Do you run a rack on your folder?
Old 01-26-14, 01:10 PM
Sixty Fiver
Bicycle Repair Man !!!
Sixty Fiver's Avatar
Bikes: See my sig...
Quoted: 67 Post(s)
Liked 129 Times in 96 Posts
I like a nice rack.
The MEC rack bag I often use doubles as a backpack and carries all the daily essentials quite nicely and serves well as a 4th bag when I am touring... it will be become the 6th bag after I mount up the front racks and panniers.
In the winter I don't mind using a messenger bag or backpack as heat / sweating is not an issue but most of my daily drivers are racked out or will get racks built before spring.
Sixty Fiver is offline
Old 02-04-14, 09:54 AM
dazza1985_49
Hi - I have a rack on my Brompton P type which I regularly use with the Brompton rack bag. However, after cycling about 1800 miles since my last wheel rebuild I have now had to rebuild the rear wheel again, where as the front is fine. Just wondering what effect the rear rack bag has on rims..? I don't overload it, just mainly have a shirt, trousers, towel and iPad mini in there. Anyone else found that they are having to replace their rear wheel more regularly when using a rack bag?
dazza1985_49 is offline
Old 02-04-14, 10:48 AM
Rob_E
Rob_E's Avatar
Bikes: Downtube 8H, Surly Troll
Quoted: 303 Post(s)
Liked 22 Times in 21 Posts
The weight you are talking about carrying seems insignificant when compared to rider weight. Rear wheels are under more stress because more weight is carried there whether you have a rack bag or not. They can also be weaker if you have a gear cluster in the back, because then wheel will dished when built.
Knowing that I am a heavy guy who carries too much crap, I prefer to put a touring load on the front, which has comparatively less weight on it to start with, but I would think nothing of carrying your load on the back. It's probably less than what I typically carry in my trunk bag. Having to rebuild the wheel twice in that number of miles tells me that you might want to make certain the wheel you're using is rated for the weight you're subjecting it to, up the spoke count, and/or find a new wheel builder.
Rob_E is offline
Old 02-04-14, 12:01 PM
dazza1985_49
Thanks Rob. I'm heavy at 100kg but within Brompton's max rider weight so will put it down to wheel build and keep an eye on it.
Old 02-04-14, 01:22 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Brompton's new directional drilled double wall rim is rear specific.. & better, I Expect,
NB keep an eye on the spoke tensioning ..
though they are still thick and short beefy spokes maintained state of the wheel is not self executing.
fietsbob is offline
Old 02-05-14, 02:40 AM
bhkyte
bhkyte's Avatar
Bikes: 2X dualdrive Mezzo folder,plus others
Quoted: 107 Post(s)
Liked 3 Times in 3 Posts
took my rack off my brompton. its small and most people just use the front bag most of the time anyway. I kept breaking srunts at £5 a pop due to pressure from closing my dahon androes stem extender.
Clean look and weight loss suits road race sytle conversion anyway
https://www.bikeforums.net/showthread...k-or-mudguards
File Type: jpg
bhkyte is offline
Old 02-10-14, 12:00 PM
bjorke
Idealistic Troublemaker
bjorke's Avatar
Bikes: Friday, Brompton, Soma, Fuji, Haro, No_Name...
I have a rear rack for my Friday but it messes with the fold so it's most left off. The "under rack" bag is cute but gets FILTHY.
On the Friday, a Travois trailer is the best.
On my Soma minivelo, I run a front rack + rando bag and a Carradace "bag man" rear with a largish saddle bag. And then STILL carry the laptop in a messenger bag.
bjorke is offline
Old 02-10-14, 12:36 PM
fietsbob
Bikes: 8
FWIW, Older Burly Flat bed with my Pocket Llama, all 4 tires are 406 .. 20"
(Current one uses 16" like BoB trailers)
The Bi Fri, Suitcase trailer and the Travoy are 12.5"
Carry Freedom City, a flat-folding trailer, uses 12.5 wheels too .
fietsbob is offline
Old 02-10-14, 01:17 PM
GoodShipRuffles
Good Ship Ruffles
Bikes: Brompton!
Without a front bag I find there's a distinct tendency for the front wheel to lift on my Brompton when pulling away from lights.
That said the wind resistance seems to be increased out of all proportion. Sometimes I pull out to overtake a bus on London bridge only to find myself going backwards.
GoodShipRuffles is offline
Old 02-10-14, 02:49 PM
DoubleDiamonDog
Quoted: 14 Post(s)
I have Brompton, with no rack and just use the T-Bag on the front. I had seriously considered a rack but as I talked it through with the dealer - how I planned to use the bike - he suggested that I not get a rack and just use the front luggage carrier. Having said that, for other Brompton owners and other owners of folding bikes, a rack can make good sense.
I were the OP, since he doesn't use the rack I would remove it but hang on to it in case I found that removing it didn't provide the advantages I imagined.
DoubleDiamonDog is offline
Old 02-10-14, 02:54 PM
DoubleDiamonDog
Quoted: 14 Post(s)
Originally Posted by cplager
I do regularly use my rack, but it's a seatpost rack:
I use it for one or two panniers and find it works well (as long as I've clamped it down tight enough). It's very easy to pop off if I don't want it. It claims a weight limit of 10 Kg.
