I think Shimano is finally developing a bicycle gearbox!
Hello all, I haven't been on here in years. I used to be a regular poster but now I am the Assistant Editor at BikeRadar.com and have to look after those forums!
I've been doing some digging and have found a patent that strongly suggests Shimano is pretty far down the line developing a gearbox for bicycles.
This is, obviously, fairly huge news, and thought it may be of interest to you all.
Let me know what you think!
Surely that's just an electric drive such as is fitted to many e-bikes. Electric motors would need to be geared down to drive cranks.
No, it's not. It's basically an encased compact derailleur system with cassetes on both ends, at least one of them sliding in order to maintain a straight chainline.
Some Weirdo
Bikes: '86 Schwinn Prelude, '91 Scott Sawtooth, '73 Raleigh "Grand 3"
Quoted: 223 Post(s)
Liked 141 Times
I'm not buying into the hype.
Somewhere, a village is missing its idiot.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Likes For ThermionicScott:
Sunshine
Quoted: 10963 Post(s)
Liked 7,489 Times
Cool?
So would this be good for commuting since it would be enclosed? And for MTB or would it not shift fast enough and be a tank in weight?
So far I havent been riding and come upon a situation where I wished I had all the gears located in the bottom of the main triangle, so I havent explored this tech at all.
Likes For Gconan:
Callipygian Connoisseur
Quoted: 564 Post(s)
Liked 350 Times
Meh. What's the date on that? The patent world is full of designs which never see the light of day. This could be something from long ago with no real intention to develop. Not that I wouldn't be interested in a Shimano gear box system, but I can't get too enthused about vapor (hard)ware.
-Kedosto
-Kedosto
Troublemaker
Bikes: Yes. The more the better.
Quoted: 46 Post(s)
Liked 44 Times
-Kedosto
-Kedosto
https://patentimages.storage.googlea...90011037A1.pdf
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
One thing about the cassettes is puzzling. The two end combinations (19-41 and 41-19) wrap a total of 60 combined teeth. All of the others wrap 58 teeth. It seems goofy to add that extra bit at the ends when leaving it at 39 would keep the same chain length for all combinations, reducing or eliminating a DR-like tensioner. I'm sure the motivation is to get the same range as a standard DR system but it seems like a lot to give up, extreme even. Do you think that there's some other reason for it?
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
-Kedosto
-Kedosto
I am awaiting comment from the big S and will update the article as and when I hear back.
Bikes: Nashbar Road
Liked 341 Times
The tensioner drawbacks would be: increase in drag from the drive, an extra moving part to wear out or malfunction, an extra complication in the engineering and design, extra weight, and I could see it possibly reducing the persistence of chain lube. Intuition tells me that Shimano has an additional reason for that design. I suspect marketing (eg, has the *same range*)
Maybe they couldn't make the shifting work without the tensioner?
Liked 2,011 Times
My first thought also, and the chart listing ratios seems to imply that, but the ratio with the logical 39 tooth is 2.05 compared to 2.15 with the 41. It seems like a lot to give up for a small improvement in range.
Bikes: Nashbar Road
Liked 341 Times
Still it's double the amount to take up with just the extra 2 teeth at the extremes which still bugs me.
Liked 2,011 Times
I'm not an engineer, but it looks to me like this thing could have less friction than a standard derailleur drivetrain - straight chainline, no sharp turns around jockey wheels, no tiny 11 tooth cogs...
Quoted: 18375 Post(s)
Liked 4,510 Times
I doubt this will be going anywhere. It will be locked up in patent for the next 20 years.
But, I just don't see any significant advantage of doing a chain sprocket shifting system over say planetary gear system.
I have thought about a triple gearing system on a Velomobile. But, that has quite different needs as a whole.
This thing isn't just a seven-speed sliding cassette paired with a seven-by crankset.
Liked 4,510 Times
So one ends up with more moving parts.
By going with 19/41 X 41/19, I think it does give a pretty good gearing range, but initially only 7 speed with the equivalent of about 8 teeth between gears. That will be HUGE.
Of course the benefits of internal gearing may outweigh the costs for some applications.
Liked 2,011 Times
The problem is that one still has the double internal sprocket system, plus the chain (or belt) back to the rear of the bike. And, with suspension, also the need for a chain tensioner.
Quoted: 4806 Post(s)
Liked 3,928 Times
Interesting. Basically an enclosed and perfect chainline 1X13, ie say, 52 x 11,12,14,16,18,21,24,27,32,36,42,47,52
Maybe a little heavier, maybe a little more friction than the conventional 1X when the 1X is squeaky clean and in a good chainline, but better on friction all the rest of the time. No chainring to smash MTB'ing. No rear derailleur to trash. Belt is far off the trail and should never contact anything. Nothing but a simple belt to keep clean. Drive trains that last many times longer. Yes, a tensioner would be needed for (most) suspension bikes but it can be really simple since the belt chainline never changes.
I like that the key 12,13,15,18,20 ratios are all there but I would never have to ride on those tiny cogs. The small 19 is so much better than a 11! As pointed out by the OP, big cogs and perfect chainlines are the way to go if you aren't wedded to derailleurs. I ride both derailleur bikes and fix gears. Yes, I can feel the difference easily.
Ben
Ben
Quoted: 1062 Post(s)
Liked 665 Times
You can get more detailed info about a patent, such as the so called "prosecution history" by paying for a service that a patent law firm might have at their disposal, which can sometimes shed light on the "why" of patents that are hard to understand on their own. And of course it goes without saying that this is a patent application, not a patent.
In terms of a drive system with gear ratios that allow for perfect chainline, this is used for belt driven power tools such as drill presses, to give them multiple speeds with a single length of belt.
Likes For Gresp15C:
A belt can take this kind of advantage of "constant length" gearing. A chain cannot.
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 321 Times
Move over Kindernay. We now have a NEW contender for the STUPIDEST bicycle idea of ALL time.
CONGRATULATIONS. LOL hahahahahahahahahahaha
Bikes: Nashbar Road
Liked 341 Times
It is still a chain. In order to be shiftable, a chain always requires extra slack and a tensioner. "Keeping it the same length in all gears" would not in any way eliminate the need for that.
