10 Speed Rear Derrailleur with a 9 speed cassette and shifter
Hi there,
I'm in the process of a building a Soma ES into a commuting bike/city workhorse. I was planning on doing a 1 x 9 because I already have a Shimano DuraAce bar end shifter and a 9-speed cassette. Can I use a Tiagra 10 speed rear derailleur with this? I could always fall back on the Shimano Claris but I was hoping to get something a bit higher quality. There is a small chance that I would use this bike as a light touring bike in the future and would only have to upgrade the crank set and add a front derailleur then.
And, aesthetics are important and I would like to keep the derailleur silver.
Thanks!
Thanks!
Hi there,
Thanks!
Thanks!
Thanks! I didn't think it would be a problem but there is a lot of conflicting info out there. The specs on the Shimano website are also a little confusing. The info on the derailleur says it's compatible with a 10 speed cassette.
This is my first build and I'm having a lot of fun doing all the research, taking the time to understand it, and picking the parts out.
my Rohloff is self contained .. there is just a drum with 2 cables on the bars pulling in both directions.
everything else is inside the hub.
all single cable derailleurs have the detent spacing in the front move the cable
a measured small amount , pulling the RD sideways , the return spring pulls it back .
yea they play pull ratio games amongst themselves . but still no clicks in the RD itself.
OP ? good luck.. obsolescence is how marketing driven the world turns ..
![Wink](images/smilies/wink.gif)
DancesWithSUVs
kbagel,if we were talking high-end,the derailleur's jockey wheels would prolly be designed to work specifically with a 10spd chain,but the Tiagra should work ok.
![](https://static.flickr.com/55/137967009_693820d686_o.jpg)
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Dahon Speed Pro TT,Brompton S6L/S2E-X
![](https://farm1.static.flickr.com/132/353140262_6e110d8686.jpg)
contiuniously variable
'Speeds' is also now a width. 8/9/10spd cassettes are the same width,but to get the extra cogs in,they are made thinner. The chains are also thinner,as are the front rings.
- Andy
That given, a 7 speed chain will run over a single 9 speed jockey wheel, provided it fits inside the cage of the individual RD. A 7 speed chain won't fit in the smaller spaces between the cogs on a 9 speed cassette.
That's because cassette are cassettes and jockey wheels are jockey wheels. Both are round toothy things but they are different. A thinner single gear will run inside a wider chain. (Given realistic boundaries.....like in the bicycle world, I'm sure some aerospace engineer could point out that a skinny jockey wheel won't run in a 630 motorcycle chain---but, we're talking general bike world in this case.)
![Big Grin](images/smilies/biggrin.gif)
- Andy
justanoone
General Cycling Discussion
11
08-09-18 01:53 PM
vinuneuro
Bicycle Mechanics
5
04-26-17 10:40 PM
stringmaster
Bicycle Mechanics
4
10-13-14 04:01 AM
Reeses
Bicycle Mechanics
23
06-24-13 07:26 PM
