Play between fork slider and stanchion, is it safe to ride?
Will the rocking cause any damage or break the fork? This is for a cheap commuter bike. Weighing between leaving it alone or repair it, depends on urgency and ease of repair. How to troubleshoot and which replacement parts to buy for this issue?
If it's something actually worth servicing its better to replace the bushings relatively early, but for a cheap bike run it. You'll almost certainly be too annoyed by the play before it's unsafe.
If I am to switch to a rigid fork, what information do I look for in the fork? It's a threaded fork, and I am wondering how long the steering tube needs to be to fit the frame.
Quoted: 1074 Post(s)
Liked 295 Times
You have:
Steerer tube diameter
Steerer tube length
Axle-to-crown on old vs new fork
Type of dropouts
Fork rake or offset
Type of brake mount
That’s not hugely important. Switching from a threaded to a threadless headset isn’t a big deal.
If you can’t manage that, it would seem unwise for you to attempt a fork switch.
I don't know what to do with threaded fork if it's too long. Will I need to cut the steer tube afterward? How do I fix the threading? What if I couldn't find a threaded fork that's as long as my current one? What's the minimum length I need to secure it to the headtube?
With threadless forks, I just need to make sure it's equal length or longer and then I can get away with using spacers to adjust height and not having to cut the steer tube, can't do that with threaded forks.
Liked 295 Times
Preferably you find one where the threaded length you need fall inside the range of the fork. Otherwise, you need to find a shop with the die to extend the threads.
I’d screw on a worn top race to the cut line, do the cut OUTSIDE the race. File smooth using the race as a guide, then unscrew the race. A few more strokes of the file to take the edge off and call it done.
2) find a frame builder willing to replace the steerer
3) find a general metal fabricator willing to lengthen the steerer. It isn’t entirely reckless if you fab an inner strengthening sleeve to support the joint.
Look at what you have and figure it out from there.
Although if you get an uncut steerer, you’d probably want to trim that too.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Fork blades must be appropriately long for whatever wheel you intend to use. Brake mount(s) must allow whatever brake you intend to use function properly. Rake (offset) should be close to that of the original fork to maintain handling characteristics. Steer tube should be long enough to accommodate the stack height of whatever headset you intend to use. Steer tube can be longer; use spacers to take up any extra length. If excessively long, trim the steer tube, but it's best to err on the side of longer; it's easy to remove length, but hard to put it back. A longer steer tube allows for a wider variety of headset options if/when it is necessary to replace the headset.
Old fart
Liked 3,400 Times
