumably cause the same problem.
Old 08-14-20, 12:12 AM
Amt0571
Bikes: Canyon Grand Canyon AL SL 8.0, Btwin Ultra 520 AF GF, Dahon Mu P27, Triban Road 7
Quoted: 207 Post(s)
Liked 86 Times in 57 Posts
I've changed from organic to sintered to kevlar using the same rotors, on several bikes. Zero issues so far.
I only had problems when I used metallic pads on a "resin only" rotor. It braked well, but squealed like mad.
Amt0571 is offline
Old 08-14-20, 08:05 AM
Pop N Wood
Bikes: 1982 Bianchi Sport SX, Rayleigh Tamland 1, Rans V-Rex recumbent, Fuji MTB, 80's Cannondale MTB with BBSHD ebike motor, 70's vintage Schwinn Continental and Suburban
Quoted: 219 Post(s)
Liked 163 Times in 109 Posts
I've seen lots of rotors that were stamped "resin pad only", not sure why. Probably a hardness/wear issue more than noise.
Take a power sander with a fine grit garnet sandpaper to the old rotors. Will make the rotors like new, won't matter what type of pads have been used in the past.
Pop N Wood is offline
Old 08-14-20, 09:35 AM
fietsbob
Bikes: 8
Garnet grid is for wood , Carborundum grit is for Metal.
fietsbob is offline
Old 08-14-20, 01:53 PM
Pop N Wood
Quoted: 219 Post(s)
Which will work particles into the stainless rotor contaminating it.
Yes, purposely chose garnet for that reason.
Old 08-14-20, 02:22 PM
fietsbob
Bikes: 8
you taking the disc off first?
fietsbob is offline
Old 08-14-20, 02:47 PM
Ryan_M
Ryan_M's Avatar
Quoted: 11 Post(s)
I did resurface the rotors using abrasive pads but I'll try it with the power sander. Weird thing is they were quiet to start but got noisier the more they were used, they maybe only have 200km on them.
Ryan_M is offline
