60 miles ~3400 calories burned correct???
base training heretic
Bikes: Cervelo P3C, many Litespeeds
The best comparison would be to use the HRM on an outdoor ride with a powermeter. HR is likely to be elevated indoors not to mention the problems comparing HR between two different rides.
I constantly see ridiculous calorie expenditure numbers on the web forums, the result of Polar OwnCal and online calculators and other charts.
Ric Stern has said they're basically random number generators and he's right.
Originally Posted by pacemaker
3400 kcals in 4hrs? With an average speed of 17mph that would be 14 kcals/min, which seems reasonable. My avg speed is ~17 mph which converts to ~16 kcals/min (Ht 69", Wt 160#, Age 40)I use a Polar HRM and they are accurate as long as the info you put into them is accurate. Some here have said there is no way to calculate kcals accurately. I tested my HRM against direct calorimetry by cycling on an ergometer at the same avg HR as a usual ride and the kcals burned was within 98% of my predicted kcals from my HRM; pretty accurate if you ask me.
OM boy
Bikes: a bunch
Quoted: 519 Post(s)
Liked 646 Times
Originally Posted by bmike
My 48 mile ride with 3800 feet of hills showed 4200 calories burned, from my HRM. I was out forever - 3 1/2+ hours, and it was 32 degrees. (This ride is usually a sub 3 hour ride!) My HR was in the upper aerobic for most of the ride, and near LT on some of the climbs. (I don't think the HRM takes temp into account for calories burned)
That said, I use CycliStats to record my rides, and the calories calc in the software is usually 1/2 of that from my HRM. Not sure which to trust. I don't really "count" calories, but I am curious as to how much I burned, just to know how hard I worked.
I weigh 185... and am continuing to drop... (shooting for 165 - 170)
Quite a bit less than your 4200 Kcal, even with consideration for the 20 lbs diff. I know we aren't 'comparable', but would think we'd be closer.
Breaking down the ride into 'climbing' and 'flat' (not really flat but 'handgrenade close' anyways) sections and pluggin into the https://www.kreuzotter.de/english/espeed.htm the total time ridden and Kcals came pretty close to my actual ride time and HRM Kcal number...
I think I like that online calculator...
Roadie
Bikes: kestrel
Originally Posted by supcom
I believe you have neglected to take into account the inefficiency of the human body. The formula you used is simply a units conversion. For cycling, we are concerned about the number of calories burned by the body required to generate a given amount of output wattage. The 850 calories/hr includes the waste heat generated by the body when doing work.
From the above could I say that a very inefficient rider produces less wattage (=power?) at a higher cal/hr rate than his efficient counterpart? In other words must wattage also take into account the inefficiency of the machine (human body)?
If so how is this factored in the calculations?
Bye Bye
Originally Posted by cyclezen
What params are used to set your HRM to get Kcals? I did basically the same kinda ride on Sat morning, up Gibraltar Rd around here. It's avg 8% grade with some longer pitches up to 12%, 3800 ft from the SB Mission to top. At ride start it was 36F in town, 32F on the hill, gusting headwind coming down the hillside on the upper 1/4, overall loop was 41.8 miles covered in 3 hrs 9 min, bike weighs about 23 lbs as was equipped, I'm at 164 lbs currently. We took it easy as the group was varied, and also rolled easy on the return leg. My HRM came back with 2942 Kcals for the ride... I was at mid-140s most of the way up, which is 75% of my MaxHR, best I can figure is I start going anerobic once I'm in the mid 160s.
I have a CicloSport HRM. I set my sex, weight and age?, it calcs the calories based on HR and time. My route was 3800' of climbing in a loop -2 decent climbs on each side, and the balance doing the New England Hills thing. Not much chance to cruise along. My HR was elevated most of the day. In the second half I really focused on keeping it below LT... but I knew I blew by that on a few good climbs. My average HR was 159.
I put the ride with estimated grade into the kreuzotter site and got numbers similar to the CycliStats results.
