Head set bearing race
Bikes: Litespeed Obed, Cannondale Scalpel, Spcialized AWOL, Litespeed Solano, Cannondale Synapse
I have a new suspension for with a 1 1/8" steering tube. What is the best way to install the head set bearing race? I don't have any special tools. Thanks!
Quoted: 5787 Post(s)
Liked 2,580 Times
If the frame cups are already in place, you can make a slide hammer out of a piece of pipe. In case the pipe is a sloppy fit, protect the race with a washer that's a closer fit on the steerer so you're driving by the inner edge only rather than bearing contact area.
Or if there's a local bike co-op, bring the fork, and a small donation and borrow their slide hammer.
BTW- you don't have to get the bearing race home, as long as it's started, riding alone will settle it over time, but you'll be adjusting your headset until it does.
FB
Chain-L site
FB
Chain-L site
