Protecting bike from salt and rust in commutes
Bikes: 4
Quoted: 11 Post(s)
So I just bought a vintage bianchi road bike with a steel frame and nice components. It's currently winter where I live, and this means that there is often the typical mix of slush/salt/snow/dirt on the roads. I've had issues with bikes getting damaged and parts not working in the past, and I would like this bike especially to be protected from that. The paint on the frame is still pretty good, not much damage is visible. How much should I be worried about the bike? I usually commute a short distance (>10 minutes) and then the bike is locked outside to a bike rack. When I am at home I keep all my bikes inside as a general rule.
What is a good set of rules/strategies to protect the components/frame? I don't want the nipples to seize, things to rust, etc. I also could potentially wash the bike but it would be quite a big hassle (no garden hose etc in my apartment).
Is my best strategy to just ride my beater mountain bike around or are there ways to realistically protect my bike well?
Just wash it often with fresh water, keep it clean oiled chain , etc .. bucket brushes and sponge .. how about the bathtub?
Quoted: 2604 Post(s)
Liked 1,926 Times
Ride the beater bike for daily commutes, and save the nice road bike for nicer weather, or weekends when you can devote 30 minutes to post-ride cleaning and maintenance after every ride.
Bikes: HP Velotechnik Streetmachine GTE, 2015 Devinci Silverstone SL4, 2012 Cannondale Road Tandem 2, Circe Morpheus, 2021 Rose Backroad, 2017 Devinci Hatchet
Quoted: 181 Post(s)
Liked 14 Times
Some strategies you could consider:
If you don't want the additional maintenance and care, beaters are your best bet.
- Use a hand-pump garden sprayer to hose down your bike with warm water (store inside afterwards). $20 at your hardware store
- Replace all bolts with stainless steel bolts. Grease threads. Only use stainless steel cables.
- Consider a more rust resistant chain
- Protect inside of steel frame against rust (Frame saver, Boeshield T-9, boiled linseed oil)
- Regularly keep your drive train free of gunk and sand
- Touch up on all scratches and paint chips on your steel frame BEFORE rust starts
- Aim to replace as many plain steel parts with stainless steel or aluminum versions as reasonable.
- You can use something like thick grease or Vaseline to cover up moving plain steel parts, such as derailleur joints, etc (not chain!). Needs cleaning and replenishing once a season
- Use nosed housing ends and other covers to reduce water ingress into cable housing (esp. those that are pointing upwards and where water can collect in a housing)
- Full-coverage fenders with long mudflaps
Quoted: 800 Post(s)
Liked 218 Times
Even on dry roads, I wonder about salt dust from so much laid down. I wait until a good drenching rainfall occurs after the presumed last road salting, to wash most away.
Maybe something like Boeshield, which was developed to protect aircraft from corrosion would help. But don't get it on the brake track on the rims.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Quoted: 4227 Post(s)
Liked 2,488 Times
I don't bother cleaning my bikes during winter. I rinse the salt off with water once a year at the end of winter season and keep everything well lubed. Don't worry about a little bit of rust on the chain, bolts and other hardware, the rust is just cosmetic. The most important thing is protecting the frame. Spray some automotive rustproofing oil inside the frame.
Quoted: 800 Post(s)
Liked 218 Times
So too I don’t bother cleaning my beater either. We live in a small downtown condo, and I don’t have easily accessible facilities, like a garage.
If the bike, mainly the drive train is particularly filthy, my bike shop one block away does a good cleaning.
My beater is a good quality aluminum Specialized Diverge, and I bought it as a good-riding beater that I would nonetheless subject to the elements, without the distress of messing up my high end Specialized S-Works.
My strategy too. My pristine carbon fiber bike is completely in storage from December to March.
I don't bother cleaning my bikes during winter.I rinse the salt off with water once a year at the end of winter season and keep everything well lubed.
…Besides time, I have never had good facilities to work easily. Even now we live in a relatively small, but elegant condo, and my wife would frown on a room with a bike stand. Having the LBS do it all, in my case is a really good deal.
The shop is one block away, and they will fix many things at a convenient time for me [especially when not busy during bad weather].
They are so expert that they can do these things quickly, better than me, and often spot problems that I did not see. Whenever I leave the shop, the bikes ride as if new again.
Because the bikes are a major transportation mode for me, keeping them in good repair is critical. We save a lot of money on transportation, so further using the LBS is even more cost-effective…Hats off to Back Bay Bikes.
Bikes: Raleigh Classic 15, 84; Miyata 912, 85; Miyata Ridge Runner SE, 85; Miyata 610, 86; Miyata 100M, 86; Miyata Valley Runner, 88; Miyata Triple Cross, 89; GT Karakoram, 90; Miyata Elevation 300, 91; Marinoni Touring, 95; Long Haul Trucker, 2013
Quoted: 159 Post(s)
Liked 133 Times
In the winter it's too cold and messy to bother with much. I wipe off the chain from time to time, and apply fresh oil. Any cleaning I try seems futile—the next slushy day negates my efforts.
Quoted: 1186 Post(s)
Liked 289 Times
I leave near the ocean and I always use lubes like carbon pro heavy lube or green oil lube. My bike and other "toys" stored in the garage, but corrosion is not sleep. I forgot about my child's bike for 3 month and when found him in the corner of the garage it was all in corrosion.
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
I use a mixture of Boeshield T9, LPS 3 and ACF-50, in about equal proportions. The mixture works better than any of the components individually and I get all 3 from aircraft suppliers. I may need to reapply the mixture only once or twice per winter and this only on the chain - on other places it holds on with far more resilience.
Bikes: Specialized tarmac sl2 giant tcx zero
Quoted: 319 Post(s)
ride carbon , throw those penny smelling paper weights in the trash bro !!!
carbon is rarbon !!!!!!
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
In theory, baby wipes were a good idea. I managed to keep my bike nice and sparkly through the early part of winter by taking a couple of wipes and removing dirt and gunk from the frame after each commute.
In practice, the plan failed; once it actually got cold, the wipes just froze to the frame. If I had a microwave it might be worth heating them up (in the style of airplane hot towels!) and giving that a go.
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,434 Times
I do have "beater" that I ride on wet, snowy, salt coated roads. My "other" bathroom has a good sized, tiled shower stall with flexible water tubing and a movable shower head. I put my bike in there and give it at least a good hosing off, let it drip dry a bit, and then wipe it off and lubricate as necessary.
Congest top of your seat tube with hot glue. Rain and washing water goes to bottom bracket through the hole on seat tube. Water causes bottom bracket to rust, then rust spreads to frame and make it trashed. I had this kind of experience, my previous bb has trashed only at 9000 km because of moisture but I was lucky because I use 6061 alloy frame.
Quoted: 539 Post(s)
Liked 44 Times
Fenders to avoid throwing road salt and such up onto the drivetrain is about all you can do.
What's worst for the bike here is getting rained or snowed directly on. Ideally you could find a rack underneath some sort of roofing (like in a parking garage or something) so it's not directly exposed to rain and snow.
Steely Dan
Commuting
40
12-10-12 12:30 AM
apete2
Bicycle Mechanics
18
07-02-11 12:08 AM
