Now THAT's a flat...
Bikes: Road, Commuter, Mountain, Tandem and a couple others
Quoted: 87 Post(s)
Liked 41 Times
So I got about half a block from work when "BAM". Worst flat I've ever seen. I have no idea what I ran over, but it did some damage.
I installed a boot, was not sure it would hold or not, but it lasted the 12 miles I needed it to. I could feel the bump of the gradually expanding boot for the last 8 miles or so.
This is what it looked like when I got home...
Wow
Amazed that you were able to fix it good enough to ride.
Good job
Big boot?
what you use use for the boot?
Good job
Big boot?
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,035 Times
Yep, I ride with them too. I got a sidewall cut in an almost new GP4000SII and the boot held up for another 30 miles or more. Not *quite* the damage the OP had, but it definitely was worth carrying.
-Matt
-Matt
Quoted: 18415 Post(s)
Liked 15,545 Times
Bikes: 2015 Giant Roam 2 Hybrid
Quoted: 91 Post(s)
Liked 6 Times
In an emergency an American dollar bill will act as a boot, the linen fabric is actually pretty tough. I've done it on a 16 mile ride back home.
Quoted: 5224 Post(s)
Liked 3,581 Times
impressive!
Quoted: 87 Post(s)
Liked 41 Times
I did look - the roadway was mostly covered with leaves. The only thing I saw was a stone about 3/4" but I don't know if that did it or not - it did not look sharp enough, but the damage was obviously done, so at that time there was nothing to do but address the problem.
Park Boot
$4 and it might be the only way to get home on 2 wheels.
https://www.jensonusa.com/Park-Tool-...MaAkZkEALw_wcB
Quoted: 3375 Post(s)
Liked 5,514 Times
DAMN!
And I was impressed when a Park boot handled a 3/4” sidewall cut.
I doubt a dollar bill would have held there because it lacks the adhesive of the Park boot.
Quoted: 762 Post(s)
Liked 4,035 Times
-Matt
Quoted: 1364 Post(s)
Liked 1,677 Times
@joelcool Nice boot job!
Years ago I got a bad one like that. I was wearing a pair of shoes that were on their last legs, so I sacrificed one by cutting out the tongue and using a piece of that as a boot.
Sounds grisly, doesn't it?
Liked 5,514 Times
Most recent flat (a week ago) was yet another one of those damned little wires shed by worn out steel-belted tires, so no boot needed.
I'm thinking the next time I change out a worn tire, it would be an interesting experiment to put a cut across the tread like the OP, then test booting with a dollar bill, then test it with the Park boot.
For sure Gonna add a boot to my repair kit.
That's impressive.
Ive read about the dollar bill trick,
but
might need a $20 to fix a cut that big
Liked 15,545 Times
I never finish anyth
Bikes: 2008 Merckx LXM, 2003 Giant XTC mtb, 2001 Lemond Alpe d'Huez, 1997 Lemond Zurich, 1989 Cannondale ST, 1988 Masi Nuovo Strada, 1983 Pinarello Turismo
Quoted: 294 Post(s)
Liked 137 Times
I carry a piece cut out of a milk jug to use as a boot. Takes basically no space, but is pretty tough material. I don't know if it would have worked for this degree of tire damage, but maybe. I'd actually prefer not to test that theory if I can avoid it.
Dale, NL4T
Dale, NL4T
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Meh.... just add some more Stans.
Non omnino gravis
