The A-Bike Plus is here!
Old 08-08-08, 06:29 PM
ilovebicycling
I've been waiting for the release of the A-Bike Take Two all summer and it looks like the first shipments are trickling in. If you are into folders, then check out the lightest/smallest one of them all!
https://abikecentral.com/forum/viewtopic.php?f=2&t=1308
ilovebicycling is offline
Old 08-08-08, 07:17 PM
OldiesONfoldies
Small wheels ARE better!
OldiesONfoldies's Avatar
I'm interested to find out what the PLUS is all about? I rode the A-Bike before and came away unimpressed with the ride. Those wheels just can't roll. I lend my brother, owner of an A-Bike, a Carry Me and he was surprised at the vast difference between those 2 bikes. Has the A-Plus closed the gap a little?
Its compact size still amazes though!
OldiesONfoldies is offline
Old 08-08-08, 11:29 PM
Dahon.Steve
Quoted: 261 Post(s)
Liked 11 Times in 10 Posts
I agree with the comment it does not roll well. You really have to work to get the bike up to speed. The plus should have been larger wheels, the size of the Carry me. They have the fold correct but the wheels make the bike unusable.
Dahon.Steve is offline
Old 08-09-08, 09:24 AM
mjw
There's a video somewhere where there's a race between a Strida and A-bike and the one who rides the A-bike can barely roll.
mjw is offline
Old 08-09-08, 09:37 AM
OldiesONfoldies
So what are the improvements on the A+? Curious...
Old 08-09-08, 10:13 AM
StephenH
Uber Goober
StephenH's Avatar
Quoted: 190 Post(s)
Liked 41 Times in 32 Posts
https://www.youtube.com/watch?v=kVVgsQt1DK4
StephenH is offline
Old 08-09-08, 10:29 AM
Lalato
Lalato's Avatar
Bikes: Dahon Curl i8
Quoted: 40 Post(s)
Liked 10 Times in 6 Posts
In watching that video, I think they were being really generous to the A-Bike. It's obvious that the guy is pedaling his ass off... while the woman is going at a pretty leisurely pace.
--sam
Lalato is offline
Old 08-09-08, 10:34 AM
mulleady
The Metropolis, UK
--sam
Exactly!
The Strida or Carryme well exceed the A-bike for riding a few miles or engaging in multi-mode computing.
mulleady is offline
Old 08-09-08, 01:20 PM
Amuro Lee
Amuro Lee's Avatar
Bikes: A-bike, Strida & ,etc.
Are you sure that both tyres of the A-bike had been inflated up to 90psi when you were riding it? Tyre pressure does affect the rolling performance of an A-bike very much.
Amuro Lee is offline
Old 08-09-08, 07:41 PM
Dahon.Steve
Quoted: 261 Post(s)
I'm 5'7 and had to extend the seat post BEYOND the limit! If you look at the video, the rider does not have full leg extention which is why the A-Bike is uncomfortable to ride. On top that, the wheels do not roll well even IF the tires are up to max pressure. If the tires are below pressure, it rolls even worse!
They need to make the A-Bike larger and the wheels bigger.
Old 08-09-08, 10:03 PM
ilovebicycling
I think all these criticisms of the A-Bike misses the point. The A-Bike was designed for short rides in urban areas. For instance, from the bus station to the office and back. It incorporates well into an intermodal scheme.
The A-Bike was not designed for speed/distance.
As with any design, compromises need to be made. In this instance, the designers wanted a very small, folded package. If you want more leg extension, bigger wheels, more gears, etc., then by all means look around. There are other folders that fit your needs nicely.
The A-Bike, being what it is, is very much an extraordinary design, imho. Sure, it does have a novelty factor to it, but that's one of it's draws. I want one.
Old 08-10-08, 03:18 AM
OldiesONfoldies
Many of us have tested the A-Bike and offer our comments and experience sincerely. Yes, the A-Bike is meant as a short commute bike but even then, it fails the minimum standard of being "rideable". Compare with a Carry Me or Strida and its deficiencies are stunningly glaring. No intention to tear down the A-Bike but thats the truth. So yes, please buy one by all means if you want one but prudence dictates that you at least try it vs the CM/Strida.
And if you don't agree with me, that's ok.
ps: So what are the improvements with the APlus? Doesn't anyone know? Better wheels will certainly be needed.
Old 08-10-08, 03:52 AM
OldiesONfoldies
OK, here's what I found out abt the A-Bike PLUS. Wheels still the same. Bummer...
https://abikecentral.com/forum/viewtopic.php?t=987
The new version has…
1. A newly strengthen leyshaft.
2. An improved freewheel assembly.
3. Strengthen alminium tubing.
4. A new air-sprung cushioned saddle.
5. A smoother drive mechanism.
6. An improved sports carry bag.
Old 08-10-08, 08:22 AM
geo8rge
switching to 8" wheels would require a redesign of the frame for it to fold correctly. This is also why Strida cannot produce a 20" version.
geo8rge is offline
Old 08-10-08, 11:26 AM
datako
I rode the original A-bike about 50 yards. That was enough for me. I was underwhelmed, it is only fit for very short distances at low speed and it is less hassle to walk short distances briskly rather than have to carry and unfold the A-bike.
