Mismatched componants
Old 09-20-20, 09:55 AM
SammyJ
SammyJ's Avatar
Bikes: 2012 Caad 8 105; 1994 Trek 5500
Quoted: 32 Post(s)
Liked 47 Times in 18 Posts
First, I am working on a recumbent bike.
The front crankset and derailleur are Shamino 105 two rings, my trigger shifter is a Deore 3 position.
I have a huge travel before it will shift up.
I need a new trigger shifter set up for the 105 derailleurs.
I have NEVER regretted going on a ride;
I have often regretted not going when I could have!
I am grateful for the headwind that challenged me today!
I am grateful for the tailwind that helped me go fast!
Clydesdales and Athenas Strava Club
https://www.strava.com/clubs/clydesda...bikeforums-net
SammyJ is offline
Old 09-20-20, 10:03 AM
dabac
Quoted: 1074 Post(s)
Liked 295 Times in 222 Posts
Shimano use different actuation ratios for their road vs MTB front derailers.
Don’t know of any easy way to get it to match.
dabac is offline
Likes For dabac:
Old 09-20-20, 10:05 AM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1794 Post(s)
Liked 1,268 Times in 875 Posts
Flat bar road shifter.
Bill Kapaun is offline
Likes For Bill Kapaun:
Old 09-20-20, 10:11 AM
andychrist
Devil's Advocate
andychrist's Avatar
Bikes: Fuji Del Rey, Bacchetta Giro 20, RANS Stratus XP XL, RANS Stratus XP XXL, RANS Stratus LE XL
Quoted: 77 Post(s)
Liked 50 Times in 38 Posts
Just loosen the clamp on your derailleur and pull the cable through until the cage aligns with the inner ring, then retighten. No need for a new shifter.
andychrist is offline
Old 09-20-20, 10:39 AM
alcjphil
alcjphil's Avatar
Quoted: 1819 Post(s)
Liked 1,693 Times in 974 Posts
If the limit screw is properly adjusted the inner ring should already be aligned. Mountain bike shifters do not work properly with road front derailleurs
alcjphil is offline
Old 09-20-20, 11:48 AM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
Originally Posted by alcjphil
If the limit screw is properly adjusted the inner ring should already be aligned. Mountain bike shifters do not work properly with road frone derailleurs
Perhaps not, but the OP only has to make a single shift work, so they may be able to be adjusted well enough to do the job. Otherwise flat bar road shifters as suggested by Bill Kapaun will surely work.
dsbrantjr is offline
