Garlatti completely original
resykler
Bikes: Bianchi Eros, Bianchi Reparto Corsa, Mongoose IBOC Campagnolo, Schwinn Super Sport, Mairag 4 Star, Canondale Criterium, Centurion Accordo RS, Specialized Hard Rock 1st Gen, Bianchi Special '81
Quoted: 101 Post(s)
Liked 59 Times
Can't post photo as I'm still a newbie but this bike is beautiful....what do you folks think. White with blue highlights all Campy
Quoted: 1607 Post(s)
Liked 2,213 Times
@brixxton - post pics in your gallery in your profile. Other can post here.
mycocyclist
Quoted: 909 Post(s)
Liked 811 Times
Here's a link to OP's Album, though I'm not able to find an example in it matching the description.
resykler
Quoted: 101 Post(s)
Liked 59 Times
This is what I am wondering about. It seems completely original and I'm not going to do anything but clean it
I love the chrome
And the old campagnolo set, is it a diamond in the rough ..oh and what's an OP?
The Garlatti is a cool looking bike, but it is at the lower end of quality spectrum (typical Garlatti). It may still be a really fun bike though, just not super valuable. $50 would not be a low ball offer. The white/blue color scheme reminds me of a Raleigh Grand Sports.
I.C.
I.C.
Quoted: 1372 Post(s)
Liked 1,747 Times
As I understand it, "OP" is the Bike Forums acronym for Original Post. I could be wrong.
As for your bike, it is entry level or close to it, however; it is the exact sort of bike that I like to restore these days. At the moment, I am completing the paint/art for this sixties something Torpado. My Torpado and your Garletti are very similar in vintage and quality level (the OP's Garletti is more desirable in my opinion and, were it my size, I would not hesitate to pay a couple of hundred dollars CND).
If it is any help, I recently got this old Torpado, a gift from a friend). My intention is to keep it as original as I can, group set wise, but made the decision to paint the bike and add correct art. Anyway, "as found" for free...
So far, without the cost of tires, the bike has set me back close to $150.00 CND, to get it looking like this (that includes the cost of the art)...
My best guess is that, with tires, new brake blocks and cables, the end cost will be around $250.00 CND for me. I should add that I do all of my own work, which keeps my build (and maintenance) cost down a lot. And, if the OP's bike is all polished chrome, under that paint, he or she just might decide to go all chrome like I did on my last Torpado...
Well, not quite all chrome. Some contrast adds to the visual quality, in my opinion...
Quoted: 3464 Post(s)
Liked 2,827 Times
Interesting the proclamation on "full Campy" the derailleurs and shift levers are... but at the neat bottom end.
Chain is probably too long. (I hope so anyway)
Has Campagnolo second tier rear dropouts, could be worse.
Should ride reasonably well.
I would transform it into a wider tire "all road" bike. move to 700c wheels. go to a compact double up front.
resykler
Quoted: 101 Post(s)
Liked 59 Times
Cheers much
I'd been looking at a lot of different blogs/forums and am very glad I decided to hook up with you folks . I value everybody's opinion
That said the Torpedo looks fantastic
My Garlatti obviously needs sorting mechanically and under the paint is chrome that revives with a tin foil rub
As has been said it's mine to do with as I want. Cost me $20 and it was a horrible mess. The charm of the old Campagnolo front derailleur got me.
The jury is out
The jury is out
Liked 2,827 Times
Do not attempt to “toe-in” the brakes by bending the caliper arms- they will fracture.
I think a decent project
evaporust the rusted bits like the shift lever clamp-
those may be Campagnolo shift cables- the tell is a C in a diamond on the lead end.
Quoted: 3802 Post(s)
Liked 3,324 Times
hello brixxton & congratulations on your find
this example hails from the 1972-73 time
we had a distributor in California who purchased one batch of these at this time and then the Garlatti marque disappeared from our shores yet once again
have never known who it was; may have been someone such as Merry Sales Co. of your town or Euro-Asia, then in Carpinteria
we had had a decade long drought on the marque prior to this; the previous batch, again a one-time thing, was ~1963; here is an example -
had two from this batch come through me workshop; one interesting feature of them is that they came through with the not often encountered Campag Sportman hubs
frame -
constructed with Agrati lug pattern "ROMA" nr. 000.8020/U
upper head lug is item nr. 000.8024
lower head lug is item nr. 000.8023
seat lug is item nr. 023.8059
bottom bracket shell is item nr. 005.8057
fork ends are item nr. 000.8010
back in post nr. 7 it was mentioned that dropouts are "Campagnolo second tier" - they are not. they are Agrati. the difference between the Campag Sport ends set and this model of Agrati is that the Campag is marked with the Campag name and the Agrati is unmarked.