It's the sort of thing that seems like a good idea until you unfold it and ride it.
datako is offline
Old 08-10-08, 12:19 PM
mulleady
The Metropolis, UK
Whereas the Strida is a totally different proposition.
What are peoples views on the Pacific Carryme? I know makeinu is a keen supporter and Somnatash desires one
mulleady is offline
Old 08-10-08, 05:59 PM
OldiesONfoldies
In a nutshell, the CM rides as well as the Strida. Similiar one speed gearing - abt 50" though the Strida seems to glide better, maybe a tad faster. CM less stylish too. But the CM "transfers" power more effectively due to a chain drive. It folds smaller and able to carry loads via a rear rack. I think for multi-modal commuting, the CM pips the Strida and the A-Bike of course. But the Strida is one stylish bird!
Old 08-10-08, 06:06 PM
jur
Quoted: 321 Post(s)
Liked 7 Times in 6 Posts
Looks like the CM has a very low BB, way too low for my liking...?
jur is offline
Old 08-10-08, 08:39 PM
OldiesONfoldies
BB works fine for me but I guess if you're above 5'10", the CM wont suit you unfortunately.... think its target market is primarily Taiwan & Asia. But George Lin, ever the inventor/entreprenuer, may consider a CM for taller guys.
Bear in mind that the CM is designed for brief commutes. But I have done a 40km ride on it... and live to tell the tale
Old 08-11-08, 05:03 AM
Amuro Lee
Amuro Lee's Avatar
Let me compare the CarryMe with the A-bike briefly.
https://www.bikeforums.net/showthread...=277444&page=3
Performance:
The running speed, stability, rideability and sturdiness of CarryMe are much better than the A-bike.
Foldability:
The speed and convenience of folding of A-bike are much better than the CarryMe. The A-bike takes less than 10 seconds in folding or unfolding. My neighbor takes 30 seconds to 1 minute to unfold and secure all the locks of his CarryMe DS each time.
https://www.youtube.com/watch?v=wd0gzgdw1nY
https://www.youtube.com/watch?v=6PxP8tMqUW4
Weight:
A-bike weights about 5.5kg and CarryMe DS weights 8.8kg including the speed-drive.
Portability:
You can carry the folded A-bike by grasping the stem and take it everywhere or put it into the backpack;
The folded CarryMe have small wheels at the bottom and you can tow it on smooth grounds.
Folded Size:
The folded size of A-bike is 67cm x 30cm x 16cm;
The folded size of CarryMe is 89cm x 30cm x 27cm.
Side by side comparison:
Storage:
CarryMe
A-bike
Old 08-11-08, 06:02 AM
OldiesONfoldies
Thks for the comparision Amuro! Yr info is pretty spot on.
Old 08-11-08, 07:06 AM
gganio
Bikes: Several bicycles
VERY Beautiful posting!
Pics of portable bikes at work..
Is anybody interested in contibuting to a Wikipedia Article that I started some time ago about portable bicyles:
https://en.wikipedia.org/wiki/Portable_bicycle
More authors is way better that only one author.
Performance:
Foldability:
Weight:
Portability:
Folded Size:
Storage:
CarryMe
A-bike
gganio is offline
Old 08-11-08, 12:27 PM
Amuro Lee
Amuro Lee's Avatar
I think one author can maintain the style of the article in same tune. (The truth is, I'm a lazy guy. )
However, you can use my information and photos which I posted here and on abikecentral.com.
Thanks for your effort on writing articles about bikes on the Wikipedia!
Old 08-12-08, 06:54 AM
makeinu
I just found this new Carryme blog:
https://carrymeadventures.wordpress.com/
Yeah, there comes a point of compromise where you can't beat a good pair of running/walking shoes. I haven't tried the A-bike, but I'm currently not interested because I have no need for a smaller fold than the CM and since the CM rides and fits me so well I don't mind throwing money at it to make it lighter.
It is very low. I would like to fit shorter cranks on mine to reduce pedal strikes (in addition to saving weight and improving spinning).
Last time you posted this I didn't know, but I just found out that the 08 Carrymes have a fiddly Brompton-like latch in the front as opposed to a quick "quick release" lever. So now I understand why it takes your neighbor so long.
...also including front/rear rack, mudguards, average "stock" seat (ie heavy), kickstand, etc. Easy to lose a kilogram just tossing extras and another kilogram with simple upgrades (carbon seatpost, carbon stem, ultegra brakes, etc).
Folded Size:
Just a note: the Carryme is not completely folded in the picture and it looks like it's about 30cm taller than it would be if completely folded.
makeinu is offline
