Go Back  Bike Forums > Bike Forums > Training & Nutrition
How Many Miles Should I Ride ??
Training & Nutrition Learn how to develop a training schedule that's good for you. What should you eat and drink on your ride? Learn everything you need to know about training and nutrition here.
Old 03-29-07, 10:53 PM
SunFlower
I have never been into biking that much, I have always been more of a jogger. I do about 15-20 miles a week jogging. Most of my bike rides are about 5 miles and on flat terrain. However, I want to start riding more than I jog. My current bike course incorporates hills and I am doing about 9 miles per ride. That only takes about 1 hour. I really dont feel like I got a good workout. I will be riding 4 times a week. How many miles do you think I should ride ? I was thinking I could manage 15-20 per ride with the hills and not be too pooped. What do you guys think ? How many miles do you guys ride per day or week ?
SunFlower is offline
Old 03-29-07, 11:11 PM
fat_bike_nut
Bikes: 2010 Surly LHT (main rider and do-everything bike), 2011 Bike Friday NWT (back-up bike and multi-modal)
Sounds like you're doing well right now. Just add another mile when you feel comfortable enough and add on more as you go...as for me, I just kept going farther and farther based on personal comfort level. I started at about 5 miles, and once that got too comfortable, I went to 10 miles. Once that got too comfortable...you get the idea. Just do it 'til it feels too easy and do some more
Of course, don't listen to me if you want a strict training regimen to follow. I cycle to pile on the miles, yes, but I try to get some enjoyment out of it too. Otherwise, it's pointless for me to ride.
fat_bike_nut is offline
Old 03-29-07, 11:13 PM
Machka
In Real Life
Machka's Avatar
Bikes: Lots
Quoted: 3121 Post(s)
Liked 355 Times in 225 Posts
You don't want to know.
However, in answer to your question ... if you're doing 9 miles a day 4 days a week, and you feel fine, go ahead and up the distance a bit! The general recommendation for new riders is 10% per week, so if you do 36 miles one week, do 40 miles the next week. However, since you are already quite active with your jogging, you could probably increase your distance more than that. Go for a 15 mile ride and see how you feel. If you feel pretty tired out, back off a little bit to 12 miles or so. If you feel a little bit tired, keep it at 15 miles for a week or two. If 15 miles feels pretty good, ride 15 the next time you go out to be sure it still feels good, and then you might consider trying a 20 mile ride.
One suggestion ... as you increase your distances on the bicycle, keep at least one day relatively short to work on your speed (i.e. 15-20 miles), keep another day relatively short to use as a recovery ride day (i.e. 15-20 miles), and then increase the distance on the other two days up to whatever distance you want to ride.
Machka is offline
Old 03-30-07, 03:46 AM
roadbuzz
Just ride.
roadbuzz's Avatar
I came to cycling from jogging, and it's been so long I scarcely remember. My perception was that for equivalent workouts, figure twice as much time on the bike, or 7 times the miles. So, for example, a 20 mile ride is roughly equivalent to a 3 mile run. This is using a road bike, and I'm sure others will disagree with my numbers. Also, riding is just a different work-out. More strength required for cycling, higher average heartrate & breathing for running. Things will change some as you gain more cycling conditioning (per Machka's' advice). Again, everyones experience varies a little.
roadbuzz is offline
Old 03-30-07, 04:20 AM
trimonkey
trimonkey's Avatar
Bikes: giant scr 2
Are you still intending to continue jogging 15-20 miles a week? When i began to run and bike more than a couple of times each a week (requiring more than one workout on the same day), it took a little bit of juggling to schedule the timing of each workout so i wouldn't be wiped for the next one. I'm not sure how fit you are or what you recovery ability is like, but you may want to bear in mind that a 20 mile hilly ride in the evening, might render your legs a little unresponsive for the next mornings run. I'm not saying you can't do it, and there are certainly people on here that do. But my point is allowing your body to gradually adapt to the strains of mlutiple sessions a day, is a balancing act that requires you to listen to what your body is telling you... i've found. Anyway, good luck :-)
trimonkey is offline
Old 03-30-07, 07:31 AM
kuan
Twincities MN
kuan's Avatar
Bikes: Fat Caad Lefty, Foundry Overland.
