Second wheelset for road use?
I'm a road guy that just bought a Cervelo Aspero for a bit of dual purposes; 1 wanted to learn to ride gravel (as we go into fall, it seems to be the thing to do) and 2 for travel to Mexico with (horrible roads there....).
So... love the Aspero, if you've ever ridden an R3, the geometry works out the same (R3 has shorter top tube, but longer stem...).
The bike came with Gravel King SK Sport (38mm) tires on hideously heavy rims (Alexrims Boondock 7D.. 1kg/RIM). Riding out to places and back is a bit of bummer due to the slow heavy wheels (the slight undergearing from GRX cranks is no big deal). I'm thinking that I could really love this bike as a road bike if I put it on a diet and had a second set of wheels with some much lighter rims and faster tires. I'm thinking that I'd throw some GP5000's @ 32mm onto some reasonably light/aero rims (Hunt Aero Wide 34s?) and drop about three pounds off the bike and lose some rolling resistance as well.
Anyone else run two wheelsets? Pros? Cons? Any other input? I'd like to keep the wheelset to <1000 CAD$ ($650 USish), but if someone can suggest better, I"m open.
Thanks.
Thanks.
Sunshine
Quoted: 11012 Post(s)
Liked 7,542 Times
Yes 2 wheelsets is very common on modern gravel bikes.
Im lazy and would just end up getting a lighter wheelset and use that for both road and gravel. Looking at multiple rides in similar area on similar foot climb routes, I average like 1 mph faster on pavement than gravel using what is effectively the same wheelset(different bikes).
43mm actual gravel tires and 31mm actual road tires.
It just wouldn't be worth me swapping back and forth multiple times a week. But again, I'm lazy.
Quoted: 4827 Post(s)
Liked 3,951 Times
Minor point - 1 kg/wheelset, not!! per rim. (I had to look up this 2 pound rim.)
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
Yup, I road bike my Revolt with a second wheelset with 32mm GP5000s, love it. I'm running FFWD F3ADs, DT350 hubs, 19mm internal, 1560g, $450 from PBK. Def noticeably faster than my gravel wheelset, even with reasonably fast gravel tires.
Quoted: 1873 Post(s)
Liked 692 Times
Honestly, this has been asked a million times. You're on the right track, but you'll find the biggest consideration is getting the rotors and cassettes to line up perfectly when you switch.
2019 Salsa Warbird
2019 Salsa Warbird
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Yup, that is what a lot of us do. Realistically most of your speed and ease of use comes from the drastically lower rolling resistance of the 32mm GP5000, doubt your going to see a huge difference saving 500 grams on your wheels, but in your case lighter tires & wheels together are going to drop more than a 1lb of rotational weigh and certainly spin up faster.
(There has just been a plethora of data these days saying weight doesn't really matter that much as people think (its just easier to measure)).
