Google search says to change chain every 2-3 thousand miles
Of course google isn’t bikeforum. Is that true? I have a 16 yr old lemond roadie. I’m on 4k miles this year from commuting? Never been changed. Advice please?
Word.
Bikes: Surly Disc Trucker, Orbea Oiz XCountry Bike, Specialized Roubaix, Borealis Echo Fat Bike for Winter, many others out in the barn.
Quoted: 64 Post(s)
Liked 99 Times
I've always used 1,000 miles as a rule of thumb. What happens over time is the chain stretches and the pins get farther apart. The chain rings and cassette wear to accommodate that new spacing, and if they go too far, they will no longer accept a new chain.I've gone 2k on a chain, but I'd never go 3. Replacing cassettes and chain rings is too expensive to have to do every few years.
I've also learned from experience to avoid generic/cheap chains. I had one break on tour a couple years ago, the old guy at the bike shop assumed to had 10k miles on it. It had 700. The $40 Sram he sold me was quiet, smooth and buttery by comparison. It even shifted better.
I think you should keep riding what you got until it fails, then budget for a full replacement of chain rings, chain and cassette.
Quoted: 2604 Post(s)
Liked 1,931 Times
Just guessing, but if you've ridden ~60,000 miles on your bike, when the shifting becomes unacceptable you'll probably need new chainrings, cassette, and chain. My best guess is it'll cost you more than $120 -- exactly how much depends on what level of componentry it'll take to keep you happy. Just keep riding it if you can put up with the shifting.
I try to check my chains starting around 1,500 miles. Somewhere between 2,000 and 2,500 miles, 12 full links measure 12 1/16" on a metal tape measure, and it's time to replace a $20 chain. After 3,000 miles, my shifting becomes unacceptable and it takes a chain and a new cassette ($60 minimum total) to make me happy again.
Likes For pdlamb:
Quoted: 7348 Post(s)
Liked 2,465 Times
You should replace your chain when it is elongated. There is no way to know how many miles that takes because it depends heavily on riding conditions and the cleanliness of your chain. If you ride with a worn chain, you wear out your rear cogs. If you ride on an extremely worn chain, you wear out your chainrings. I replace my chain before it is very worn so it lasts me about three cassettes. I have never worn out a chainring.
Likes For noglider:
Quoted: 4806 Post(s)
Liked 3,928 Times
Best way to check the chain condition is with an ordinary steel ruler or tape measure. Each link is 1/2" long (pin to pin) when new. Each pair of links is 1". That distance goes up as the chain is ridden. Now one pair of links is pretty hard to measure accurately so many of us simply measure pin to pin over 12 pairs of links. (I measure front of pin to front of pin because the clean edges are easy to see.) On a new chain, that will be 12" exactly, When that increases to 12-1/16" I take it off and put on a new one. (I can usually do this several times before the cassette cogs are too worn to accept a new chain. First ride will make that plain.)
If I want to save money, I hang on to the old chains and when new chains no longer work, I rotate through the old ones, going to 12-3/32", even 12-1/8". This does kill the chainrings so there will be more to replace when the time comes.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Easy answer: yes change it
Medium answer: get a chain checker
Long answer: oh man are you even ready for how hard we can nerd out about this
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Liked 1,931 Times
Likes For pdlamb:
Disco Infiltrator
Liked 2,105 Times
How do you guys even keep track of how many miles you've ridden? My bike is 25 years-old and has been pedaled into the ground every one of those years; yet, I couldn't even BEGIN to estimate how many miles I have gone in all this time, or even how many miles I rode last week.
Is this something I should be keeping tabs on?.
Liked 1,931 Times
The flip side of this question is, "how are you dealing with chain wear now?" Do you take the time to measure each chain every week or every month? Or do you prefer just to ride it until you've got shifting problems? If the latter, you're willing to pay for a cassette AND a chain when the chain gets worn, as opposed to just changing a (not worn so badly) chain. It's your bike(s), your ride, your money, you get to choose how to deal with it.
....The flip side of this question is, "how are you dealing with chain wear now?" Do you take the time to measure each chain every week or every month? Or do you prefer just to ride it until you've got shifting problems? If the latter, you're willing to pay for a cassette AND a chain when the chain gets worn, as opposed to just changing a (not worn so badly) chain. It's your bike(s), your ride, your money, you get to choose how to deal with it.
Likewise, having ridden and serviced bicycles for most of my 58 years - and having ridden the SAME bicycle for twenty-five of those years - I know in an instant when something doesn't feel right. And in the case of the chain, I can confirm or disprove my suspicion with my Park Chain Checker.
To me, it seems that riding a chain for a thousand miles on boardwalks and bike paths is different than riding one for a thousand miles in the mountains or on hilly road routes where you're standing on the pedals and stressing the heck out of the chain a lot of the time. For this reason, I've always considered the manufacturers' recommendations as rough guidelines, to be modified according to the type of riding you've done during the life of the chain.
