MA40 vs MA-2?
MA40 vs MA-2?
I got my back wheel stolen the other night, so I just went and bought a MA-2 set for $100. They are in great condition. Laced to RX100 hubs with a Shimano 8 speed free hub.
Today I noticed a wheel set in the corner of my friends space that I share an art studio with. They just happened to be MA-40s. How random! They are on unlabeled Specialized hubs with aa 6 speed Suntour freewheel.
I texted him and he said I could have them, so now I have two wheel sets. Planning on selling one I guess. Which would you keep/sell? Going on a late 80s trek if that matters at all.
Thanks !
Thanks !
Size? 27? 700c?
Spoke count?
Butted or straight gauge spokes?
Stainless or plated spokes?
Lots of variables!!!
Spoke count?
Quoted: 1819 Post(s)
Liked 1,693 Times
The actual rim used to build the wheels matters less than the skill of the wheel builder and the amount of wear to the rims. An in person inspection of the wheels in question would be the only way to tell which wheel set is better
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,483 Times
On my Bertoni, I just switched from Module-E rims to the MA40 red label rims from the '80s. The velobase description is "elegant workhorse." They feel absolutely great and look even better.
Likes For SurferRosa:
Quoted: 1627 Post(s)
Liked 630 Times
Keep them both, in case one of your wheels get stolen again. Or you slam a wheel-bending pothole. Or you want to run different size cog sets at different times. Or, or, or...
Quoted: 4722 Post(s)
Liked 3,036 Times
The 6 speed wheelset likely has 126mm rear spacing, while the 8 speed is 130mm. If one of them is compatible with your existing rear spacing, that's the set I'd use, unless you're prepared to cold set your rear triangle and re-align your dropouts and derailleur hanger (critical if you've got indexed shifting).
Likes For seedsbelize:
señor miembro
Liked 6,483 Times
Disraeli Gears
Don't have any rubber-to-road experience with MA-40s, but I generally find that when mounting new tires to just about any rim, I need to use tire levers, sometimes a tire jack. After they're used awhile, the stretch makes it so that thumbs suffice to remount them.
Crawlin' up, flyin' down
Quoted: 1025 Post(s)
Liked 2,526 Times
My hazy memory says an MA-2 and an MA-40 are the same base rim, just that one is anodized and the other isn't. My confidence level on this is not super high, so maybe someone can confirm or correct this.
Quoted: 1609 Post(s)
Liked 2,590 Times
Liked 2,526 Times
Funny. I had them on my Miyata a few years ago and had the hardest time changing tires/tubes. Just thought I was losing my thumb strength. That makes more sense.
Confirm
I have a set of the MA40 rims built up on the specialized sealed bearing hubs from my very first "Race" bike that were built by Wheelsmith from back in 1984-1985 I believe it was. I was able to trade out the new Nuovo Record hubs from my groupo purchase for the complete wheelset for even money, saving me the added expense of having having the campy hubs built up into wheels.
The tires du jour were Specialized Turbo S with the kevlar bead. I can attest that YES, the tires were a ROYAL PAIN to mount, but I always chalked it up to the tires and never considered it was the rims...
Anyway, they are 36 hole and have been so used that there is no evidence at all of the anodizing on the side braking surfaces. I can't even begin to imagine how many miles they have on them. They've been off-roading with Specialized TriCross tires, and road racing and used as commuter/bomber wheels with double tires (one tire mounted inside of another tire to help prevent flats-- rides like rocks but works).
Not light. Not aero. But strong.
Quoted: 1944 Post(s)
Liked 2,164 Times
I'd have a tough time selling a wheelset I was just gifted and pocketing the money.
I ran MA-40's for decades and they are great rims. No experience with Specialized hubs. They don't command a very high resale for a sealed cartridge.
As for MA-40's being hard to mount wheels, I used a VAR lever. If the MA-2's are the same rim, then they are just as hard, so that is kinda moot.
John
John
