Will Di2 EW-WU111 wireless unit work inside
Accidentally posted before finishing. (Is there a way to delete a post?)
Anyway question is will the unit work inside a Ti seat tube? Was planning to update firmware and configure data screens and shifter hood buttons prior to inserting into seat tube but will the metal prevent communication of gear and battery information? I'm thinking probably yes. In which case in order to hide the wireless unit best place would be inside handlebars.
Last edited by dstke; 02-10-21 at 11:08 AM. Reason: Accidentally posted before finished
Quoted: 6187 Post(s)
Liked 4,804 Times
So if it does interfere you wouldn't purchase it? I'd just try and see, regardless of others experience. Though I'd think metal of any sort will be a bigger issue than if this was a carbon bike.
I'm planning on getting one too and was just going to do my own experimentation with placement.
edit.... seems like there is or was a check box or function in the advanced edit to delete a post. It was very obscure and not very noticeable. Not sure if starter post for threads were/are different.
Clark W. Griswold
Quoted: 4346 Post(s)
Liked 3,981 Times
Mine has worked in the past a few times but really isn't reliable. I wouldn't do it honestly and I wish I hadn't spent that money. I may end up moving it to the rear derailleur or put it near the bars when I re-wrap and add the bar end Junction A unit. I do have an older phone so that could be it as well but I have tried it with other folks phones and it doesn't like to work as often.
Quoted: 942 Post(s)
Liked 526 Times
Just splice it in up front, that's what I did on my Ti bike. You may have to unwrap the bars to clean up the wiring after.
That's the plan.
Likes For TerryDi2C:
Quoted: 6952 Post(s)
Liked 10,958 Times
Mine is in the downtube of a steel frame and seems to work fine...Though I just moved it there and haven't actually ridden outdoors with it, because of the weather.
Bikes: yes, i have one
Quoted: 1136 Post(s)
Liked 1,181 Times
Likes For spelger:
