Any way to warm up a bike faster when you bring it inside?
Quoted: 120 Post(s)
Yep, bringing it/keep it inside is probably enough of an answer. It's aluminum. It probably takes less than an hour to warm up enough to room temp. The other other thing I thought of was pointing a space heater at it.
It does make a different. It's a lot easier to ride when the weather warms up. I'm guessing the oil, tires, and everything just work better at warmer temps.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Stuart Black
Stuart Black
Quoted: 120 Post(s)
It's the bike for sure. I'm inside each time. Weather can be the same. If the bike is outside, it's more sluggish. If it's inside, it's normal.
These are about ten minute bike rides, so the bike would be cooling down after it comes out from inside, but it's not matching outside temps in ten minutes.
It also hasn't mattered if I'm fully bundled up. I can be sweating inside too much clothing and this still happens.
Liked 7 Times
OK...injured my neck* several years ago 'cause, you know, I do my own stunts on mountain bike, tho' that's never the plan.
Anyway, I use those microwavable 'beanbag' things most mornings to apply heat to the neck. Nuke 'em 3 minutes and they're toasty. Get 'em on Amazon.
Try those things on the saddle and bars.