To start, do one ride a week that's 25% longer that your longest daily workout. Keep increasing that by about 15 minutes each time. That'll drag your daily mileage up.
www.marrow.org
kuan is offline
Old 03-30-07, 08:51 AM
Richard Cranium
Richard Cranium's Avatar
Location: Rural Missouri - mostly central and southeastern
Bikes: 2003 LeMond -various other junk bikes
Quoted: 44 Post(s)
Liked 14 Times in 13 Posts
Using "miles" as a measurement is meaningless. If you interested in being fit, then 6 or 7 hours per week of combined aerobic activities, like riding or running is enough for maintaining health.
If you choose to ride or run more than that, then you are exercising to increase your capacity to endure a particular task, but not necessarily improving your health.
Richard Cranium is offline
Old 03-30-07, 10:46 AM
umd
umd's Avatar
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
I typically ride between 300 to 400+ miles a week, usually with around half of it over the weekend. That's 30-40 miles/day during the week and 2 long rides over the weekend, usually near or greater than 100 miles each. As of last night (Mon-Thurs) I was at about 150 miles with 11k of climbing. This includes my commuting too.
You can see my weekly data on my blog
umd is offline
Old 03-30-07, 10:52 AM
PEABOB
Bikes: schwin.
Hey Peoples. just reading the posts and it is of great help. I just started riding a new recumbent trike and finding i get winded rather fast. Out of shape and overweight here. I just want to enjoy the outdoors and do something fun. I feel quite alright now that i have rode short times but they are getting longer everytime i go out. Like i said enjoyment and weight loss is what im looking for. thanks for all the great posts. peabob
PEABOB is offline
Old 03-30-07, 09:32 PM
Bici3
Try riding as long as you possibly can everyday. Fall over sideways on your backyard lawn in supreme exhaustion. Laugh in exquisite, delerious pain and joy. Rinse off in cold water from the garden hose. Laugh some more. Have a big sport drink. Grill food on the patio with like-minded friends, and a dark-colored beer. Chocolate Chip gelato and espresso a bit later.
https://www.bicitreregioni.com
Bici3 is offline
Old 03-30-07, 10:03 PM
cyclezen
OM boy
cyclezen's Avatar
Bikes: a bunch
Quoted: 44 Post(s)
If your intent is largely 'exercise', and you want to step up the 'pace' a bit, or challenge yourself a bit more; then look for group rides. There should be plenty in your neck of the southland. I'm not talkin 'hammerfest', just some solid and steady paced groups. And if they're worth half their weight in salt, they'll have a few routes thru the hills in PV. Go to the local Bikeshops for info on group rides, pick up the local bike rag - forget the name, but there's one specifically for SoCal riding, actually there are a couple rags for sure.
You'll quickly find yourself doing 15-16 mph pace for the hour, and feeling great about it.
As for your objectives, 15-20 miles per ride, a good target for sure.
cyclezen is offline
Old 04-01-07, 08:28 AM
JPradun
Pokes On Spokes
JPradun's Avatar
Bikes: Pedal Force ZX3
I'm going to be a little different. When I tried my hand at running for a few months (before I started riding), I could only do about 15mi/wk. I probably could have easily done a 40mi ride.
Get your butt used to the saddle and ride as far as you possibly can. You'll probably surprise yourself after you do 30+mi.
I ride half as much as people like umd, but this week I did pull off 200mi, and 150 last week. I usually go for 45-70mi rides each time.
JPradun is offline
Old 04-01-07, 09:33 AM
Tom Stormcrowe
Out fishing with Annie on his lap, a cigar in one hand and a ginger ale in the other, watching the sunset.
Tom Stormcrowe's Avatar
Bikes: Techna Wheelchair and a Sun EZ 3 Recumbent Trike
Liked 3 Times in 3 Posts
1.6X10^126350495 miles a day!