I find that it's a great choice for those of us who don't want to "permamently" add a rack (or those who don't have the mounts).
Sorry to divert off topic for a sec here but Charles, I was wondering how you like having the drive wheel in front, as a the "steerable" wheel on your recumbent. In my "imaginings" I have thought that shortening the drive train to the easier, more direct connection to the front wheel would have advantages but wondered how that would work with steering. I have thought that it would not be an issue at speed but but slower more intricate maneuvering might be a bit compromised.
Old 02-10-14, 06:01 PM
cplager
The Recumbent Quant
cplager's Avatar
Bikes: 2012 Cruzbike Sofrider, 2013 Cruzigami Mantis, 2016 Folding CruziTandem
Quoted: 28 Post(s)
Liked 8 Times in 6 Posts
Your "imaginings" are pretty good. At speed, I can ride for extended periods of time with no hands, so it really becomes a positive. At very low speeds, it can be noticeable and can be a little on the annoying side (but the speed at which this is an issue is still getting lower and lower). It does take a little getting used to, but once you do, it's fantastic.
cplager is offline
Old 02-10-14, 06:44 PM
DoubleDiamonDog
Quoted: 14 Post(s)
Going a step further with this I have thought that a front wheel drive recumbent with a simple rear wheel electric hub drive motor, with low centrally mounted battery as you obviously have room for, would be a very intriguing rig. Aerodynamic, simple and with additional power for what I understand can sometimes be an issue - climbing - for recumbents. I have neither a recumbent nor electric bike but "imagining" can be fun.
Old 02-10-14, 07:55 PM
wahoonc
Membership Not Required
wahoonc's Avatar
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times in 14 Posts
I run racks on most of my bikes, including the folders. My Twenty's came with racks, I bought racks for my Dahon Classic III's.
I typically use a Banjo Bros rack top bag with drop down panniers. They do work with the 16" wheels... barely. But is still comes in handy.
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"
_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"
_krazygluon
wahoonc is offline
Old 02-10-14, 08:10 PM
smallwheeler
smallwheeler's Avatar
Quoted: 151 Post(s)
Liked 10 Times in 8 Posts
Originally Posted by wahoonc
aaww yeaaah.
smallwheeler is offline
Old 02-15-14, 01:13 PM
bjorke
bjorke's Avatar
bjorke is offline
Old 02-16-14, 09:04 AM
downtube
downtube's Avatar
Bikes: Many Downtube Folders :)
Quoted: 282 Post(s)
Liked 24 Times in 17 Posts
I never use a rack on my 9FS. I do not normally carry much ( if anything ). I use a backpack when necessary.
Om,
Yan
Designer of Downtube Folding Bike
Ph.D. Temple University ( Math )
Biked across the USA twice
Semi-active chess player ( two time Bahamas National Champion )
Sivananda ( Bahamas ) Trained Yoga instructor ( 2013 ) and ThetaHealer since 2013
Bicycle delivery worker for Jimmy John's. Delivering is the best workout I have ever had.
downtube is offline
Old 02-22-14, 06:50 PM
bjorke
bjorke's Avatar
(with the bag)
bjorke is offline
Old 02-23-14, 06:35 PM
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
Liked 118 Times in 99 Posts
Originally Posted by bjorke
(with the bag)
With the front rack being pretty small, out of curiosity, what keeps the bag from falling down?
Velcro straps at the bottom of the bag?
Winfried is offline
Old 02-24-14, 10:55 PM
bjorke
bjorke's Avatar
Yes, it's the Acorn boxy rando bag, which has velcro and side straps and a rigid hidden body that keeps it upright even without a decaleur (which is good for commute riding).
<- not mine
bjorke is offline
Old 02-28-14, 04:39 PM
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
Thanks for the info. I didn't know smaller porteur racks were called decaleurs.
Winfried is offline
Old 02-28-14, 09:04 PM
smallwheeler
Quoted: 151 Post(s)
(with the bag)
sweet...
Old 03-04-14, 09:38 AM
werks
Bikes: Bike Friday ( 2ea), Specialized TriCross Comp, Cannondale M900, Cannondale ST400 (1985), TREK T 900 Tandem
werks is offline
Old 03-04-14, 10:32 AM
fietsbob
Bikes: 8
the Bike Friday includes braze ons , on that fork, is a 4 point mount for their front rack . ..
They connect with a front cross Tube , the racks pack Flat for all things to go in the suitcase for travel .
fietsbob is offline
Old 03-10-14, 09:58 PM
beamercub
Here is my Tern Link C7.. I love the Biologic luggage truss that is added to the front frame above the fork.. It enable the cool bag to click on or off with a key lock !! Best part it doesn't effect steering at all because it's on the outside tube... I also love the Biologic rear rack.. It enables me to get creative with what I might be hauling.. I recently took my luggage truss and rack off because I took the big with me to San Francisco.. I felt naked without them..
File Type: jpg
beamercub is offline
