Nine Speed Compact Crankset with Eight Speed Drivetrain?
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times
I've got a '97 Bianchi Trofeo with an eight speed Campagnolo drivetrain. I'm happy with the eight speed part, but would like to replace the 39/52 crankset with a 34/50. I've got a nine speed Shimano Tiagra 34/50 crankset with BB. Should I be able to swap the cranksets? Would it require a different FD?
A similar question was posed on the Road forum, but I'm guessing you guys might have more experience at this.
Thanks!
Thanks!
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
Bikes: 84' Ciocc, 79' Shogun 1000, 76' KHS Gran Sport, 96' Schwinn Super Sport,
Yes, just move the FD down. The BB I don't know about, My Ciocc I went from a Victory crank to a Mirage compact and used the old BB. What crank are you using.
Bikes on Flickr
I prefer email to private messages. You can contact me at justinhughes@me.com
Bikes on Flickr
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4346 Post(s)
Liked 3,007 Times
You might have trouble with an 8-speed chain on a 9-speed crank. 9-speed chain on an 8-speed cassette should be OK though.
It's MY mountain
Liked 3,007 Times
Nope. The cogs are closer together on 9 speed so you need a thinner chain, but the teeth aren't thinner.
If your chain is too wide in front though, you can have all kinds of shifting problems depending on the brands of crank and front der.
OMC
Quoted: 461 Post(s)
Liked 116 Times
Okay, I get that. I was hoping that, since the Campy FD kinda ratchets the chain over rather than just thunks it over like Shimano, it wouldn't be an issue.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
It's MY mountain
Liked 3,007 Times
I had a 9-speed chain that never worked right with my 8-speed compact crank - it'd skate or get caught between the rings - no amount of futzing with it helped... gave up and bought a new 8-speed chain and it worked fine again.
I have a 10 speed cassette (ultegra), shifters (DuraAce) and chain (shimano) that work just fine with my 9-speed Dura Ace crank, FD, and RD... Shimano says I need a 10-speed crank but I've had zero issues with front shifting.
But narrower chain on the rear is almost never a problem.