. “He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.”- Fredrick Nietzsche
"We can judge the heart of a man by his treatment of animals." - Immanuel Kant
Tom Stormcrowe is offline
Old 07-25-16, 03:49 PM
Giants28
69 years old had back surgery in May can no longer run started riding bike riding 15 miles a day little over5 minutes a mile is that considered a good work out dont know much about biking?
Giants28 is offline
Old 08-08-16, 05:26 PM
ridethetown
Bikes: 2020 Specialized Roubaix Comp, 2019 Specialized Diverge Sport, 2018 Santa Cruz Bronson S Aluminum 27.5, 2014 Wabi Classic (Fixed)
Quoted: 43 Post(s)
Liked 13 Times in 5 Posts
+1
My first ever road ride was on a crappy old rusty Trek MB that was too small and had seen 4 Burning Man's. 34 miles and 1500 ft. of climbing. Terribly hungover and poorly fueled, I puked my brains out at the turnaround and cramped every 3 miles on the way home. Hated every second of it but couldn't wait to get back on the horse. Bought a $200 Dawes off Bikes Direct that very evening and rode a metric century 3 months later.
Do I recommend this exact approach? F no. However, the more quickly you find your limits, the more quickly you'll get much needed perspective on what you're capable of. Strong mind -> strong body.
ridethetown is offline
Old 08-08-16, 06:00 PM
FullGas
Quoted: 172 Post(s)
used to be a high-mileage runner...35+ mi/wk.
knees decided that sport was no longer an option.
now, I swim 6000 yards and ride 130 miles per week. my body likes it much better...
FullGas is offline
Old 08-14-16, 03:56 PM
GSJon
GSJon's Avatar
Bikes: Specialized Crux Expert Evo, Felt DA, Surly Crosscheck, Divvy
Quoted: 8 Post(s)
Good going on resurrecting a NINE year old thread.
GSJon is offline
Old 08-14-16, 04:05 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4815 Post(s)
Liked 1,549 Times in 875 Posts
From last post to necro, 3,404 days. Pretty good. Strong Top-10 contender.
DrIsotope is offline
Old 08-14-16, 07:22 PM
sprince
Quoted: 71 Post(s)
As many as you have time for while still enjoying it.
sprince is offline
Old 08-24-16, 07:23 AM
chong67
chong67's Avatar
Bikes: Trek FX 7.4 + Sirrus Expert Carbon X1
Quoted: 148 Post(s)
Me too. I went from a jogger/runner to bicycling. My feet cant take the constant pounding anymore. Buying expensive shoes and padding are no help.
Bicycling is so much better. I do abs and back exercise at the rest area of the trails.
Swimming is good but not convenient.
chong67 is offline
Old 08-24-16, 08:29 AM
Jim from Boston
Jim from Boston's Avatar
Quoted: 800 Post(s)
Liked 206 Times in 161 Posts
How Many Miles Should I Ride ?? (Zombie thread)
Originally Posted by Giants28 View Post
69years old had back surgery in May can no longer run started riding bikeriding 15 miles a day little over5 minutes a mile is that considered a goodwork out dont know much about biking?
Here’s a concensus opinion from two long-term, year-round commuters. Personally I ride for fitness, as does @tsl, from various posts and conversations. I’m personally very time-crunched by work and family activities, but I have a minimal 14 mile one way commute, and a high-end carbon fiber bike that encourages riding; and I had a fractured sacrum requiring pins back in 2012.
Originally Posted by tsl View Post
…Iwas concerned about getting decent miles in. This is the time of year when I'dtake my 17-mile long loop to work, and a 13-mile cut of it coming home. It's not that I chase miles for the sake of numbers. It takes me 50 miles a week just to feel good and normal, I feel fantastic over 100 miles a week, and like Superman over 150
…I particularly agree with your assessment of weekly mileage, though at over 150 miles per week, I call it hyper-fit.
Jim from Boston is offline
dm_miller
Touring
29
09-11-17 06:59 PM
LabRat55
Fifty Plus (50+)
25
06-19-17 11:54 PM
Jarhead_1
General Cycling Discussion
30
08-18-15 06:52 AM
nrowensby
62
01-11-12 02:24 PM
Lucillle
Fifty Plus (50+)
39
01-27-11 09:14 AM
