Chain clean & lube: What works for you?
Old 10-12-13, 07:25 AM
Barrettscv
Have bike, will travel
Barrettscv's Avatar
Quoted: 910 Post(s)
Liked 288 Times in 158 Posts
My rides are about 50% pavement and 50% gravel.
My practical chain maintenance routine is not enough to keep my chain clean. So I ask, What works for you?
What lube do you use?
What intervals?
What do you use to clean a chain used for gravel paths and roads?
How long will you keep the same chain in use?
I'm now wiping down my drivetrain every ride, or about every 50 miles. I don't use solvents or cleaners. I'm lubing the chain about every 150 miles with a wet lube. I'm buying a new chain about every 2500 miles, long before it is worn-out.
Barrettscv is offline
Old 10-13-13, 09:07 AM
pamaguahiker
pamaguahiker's Avatar
Bikes: 2014 VeloOrange Campeur. late 90s Bianchi Cyclocross cro-mo frameset modified to touring, 1993 Bianchi Project 5, 80s Holdsworth Gemini Tandem
Quoted: 7 Post(s)
Liked 17 Times in 9 Posts
That's a lot of questions in a short paragraph. I will tackle first, then be critiqued and learn some about the process also when people do respond.
I use white lightning, but my process of cleaning and applying is different. When I finish a ride, if it was wet and muddy. I use a wet spray, while spinning it backwards, I applying wet spray. let it stand a few minutes, then cycle is backwards again with rage held firmly to clean. I do this for a few minutes and inspect. if it is still VERY wet with lube cleaner, then I run it backwards again. Then I apply the white lightning while spinning around to get all the chain covered. I probably oversimplified the process but it works for me. After you do it a time or two. The whole process can be done within 10 minutes easily. I also knock off any chunky debris from cogs and rings.
How long does a chain last? depends on how muddy, how often it is muddy, is it cleaned after muddy, are cogs clean...those may be some questions stated.
For me, I have a bike that I have 10k at least on chain, cogs, and rings. It is my beater winter, bad weather bike and being in Pa, where there appear to be 2 season some years, winter and almost winter, or horribly humid and rainy at other times. (Where else do you put the heater and AC on in the same day, Pa), I just keep cleaning as suggested above on those rainy or dirty mud days. I don't plan on changing until I have a catastrophic failure of chain and I am well aware that I will be replacing all. But as I said. It's a beater and the items I replace it with will most likely be not top notched and mostly used. When I used to race and use high end parts. They needed replaced more often, about 5k miles maybe, and there is a old tip. When the cassette cogs started skipping, flip the chain and you can usually squeak out another 500-1000 miles. I have had only one opportunity to test this theory and advice and it did indeed get me another 600 miles.
Good luck
pamaguahiker is offline
Old 10-13-13, 04:25 PM
roadbuzz
Just ride.
roadbuzz's Avatar
I use Pro-link Gold. Their instructions are to just wipe down and re-lube, but that's nuts. Wiping cleans the outside, that's not the wear I'm worried about. Lubed sand and grit ain't good for anything.
I try to clean (and re-lube) my chain after a wet ride, or just starts looking too gunky. Either way, at least once a month.
I use an on-the-bike chain cleaner from Performance, use Simple Green as the cleaner.
I use the measure-twelve-links method to determine chain wear. Try to replace when it's "stretched" 1/16".
roadbuzz is offline
Old 10-13-13, 06:29 PM
pamaguahiker
Quoted: 7 Post(s)
1+ to the measure-twelve-links method. It's a good measure! I used this faithfully with my racing bikes.
Old 10-13-13, 11:57 PM
Andy_K
Andy_K's Avatar
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times in 1,439 Posts
When I'm going to be riding in wet conditions I use Finish Line Wet lube. It's pretty thick and doesn't wash away. On my commuter that usually keeps it quiet for a few weeks. I don't wipe it down until it starts to get noisy or feel sluggish. With this routine I get about 2500 miles out of a chain.
I also use Finish Line Wet for CX racing, but those races are usually pretty muddy and so I end up washing it and relubing after every race. I don't track mileage meticulously in those conditions, but I'd guess those chains don't see 500 miles.
I use a chain checker tool and replace it when it gets to the 0.1% indicator.
My Bikes
Andy_K is offline
Old 10-14-13, 05:42 AM
jolly_ross
The 12 link method works, is cheap and is easy. If you need to measure really quickly (like, perhaps, you fix bikes for a living) then the options are pretty well either "Shimano chain checker" or "ignore the minor errors in other brands". I use a ParkTools checker under the second of those options.
https://pardo.net/bike/pic/fail-004/000.html
jolly_ross is offline
Old 10-14-13, 09:43 AM
Cynikal
Team Beer
Cynikal's Avatar
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times in 104 Posts
I use Chain-L and apply warmed. Depending on the race I will wipe off and see if there is need to re-apply. If a really muddy or gunky race I will run the chain through a scrubber and re-apply. For my SS cross bike, I keep it dry so it will never attract anything. I've thought about dipping it in melted paraffin but have never gotten around to it.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Cynikal is offline
Old 10-14-13, 11:12 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Some, applied regularly, not that Fussy , LBS has a bottle of Triflow, I use theirs occasionally..
wiping off the outside of the chain once it penetrates under the rollers.
fietsbob is offline
volosong
Bicycle Mechanics
36
07-06-22 12:56 AM
Pickleballer
Bicycle Mechanics
14
03-13-12 02:36 PM
bagel007
Bicycle Mechanics
19
05-27-11 03:16 PM
Univega
Road Cycling
23
05-06-11 09:42 AM
merganser22
Bicycle Mechanics
6
10-09-10 12:59 PM
