What is this and is it worth restoring?
Bikes: 1983 Austro Daimler - Puch Pacifica, 1984 Miyata 310, 1983 Univega Gran Tourismo, 1989 Peugeot Triathlon, 1989 Bridgestone MB-1, 1992 Klein Rascal, 1992 Cannondale M-700
Quoted: 86 Post(s)
Liked 73 Times
So, here is a challenge! The seller’s photos are pretty bad, but what I can tell from them is;
Repainted frame with wraparound seat stays and simple long pointed lugs.
Is fork original?
Campy Nuovo Record crank, FD, bent shifters, hubs?
Ambrosio “Champion Del Mondo” stem and bars
Universal Super 68 brake levers and calipers
non-original Shimano Crane RD
Regida rims
Brooks or Ideale saddle in rough shape.
What is it? Is it worth buying and restoring as is or part it out?
Thanks!!
Is fork original?
Regida rims
Thanks!!
Bikes: Lots of French, some British and a couple of Italian
Quoted: 247 Post(s)
Liked 130 Times
Generally speaking, seat stay finishing with a wrapover is not a low end frame. Lack of bottle cage bosses puts it in the 70s? as does the stem. If you were in the UK I'd say Holdsworth/Carlton/various others. I'd go for it.
Likes For MiloFrance:
Bikes: 1968 Raleigh Super Course, 1972 Raleigh Professional, 1975 Raleigh International, 1978 Raleigh Professional, 1985 Raleigh Prestige, 1972 Schwinn Paramount, 1980 Schwinn Voyageur 11.8, 1960 Carlton Franco Suisse Peugeot PX10, 1972 Motobecane Le Champ
Quoted: 323 Post(s)
Liked 690 Times
With a Davis style sloping fork crown and full wrap around seat stays (not to mention the long point lugs) it’s clearly a high end bike. It’s tough to tell but I’m wondering if that fork crown is chromed under the paint. No harm in lightly scraping away this paint to find the original color either. If you find out what it is it’ll be worth restoring. Can you find a serial number on it?
Likes For Pcampeau:
Bikes: Colnago (82, 85, 89, 90, 91, 96, 03), 85 Cinelli, 90 Rossin, 83 Alan, 82 Bianchi, 78 Fountain, 2 x Pinarello, Malvern Star (37), Hillman (70's), 80's Beretto Lo-Pro Track, 80's Kenevans Lo-Pro, Columbus Max (95), DeGrandi (80's) Track.
Quoted: 179 Post(s)
Liked 198 Times
Yes - it looks British.
Is it worth buying and restoring? YES!! I wish I found it and it's a good frame size too. I'd guess at early to mid 70's too?
Likes For Gary Fountain:
Quoted: 331 Post(s)
Liked 332 Times
Nice bike, definitely worth restoring. If you keep this kind of bike, it will outlive you. If you restore it yourself and sell it, you will never get your money back. If on the other hand you get it done professionally and sell it , it will be the worst investment you ever make.
Suck it up and welcome to C & V!
Likes For Johno59:
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Early 70's Holdsworth?
Has all the hallmarks of an early 1970's Holdsworth except for the head tube lugs. Maybe not a Professional but rear the top.
Wrap over seat stays
Holdsworth used the Prugnat S style lugs on a lot of frames.
They also used these style lugs on some of their lower priced models.
During the bike boom, builders used what they could get, especially lugs and fork crowns so who knows.
It's definitely a good quality Brit frame from the early to mid 70's. Very much worth restoring.
1 question and 1 comment:
Does the bike fit you. If the frame is too big or too small pass it on.
Next, get the bike in riding condition with new cables and housing, brake pads and tires. Take it out and ride it for a while then decide whether it's a keeper and worth putting time and money into.
verktyg
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
If it fits and it's not north of $200, buy it first and ask questions later. Agree with everyone above that it has all the hallmarks of a UK build.
@verktyg, did you happen to notice the subtle curve on the rear brake bridge? Do you know if any Holdworths carried this detail?
-Kurt
-Kurt
Quoted: 3811 Post(s)
Liked 3,338 Times
whilst clearly a Holdsworthy product it may have been badged as C. Butler, Harding, Grubb or any of of number of contract done badges
verktyg
Liked 1,238 Times
1973 W. F. Holdworth Competizone
@verktyg, did you happen to notice the subtle curve on the rear brake bridge? Do you know if any Holdworths carried this detail? -Kurt
The eBay seller listed the bike as a 1973 Holdsworth Professional and wrote 3 pages of vainglorious BS claiming that's what it was. I knew it wasn't a Pro but I bought it anyway figuring that if I didn't like the bike I could part it out.
Original eBay picture
After much research, I concluded that it's most likely a 1973 W.F. Holdsworth Competizone frame as pictured in their 1974 catalog but in orange and blue Team Kit.
The catalog says the frame was "Built with good quality tubing..." whatever that means. It's fairly clunky so I suspected that it may have been built with Reynolds 531 0.9mm straight gauge tubes. The seat post is 26.8mm diameter. WRONG!
Two years ago when I changed to 3/4" shorter shoes, I tried to lower the seatpost. It wouldn't go so I tried to run a reamer down the seat tube. It wouldn't go any further either.
That's when I discovered the seat tube was cheap seamed gas pipe tubing with about a 1.5mm wall thickness!
You can clearly see the seam in the poorly reamed seat tube. I re-reamed it a further 1" down now all is well.
The lug work and other cosmetics are on a par with other Holdsworth products but why would they waste the time and effort on a gas pipe frame (the forks and stays may be Reynolds or some other lighter gauge tubing than gas pipe).
Even though it weighs a ton, the bike rides and handles superbly.
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
52psi
Quoted: 790 Post(s)
Liked 802 Times
Buy now, ask the rest of your questions later.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
For what it's worth, the saddle is an Idéale. I'll guess a model 90.
Quoted: 786 Post(s)
Liked 520 Times
Did you end up getting this one? Looks like a 60's 151 BCD Record crank, and FD with cable stop. A worthy bunch of components, if nothing else.
-J
-J
Bikes: 1970s Alex Singer, 1960s Peugeot PX 10, 1960s Bertin C37, 1973 Carre Bertin C 37, 1972 Carlton Kermesse, 1981 Peugeot PX 14 Super Competition
Quoted: 346 Post(s)
Liked 266 Times
+1 with Charles, it's a Holdsworth and probably an early 1970s Professional. I hope you bought it. Holdsworth Professional