You need a new bike
Originally Posted by berts
Thanks for the input.
In the end, you have two tools that make different measurements. But neither measurement tells us the efficiency of the human body. To measure the efficiency, we would need to do something like measure the total heat produced by the body in generating various power levels. This could be done in a lab, but not on the road. So we are left with the tools that are available and apply some average loss factor to the data.
HRMs estimate calorie burn based on prior research to correlate heart rate to energy consumption. It is, of course, an estimate that may, or may not apply to a given individual. A good HRM that takes into account weight will probably be close enough for 99% of us. In my case, I use a Polar S720 and get pretty repeatable results for similar exertion levels. The data also correlates fairly well to overall estimates of calorie burn vs average speed I have seen for cycling.
Obviously, any simple table of calorie burn vs speed is going to be valid only for average terrain and weather conditions. Cycling up Mt. Washington is going to require much higher calorie burn than the tables would estimate based on your average speed!
Videre non videri
Bikes: 1 road bike (simple, light), 1 TT bike (could be more aero, could be lighter), 1 all-weather commuter and winter bike, 1 Monark 828E ergometer indoor bike
The efficiency of the human body for cycling is pretty much fixed at between 20 and 21%, for virtually every rider proficiency level.
Therefore, a simple power meter, provided it's accurate, will very precisely tell you the energy spent by a rider on any given ride. Just take the energy output recorded by the power meter and multiply by five.
Likes For CdCf:
OM boy
Bikes: a bunch
Quoted: 519 Post(s)
Liked 646 Times
big difference might be that my climb was one continous section and the descent was consistently long with pedaling only to pass each other as we played 'speed razor'... That long downhill makes quite a difference on heartrate. Don't believe I topped high 80's on any of the downhill sections - 10 miles of non-stop, no-sideroad-access descent is awesome fun! Then another 2 miles of limited access before easy rolling again.
The rest of the ride was mostly 2 up small ring 17ish mph with just a few small hill sections.
I checked the HRM at the descent base and was around 2,400 Kcals, which left about 500 Kcals to cover for the final 14 miles at 17avg - I guess thats about right.
I'll have to take note and compare what my Kcals are when I do shorter hills but keep them coming throughout the whole ride - be interesting to see if there's a diff.
Bye Bye
same params on my HRM - nashbar 1200 - which is a relabeled Reebok, I think.
Most of my rides here average 800 - 1000' of climbing per 10 miles. Up / Down / Up / Down depending on route. HR 80 on a downhill? Wow. If I even think about cycling my heart rate is around 100 - 110. I'll have to start tracking my RHR. (I usually do twice a week in the summer...)
Roadie
Bikes: kestrel
Thus the equation would be:
4.3 kcal/hr = 1 watt
instead of
.86 kcal/hr = 1 watt
therefore
850 kcal/hr = 197 watts which is a bit less than what terrymorse indicated.
Originally Posted by terrymorse
850 kcal/hr corresponds roughly to 236 watts.
It is interesting if indeed my body efficiency for cycling is the same as Lance Armstrong's (he just is capable of burning that much more energy). This brings up some intriguing physiological questions.
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Please correct me if i am wrong. I found that:
1 watt = 0.86042065 kilocalories / hr
or
1 kcal/hr = 1/.8604 = 1.16 watts
thus
850 kcal/hr = (1.16 * 850) watts
or about 986 watts
please correct me if I am wrong
or
thus
or about 986 watts
Videre non videri
I don't know exactly how existing power meters work, but I know how they could/should work.
I assume they record instantaneous power at frequent intervals, say several times every second. It's a simple matter then to find the area of the power vs time curve, which is the total "mechanical" energy for the ride.
(The body's energy expenditure would then be about five times that.)
So, I did mean energy, not power. Believe me, I know the difference!
Regarding the 20% efficiency figure...
Of course, I'm only repeating stuff I've read, but I suppose almost everyone else here is as well, so it's up to you to decide whom to trust...
half man - half sheep
Location: Big Mineral arm - Lake Texoma (Pottsboro, Tx)
Quoted: 9 Post(s)
Bikes: Many
Originally Posted by Doggus
Less power for speed for the weaker rider. I bring my wifes avg up, she brings mine down. I could avg that ride at 19+ on my own. Not sure where all this tandem folklore is coming from, I haven't seen it in real life. In our tandem club they're all slow. The singles leave us all in the dust. There's only one tandem team here that is fast and they ride a Calfee carbon fiber tandem...they can avg 21. Our best is 18. My worst on a single is 19. I sure hope our tandem gets faster..maybe the brakes are dragging
Craig
Quoted: 9 Post(s)
Originally Posted by Byk42
What tandem club are you on? From your profile, it looks like you're in the area of the Double DATES club. From what I remember, they have several fast teams. They had at least a half dozen teams that regularly do centuries at well over 20 mph average. I know a couple teams that even ride sub 4-hour centuries. But, maybe that's not your club.
Craig
Craig
I got about 3100 Calories for a 60-mile ride I did last weekend using the kreuzotter site. Using the online calculators I get anywhere from 2700-3600 Calories. The thing I can't figure out is how to account for elevation gain on the ride. Since it's a loop, you end up at the same point for a zero change in elevation and all the hills in between aren't included in the calculations. I guess I need a computer that logs total elevation gain, then average that out over the ride distance to get an average for "slope of road".
Then there's also wind to deal with and changes in drag based upon the attack-angle of the wind. A full-on headwind actually isn't the worse since you have a small frontal area while a wind from 30-50 degrees is the worse. Not sure how to incorporate that data into the calculators as well. I think I need to get a Powertap or SRM...
Bikes: Surly SteamRoller
Quoted: 42 Post(s)
Liked 53 Times
Originally Posted by LowCel
A great free website is Fit Day. That site helped me lose 50 pounds last year.
部門ニ/自転車オタク
Bikes: 2008 Blue T16, 2009 Blue RC8, 2012 Blue Norcross CX, 2016 Blue Axino SL, 2016 Scott Scale, Fixie, Fetish Cycles Road Bike (on the trainer)
VW
Envision, Energize, Enable
Quoted: 42 Post(s)
Liked 53 Times
Bye Bye
Originally Posted by TomM
How much drag is generated by the wind flowing around the body?
Bye Bye
darn cool technology on the bike.
i've looked at em. wish i could spend the $$... but can't see it in the near future.
Sorry to take so long to reply to your question. Out on business. I use the Polar F11. I've only had it since Xmas but I know the feedback I get from it is good for me and as long as you input the correct info it will be very accurate for anyone. Seems several post on this thread have tried to complicate a pretty simple concept as energy exp. Refering to efficiency; Lance is no more efficient than some out of shape couch potato when it concerns energy exp. Take Lance and a guy the same Ht, Wt, Age and body comp as Lance but in less shape: to go 5 mile on a bike they will each use the same number of kcals.
Bye Bye
Not informed enough on the body science to take this on... but it doesn't seem right. More in shape would seem to mean better tuned to burn energy where it counts. As you develop muscle and aerobic capacity I would imagine the tools the body uses has to crack open energy and turn it into motion get better at it.
Just pedaling form will make a big difference. If the couch-potatoe pedals in squares and pushes down when the pedal is at the very bottom, there's a lot of force that goes into rocking the bike laterally and bounces the rider up and down without creating any forward movement at all. So in the 5-mile example, it may be possible for the couch-potatoe to have to burn off 20-30% more energy than a smoother more efficient rider that pedals in circles.
The converse is also true in that if Lance rides that 5-miles at 35mph, he's gonna burn off more energy than someone who rode that same distance at 15mph.
Videre non videri
BUT, the "non-Lance" driver will use up more energy in the process of travelling the distance.
I doubt the difference is great, though. I think it would amount to 5-10% or so. That's just a guess, however...
