Wheel upgrade or new bike?
Hi guys, new to the forum and need some guidance. I've been road cycling for the last eight years and currently ride a 2016 Colnago CX Zero, Full Carbon, 105 group set. I was considering a new bike but not sure it's the correct route. My typical rides range from 25-65 miles and I'd love to shed some bike weight. Do you think it's worth getting a new bike or upgrading the wheels? I was looking at Zipp's 303 Firecrest Carbon Tubular Rim-Brake. Thoughts on which direction to take? Thanks in advance!
Likes For blakcloud:
Both. Buy a new super bike, electronic shifting, aero tubes, top-of-the line wheels. Use the Colnago as your rain bike. N+1, for the win. Or not. I have had great luck with Venn Rev carbon wheels. I have a set, 35 mm depth, on my lightest climbing bike and have, after 1 year, found them to be acceptably light (about 1400 grams for the pair), very stiff, pretty comfortable, very durable (I have only tweaked a couple of spoke nipples to bring the front back into true after bombing potholes. They also are wide enough at the brake track that they accommodate 25 and 28 mm tires with a non-lightbulb shape profile. They brake as well as any carbon brake track wheel I have used when it’s dry and are a bit sketchy in the wet. I recall paying $790.00 for the pair.
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
Why tubulars, for one? That's another ball game entirely, especially for every day riding.
No on Zipp for two. Way, way overpriced compared to competitors.
For under a grand (for under $600, even), there are 1400ish gram carbon clincher wheelsets, and even some aluminum ones if you want to go that route. Zero reason to buy Zipp anything, especially with their pretty awful hub problem history.
Either way, buying expensive carbon wheels solely for weight savings when you're already running a heavy bike with heavy components also doesn't make too much sense from a grams/dollars standpoint.
Likes For rubiksoval:
Quoted: 3949 Post(s)
Liked 7,295 Times
I think your present wheel set is an important, missing detail.
Likes For tomato coupe:
Where else can I shed weight then? The bike weighs 19.5lb. If I were to upgrade components then I might as well buy a new bike.
Quoted: 20810 Post(s)
Liked 9,456 Times
You're looking to shed weight, but to what end? If it's a performance-oriented goal for your present rides, you'll probably be disappointed.
Oh, hell!!! What am I saying? Of course you should spend another couple of grand to get a bike that weighs almost a full pound less than your current bike. Sure. I've done it, and it's very satisfying, until I really think about it.
I don't know what size guy you are, but if your bike is sub-20 pounds, any bike weight gains are a low percentage improvement. Can you realistically lose 5 pounds of body weight? Wouldn't that be a better strategy than spending a couple thousand dollars more on a bike?
Quoted: 1067 Post(s)
Liked 259 Times
I would keep an eye out for something like a second hand Giant TCR Advance Pro, rim brake with Ultegra.
Sub 16lb, and reasonable carbon clincher wheel set standard.
Bikes: Trek Domane SL7 Disc, Cannondale F29
Quoted: 388 Post(s)
Liked 324 Times
While I also suffer from "weight weenie-ism", the reality is that shaving a little off the bike really doesn't make that big of a difference unless your daily ride consists of riding up Mount Everest. Aerodynamics and comfort will likely result in more speed gains than reducing weight on the bike.
Liked 7,295 Times
Liked 7,295 Times
Better wheels could get the weight to down to 18 lbs., and upgrading to Dura-Ace should get it down to 17 lbs. This may or may not be cheaper than upgrading the whole bike.
Quoted: 6193 Post(s)
Liked 4,808 Times
That frame is already a pretty light frame..... I think. So with a component upgrade and possibly wheel upgrade you might shed a couple pounds. Worth it? I don't know.
Is one more bike already built with newer and higher tier components better? Or is not having one more bike better and just spending more money and having extra parts taking up space?
Unless you bike in a very hilly area, I would focus more on aero and rolling resistance than weight. The question is - Do you want a lighter bike or are you trying to improve performance? You'll get more performance gains from improving what you already have, from a bang for the buck perspective.
I would go with aero wheels, latex tubes, and a low rolling resistance tire. For the wheels, if you don't want to spend too much, check out the HED Jet 6/9+ from mybikeshop.com or Flo carbon wheels. For tires, I would consider the Continental GP5000.
Then consider other low hanging performance fruit. Are you wearing tight fitting cycling clothes? Could you adjust your fit to lower the front end?
If you want a nicer experience, consider upgrading to Di2. Once you have electronic shifting, you'll never go back.
As for the weight of your bike itself, it isn't light. My Specialized Allez Sprint (aluminum frame bike) weighs 18.5 lbs in Ultegra trim. But you're going to spend a lot of money lose a few pounds on the bike. You can spend that money towards actually making you and the bike faster. But nothing wrong with N+1.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
Can you even get a new bike? Want you want may not be available for delivery until next spring.
Liked 7,295 Times
That's not a bad idea. The internal cable routing on a CX-Zero looks nice and clean, but it noticeably degrades the shifting of a mechanical group. I liked the bike a lot better after I switched to electronic.
If you want a nicer experience, consider upgrading to Di2. Once you have electronic shifting, you'll never go back.0+
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Quoted: 388 Post(s)
Liked 324 Times
Likes For PoorInRichfield:
Thanks for your feedback. I was hoping to improve performance by upgrading to aero carbon wheels (which would result in a lighter bike) as the Shimano RS010 wheels seem pretty heavy. I've adjusted the stem position in the past to get me lower in the front but the seating position became uncomfortable after 50+ miles. I already wear tight-fitting cycling clothes. Also, I find the 105 groupset to be sufficient for the type of riding I do. I usually have a 17.5 mph average pace.
If you decide a get a new bike, I wouldn't prioritize weight - I would get a more aerodynamic frame.