fittings -
headset is Agrati item nr. 000.4001
bottom bracket set is Agrati item nr. 113.3021
chainset is Agrati
pedals are Sheffield (Noli-Cattaneo) model Corsa Nr. 655
brakeset is Universal model Sport (not model 61)
stem & bar set is 3TTT Tourist
hubs Gnutti large flange one-piece alloy 36 hole
rims Maccari steel 36 hole 27"
gear ensemble Campag Valentino
drive chain and gear block Regina
usage tip -
one feature of these frames is a quite low bottom bracket shell
this design gives the bicycle what is called a nice "roll" - nothing to do with friction
the downside is that one cannot pedal through hard cornering without risking a pedal strike
likewise the design is not the ideal for "gravel grinding" or "cow trailing"
accessory -
the cycle's REG (Rampinelli) water bottle holder nr. 164 is of value; even in this poor condition
hope that you enjoy lots of good fun with the machine!
frame -
fittings -
chainset is Agrati
usage tip -
accessory -
Likes For juvela:
Quoted: 107 Post(s)
Liked 151 Times
That's a nice bike that will clean up well and ride nicely. My first road bike was a similarly equipped Bianchi Rekord '72; the main differences include a Nervar cotter crankset and stamped steel rear drop outs that required a derailleur hanger. In 1979 I road it for 3 weeks throughout France and Switzerland, including over the cols du Telegraphe, Iseran, Galibier, Lauteret, etc.
resykler
Quoted: 101 Post(s)
Liked 59 Times
Time to stop and test the water
Think I have come to the end of the Garlatti
project for know. Well I'm getting blue bar tape tomorrow so after wrapping and a last touch up on the chrome. So now what to do. I am thinking of putting it up for sale. Where do you folks think would be a good outlet and I am pretty sure what I'm going to ask for it, but I want to know your thoughts
PM me your cotters
Quoted: 1137 Post(s)
Liked 588 Times
brixxton if you need replacement mechs that are in minty-fresh shape at a cheap price which you could possibly re-coup the cost of in your sale, I've had these hanging around a bit. https://www.bikeforums.net/classic-v...py-brooks.html -- Sales forum has been super active lately so they keep getting buried and I'm just not willing to bump constantly.
As for a fair price, as-is, while it's cool and all, there's a lot of work. I'd have a hard time paying more than $150 for it. But maybe the right buyer would be willing to go up to $250?
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Level the saddle and lower the quill stem. $200 for the right buyer.
Likes For Phil_gretz:
Zip tie Karen
Liked 1,542 Times
ALSO: swap the front brake pad cartridges. You have the opening facing forward. This forces the pad out from the cartridge when braking. The opening should face rearward.
Quoted: 5887 Post(s)
Liked 3,469 Times
I'd sell the water bottle cage separately from the bike. For the bike, I don't see this as a $200 bike. It has low end parts, a steel cottered crank, steel rims, etc. Yeah it's old and cool but quality low end bike boom bikes with steel wheels and a steel cottered crank are available for $50 plus with a bit of shopping. Those are usually French and this is Italian but the campy derailleurs on this bike are nothing special. I'd value this at $100.
If you collect old bikes, why would you pay real money for this bike as opposed to getting a quality bike? At $200, I've picked up vintage bikes with Reynolds 531 (or equivalent quality) frames.
If you're not a collector, why would you pay $200 for this bike when you can get a quality bike that actually works right for that price?
resykler
Quoted: 101 Post(s)
Liked 59 Times
Dollars and Sense
https://www.ebay.com/sch/i.html?_fro...&_sacat=177859
my head hurts. Think might just hold onto it
Liked 3,469 Times
I thank you all, but check this out!!!!
Second, ebay prices are just that; they're ebay prices. You need to find the prices at which items sold for.
Third, there is something odd about that eBay bike and it’s a really, really high price. That bike has a Reynolds frame, but the stickers don't look right and the seller says that he or she does not believe this is Reynolds. Your bike I believe is hi tensile steel. Nothing wrong with that but that lowers the value. The parts are lower end as well with steel rims, a steel cottered crank, and low end campy derailleurs.
At $200 plus (which is where the valuations came in), there are "better" bikes out there but maybe they lack the right coolness factor. Your bike is cool in an old fashioned way and that may well sustain a higher valuation that I gave to it.
resykler
Quoted: 101 Post(s)
Liked 59 Times
There not making any more!!
A couple of things to keep in mind. First, you just received a range of valuations. Throw out the low one (that's mine) and the high. Somewhere in the middle is probably a pretty decent valuation.
I can assure you both frames are identical, probably part of the same 1970' California import .
Of course mine is more than a frame and once truly finished will be a rare example of 1970"s Italian "bling". Who wants to spend $3K on a ((((***)) only to be lost in a crowd of them.
of course that guy must be dreaming, or he knows something...
Quoted: 1604 Post(s)
Liked 2,569 Times
Looks like the handlebar is bent. May explain the front wheel.
https://sfbay.craigslist.org/sfc/bik...292597698.html
Liked 3,469 Times
EBay is full of overpriced inventory
Likes For bikemig:
