1982 Masi Gran Corsa-Need help to ID Campy Brakes & Pads Source
Greetings all,
I have recently purchased a 1982 Masi Gran Corsa that I plan to ride in Eroica events. Bike is in good condition with all Campagnolo components. First bike with Campy for me. I'm hoping some of the C&V forum members could identify the Campy brake model and a source for replacement pads. The brake pads are rock hard. Also any advice for brake adjustment, can't figure out the cable adjuster on the brake.
Thanks in advance
Thanks in advance
Señor Member
Quoted: 284 Post(s)
Liked 295 Times
With the white o-rings and the visible shape, I’d guess those are Chorus monoplaner brakes. Others more familiar with Campy can correct me.
Koolstop sells an excellent brake pad that works with those:
Kool Stop International - High Performance Bicycle Brake Pads Since 1977
HI
THANK YOU ! ! ! Just ordered a set of the pads and thanks for identifying the brakes. Next I'll post some pics of front and rear derailleurs for identification. Campy is a whole new world for me.
Likes For City Guy:
Quoted: 1607 Post(s)
Liked 2,216 Times
Looks like Chorus to me. The feature to look at is the transition from the arm to the mounting pad. They very from one model to the other. Only Chorus has such a pronounced curve in the transition.
P1010556 on Flickr
Brake pads will make a difference! They are really nice looking. Thy also need brake levers that provide the release to open for tire removal. Old Record or Super Record levers don't provide this feature. Ergos and Chorus brake levers do.
P1010556 on Flickr
Quoted: 4510 Post(s)
Liked 6,377 Times
You can't just casually say " I got this Masi " without showing us the full meal deal.
Ok one pic of the Masi on the workstand while doing some basic maintenance. Cleaned drive chain components, awaiting new KMC replacement chain, Deciding on what bar tape to install, Cinelli cork?, yellow? black? or Benotto plastic yellow?
Maybe a Brooks B17 saddle, and would appreciate advice on period correct saddle.
The current Michelin gum wall tires have plenty of tread, and the tubes hold air Ok, but the rubber seems hard, probably because of age.
Having difficulty finding 700 x 23 gum wall tires. Steel Vintage has Panaracer EVO4 C tires available, maybe Vittoria Corsa G 2.0, but I have not found any other options available. Any recommendations for a 700 x 23 gum wall?
Likes For City Guy:
