Columbus foco question.
Old 05-19-19, 08:18 PM
Jonnyd613
Liked 10 Times in 2 Posts
Hey folks I’m currently looking at a bike in Columbus foco tubing and am questioning the durability of it. I rid a mix of well paved bike paths and sometimes rough city streets. The bikes I’ve ridden in the past have been vintage steel that have handled the roads ok but I are heavy and would like to try newer shifting and lighter weight.
My question is if anyone has experience with foco tubing in their bikes and if I should be nervous about the thin wall tubing. Is it safe to strap to a bike rack like my old bikes or do I have to transport it in my car? Any help is greatly appreciated!
Jonnyd613 is offline
Old 05-19-19, 08:58 PM
Nessism
Nessism's Avatar
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times in 337 Posts
Foco is pretty thin in the middle of the top and down tubes. I wouldn't carry a bike like that on a bike rack unless there are features in the rack that spread the load and don't create pressure points on the frame tubes.
Nessism is offline
Old 05-20-19, 07:46 AM
Road Fan
Road Fan's Avatar
Quoted: 1856 Post(s)
Liked 664 Times in 506 Posts
Your vintage steel bikes (and mine) were most likely made of these commercial steel products: Reynolds 531, CrMo, or Columbus Cyclex (their branding of CrMo). These have roughly the same strength. You can only make a tube so thin and still expect it to resist denting and crumpling, aka buckling. The stronger the steel, the more resistance to crumpling a tube will have, the bigger wrench you need to hit it with to make a dent in the tube wall. So for a given desired resistance to crumpling, stronger steels can be supplied with thinner walls and hence the finished frame will have lighter weight.
High-strength modern steel for bikes include Columbus Nivacrom, Reynolds 753/853/953 (this last is just about the strongest of all), TruTemper OX-Plat (another of the top materials), and too many others to list. These are (based on metallurgical test results) something like 40% stronger (plus or minus, we're just using rough numbers) than the older group of steels. Columbus Foco is made of this Nivacrom. It should be thinner and lighter than an older SL-based frame, which can still make an awesome bike, by the same proportion as the strengths. You can Google Columbus Foco and read what Columbus has to say about it - you should be able to find maybe 5 catalog pages in English.
Compared to an old English 3-speed from the '70's or before, these are all light, bicycles that may feel fragile. But first they were designed to take racing stresses applied by the strongest riders in the world, and what you can buy today may or may not be racing only. And many of us steel bike freaks have been riding full-racing steel bikes on the streets for decades. They're a little stronger than eggshells.
Road Fan is offline
Old 05-20-19, 06:03 PM
Jonnyd613
Thanks for the reply’s guys I think I might have to keep looking I’m not much of a racer and don’t really want to have to worry about pot holes and curbs.
Old 05-23-19, 03:29 PM
rgconner
rgconner's Avatar
Bikes: Curtis Inglis Road, 80's Sekai touring fixie
Quoted: 472 Post(s)
Liked 11 Times in 9 Posts
I have a 19 year old bike that is Foco tubing for the main tubes, Thron for downtube and bracket.
Holding up just fine.
rgconner is offline
Old 12-12-19, 11:35 AM
MiloFrance
MiloFrance's Avatar
Bikes: Lots of French, some British and a couple of Italian
Quoted: 247 Post(s)
Liked 130 Times in 65 Posts
Jonnyd613 did you buy it? Sorry about the zombie thread, I was looking up foco tubing on Google and it popped up first!
MiloFrance is offline
Old 12-12-19, 11:47 AM
Jonnyd613
No I ended up buying a mid 70s motobecane grand jubilee still light but plenty rigid the "Nervex style" lugged Reynolds 531 steel is sweet. The concern that I had with the Foco tube was the bike I looked at had a small dent on the top tube that the owner said happened while dismounting the bike and his cleat tapped the tube. Whether or not that’s how it happened I’m a little rough with my bikes and put them on a rack on the back of my car and it wasn’t going to work for me.
That being said it was sooooo light and very cool just not for my urban/country rough ridding roads. Hope this helps!