Just took it to the LBS. The owner said they'll try a new chain, but there's a good chance that it'll make it worse. He said it could require a new cassette and crankset but for the fact that the parts are on super back order. So, if it doesn't work, then he'll pretty up the existing chain and put it back on. Oh well, I didn't know. I don't recall if there was a maintenance brochure when I got the bike 14 years ago. I don't know any other cyclists to have been granted this advice. I suppose I should have intuited that the chain needed to be changed, but I'm not that smart. I just started pedaling and occasionally sprayed on blue lightening. Now I'm going to probably pay the price. Bummer. Oh well.
Likes For burritos:
Liked 3,928 Times
My question was sort of rhetorical, but I do have to admit that I envy people who can tell you how many miles they rode last week or last year. I barely keep up with that kind of info for my CAR. (The dashboard tells me all I need to know!)
So I have mileage calendars going back a dozen years with running totals of mileage for every bike. I can get mileage numbers for just about any weird whatever I want. (Last half decade I started tracking fix gear and geared mileages. Saw that if I did it right, I could arrange my riding to hit 100,000 miles of each on the same day! That was fun.
I make notes of bike maintenance on the calendar but rarely use it as maintenance schedule. I just try to stay in tune with each bike and do what it needs. Chains - never on mileage, always by the tape measure. (Not a saint. They grow long in the
Liked 3,928 Times
Quoted: 1074 Post(s)
Liked 295 Times
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
Chain checker. It's worth at least the couple of dollars in piece of mind. I've had chains in nasty gritty conditions be absolute completely worn out junk in 500 miles. I've had others last more than 3000 that only got changed because of upgraditis.
As noted, so much depends on how you ride, the conditions you ride in, & maintenance efforts that it's impossible to give a recommendation. Kudos for going to the bike shop to check & confirm. If you do need a cassette, chain, etc...You need not be confined to the ever-popular Sram-mano; There's lots of other manufacturers that make perfectly acceptable parts. Sunrace & KMC immediatley comes to mind.
--One good measurement is better than a thousand good guesses.-- So said some famous person.
Car dependency is a tax.
I guess that's the beauty of all cyclists being different. Although my bike is one of my most prized possessions, I rarely give a thought to lubricating the chain, checking air pressure, or re-greasing bearings unless I feel something "off." Then I get right on it. After 25 years of doing my own service, my 1996 GT Outpost rides like it's three weeks out of the bike shop -- in fact, BETTER than it did then! If you ask me how many miles it has on it or how many miles I got out of specific components, I would look at you completely dumbfounded.
As responders above have said:
1. Everyone rides differently.
2. Get a chain checker (Park Tool is +/- $11.50) and change the chain when needed.
Quoted: 1088 Post(s)
Liked 1,024 Times
If the bike has been a dust collector as you claim then the chainrings being worn after 4k miles is nonsense. Buy a chain checker, the park has two sides, one side is .5 stretch, the other is .75 stretch. If only the .5 fits then toss on a new chain and see what happens, unless you only pedaled in 1-2 gears it'll probably work fine across all of them and be fine until you have worn out the new chain. If it fits at .75 it isn't worth experimenting, just replace the cassette as well. A chain ring will outlast 4 or 5 chains unless you used them way past when they should have been replaced, and one chain at 4k miles isn't even close, usually a minimum of 10k miles and often more if chains are kept lubed, cleaned and replaced at reasonable intervals. Unless the rings are work to a sharp point, it isn't time. Rounded teeth are fine.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
As the old saying goes... Your mileage may vary.
I suppose I am just fortunate that I can still replace the bottom bracket AND chain on my bike for about thirty dollars. If this is common with the newer bikes out there, perhaps the OP should be aware that replacing a bicycle's drive train is NOT such a major expense.
Quoted: 1364 Post(s)
Liked 1,677 Times
I used to commute about 3200 miles a year. My long-time commuter and now winter bike has a triple up front that loves to munch chains. So I would usually end up changing the chain every year or two. Six years ago I bought a new bike and didn't think about changing the chain until the chain began skipping after 4 years. The new chain skipped on the rear gears which had to be replaced. I took advantage of that to get a wider spread of gears with a lower low gear to help my aging knees on hills. The gears were about 30 bucks and with the install about $20. That's only about a tank and a half of gas.
While I wasn't having chain issues on my old road bike I did change the rear gears a few years ago to get lower gearing for my knees. I had to replace the chain as it had stretched and didn't work with the new chain.
But right now, since I no longer have a daily commute I am more worried about my posterior expanding.
Quoted: 626 Post(s)
Liked 701 Times
The chain on my recumbent bike lasted me nearly 5 years, about 7k miles. I don't know if I'm easy on chains (I tend to spin high RPMs and not mash) or I should have checked it more frequently. I did have the rear cog replaced at the same time. Haven't put as many miles on it in the last few years between my many moves, and now splitting my ride time between the bike and the velo.
Back when I was a poor starving college student, my bike was my only transportation and I averaged just shy of 1k miles/month. I think I still rode with the same chain for 5-6 years (12 speed Fuji, early 90s model).
