How much Oil should be added to a 3 speed Hub?
Bike Junkie
Location: South of Raleigh, North of New Hill, East of Harris Lake, NC
Bikes: Specialized Tarmac, Specialized Roubaix, Giant OCR-C, Specialized Stumpjumper FSR, Stumpjumper Comp, 88 & 92Nishiki Ariel, 87 Centurion Ironman, 92 Paramount, 84 Nishiki Medalist
Quoted: 68 Post(s)
Liked 37 Times
I have a couple of 3 speed Raleigh bikes and I'd like to ride them. I noticed the oil hole in the Sturmey Archer rear hub. So I opened the cap on one of them and added some oil when it suddenly dawned on me, I don't know how much to add! Should it be full, is there a way to measure this? So what is the correct amount of oil to put in these hubs and how is it measured?
Also, I'm using non-detergent 3 in 1 brand, mostly because the spout fits right into the oil hole, is this a satisfactory brand of oil?
This is my first venture into the world of 3 speeds, so thanks for understanding my ignorance.
Roccobike BF Official Thread Terminator
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times
Are the hubs greased? I noticed that my bike which had the oil ports had no grease since one owner probably just put in oil and the next owner put nothing.
I knew there was a reason why it felt so slow haha.
Short answer is: enough
I go by sound, I can hear when they're too dry and add light oil until they make a satisfactorily smooth sound
Decrepit Member
From the 1956 Sturmey-Archer Master Catalog:
LUBRICATION
Only a thin good quality oil should be used for the lubrication of Sturmey-Archer hubs. Thick oils or grease must not be used, but when a hub is dismantled a small amount of grease or vaseline may be put on the ball races only.
The ideal rule for lubrication should be 'a little but often'. Two or three drops of oil every week will maintain the hub in first class running order.
I have heard that 3-in-one oil is "vegetable-based" and turns gummy over time, and should therefore not be used for lubricating S-A hubs. I called the 3-in-one customer service number (3-in-one is now owned by WD-40) and asked about this. I was told that 3-in-one is not vegetable-based and isn't any more likely to dry out or turn gummy than any other petroleum based oil. I don't know what to believe, but if I ran S-A 3-speed hubs I would probably just buy SAE 20 motor oil for lubrication.
EDIT - I notice the Wikipedia entry for 3-in-one oil says it contains citronella oil, which is derived from the leaves and stems of different species of Cymbopogon. I just dunno. I think it would probably be smart to use motor oil and avoid any potential problems with 3-in-one.
LUBRICATION
Quoted: 3810 Post(s)
Liked 6,690 Times
I have a Raleigh/Sturmey Archer SA service brochure from the 70s, and it recommends SAE 20 oil for hub lubrication.
Neal
Neal
crotchety young dude
Bikes: IRO Angus; Casati Gold Line; Redline 925; '72 Schwinn Olympic Paramount
I've used Phil Tenacious Oil and it seemed to work fine. But, the bike was a gift for someone else and I only rode it a few times before giving it away.
Disraeli Gears
If you overload the hub with oil, it will just leak out; no real harm except to braking surfaces and tires. You could load it up the first time, put the wheel on its side for awhile to let it drain, and clean it. From that point onward, a squirt or two a week should be fine.
I use a syringe that we get from the pharmacy at our local grocery store. it's meant for kids cough syrup and stuff and works perfectly. it fits in the hole and I can deliver a measured amount of oil without any mess. I put in 5ml of german blend castrol synthetic (any motor oil will work i just have this leftover from my VW) and replace when I hear the pawls make an especially dry ticking sound. prior to this I'd recommend giving that hub a brake cleaner flush and wait a few days for it to dry out before oiling. that will clean out any crap the previous owner put in there. In my experience that's all the work these hubs usually need.
surly old man
Bikes: IRO Mark V, Karate Monkey half fat, Trek 620 IGH, Cannondale 26/24 MTB, Amp Research B3, and more.
Quoted: 46 Post(s)
Liked 42 Times
Seems like old 3spd hubs are the most bomb-proof bike part ever. Not sure what happens in there, but it seems blessed. They are like mules; none has ever died a natural death. Most of the ones I have seen seemed never to have been maintained at all, and they magically work just fine. I have pulled a couple of 3spds out of junkheaps where they have sat for years or decades, and the hubs leap to life on the first revolution.
jim
jim
Cross Check Nexus7, IRO Mark V, Trek 620 Nexus7, Karate Monkey half fat, IRO Model 19 fixed, Amp Research B3, Surly 1x1 half fat fixed, and more...
SB forever
SB forever
SNARKY MEMBER
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 531 Post(s)
Liked 1,004 Times
3 speed hubs aren't very picky about what oil is used, as long as they get some. If the viscocity is too high, the shifting will be stiff in cold weather. 3 in 1 oil is kind of thin, about equal to 10 weight, so motor oil is a better choice. As was said before, if you get too much, it just leaks out.
My bikes became Vintage
To know how much oil to put in, you would need to overhaul it and start from scratch. Sutherland's says to lube the pawls and ball bearings with grease, lightly oil other internal parts and add about 2 teaspoons (8 ml) of cycle oil when assembled.
Bikes: Still have a few left!
Quoted: 467 Post(s)
Liked 532 Times
Back in the 80s, in the Portland, OR area, my daily commuter was a Raleigh Sports. My routine was to pump the tires and add a few drops of 30wt oil before heading out on Monday morning plus I cleaned the chain & cogs every few months and the whole bike in the Spring. For five years or so, repairs consisted of replacing worn out tires and lubricating the cables when I replaced brakepads. I May also have replaced a broken brake cable. In a colder climate, I would have used 20 wt oil for the hub. Don
oil
We use pedros syn lube. 3 drops. the bottle has a point applicator top which makes it easy to use also. I have felt this seems to have a fine enough viscosity for 3spd hubs. A sister shop of ours has some of there 10 yr mechanics also using da pedros.
2 tsp's is actually 10ml and way too much. I know this from experience. Once you know how much oil you have put into your hub a weekly top off of a few drops of pedro's would be OK. Personally I like 3-speeds because they don't require the maintenance that my other bikes do. I go for the larger doses of thicker oil at a longer interval. This is a funny topic and it's all about personal preference, I guess, some people prefer oil to leak all over their stuff and some prefer to have a very light tinny sound to there 3-speed hubs (a wonderful sound in my book). you will have to experiment a bit to find out what works for you. However a good flush is the first step no matter what.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
I have had a fair sized spot under the wheel on occasion when I was a little over enthusiastic with the oil can and then didn't ride very far. FWIW I only add oil PRIOR to riding...
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Bike Junkie
Quoted: 68 Post(s)
Liked 37 Times
Thanks for all the feedback. Great information. I won't say how much oil I put in the one hub I worked on, but suffice it to say, I'll be draining some of it out.
Thanks again for the support.
Bikes: Fred cycles
Quoted: 34 Post(s)
Liked 18 Times
Don't need to drain it out. It's all over the floor at this very moment. How do i know this? For the past year, my daily driver has been a 30 year old Schwinn with an SA & I didn't know what to do at first either, learned by doing
Wahoonc is right. I use a product called "Formula 88" in a black spray bottle. It's a degreaser. Spray that on the gunkiest hub. let soak in, garden hose it off and follow up with high pressure (compressed) air especially around the spoke holes, take it for a ride and wala, clean as a whistle.
The quality of the chrome plating can't be beat. Even after 40 years, like new. As with most SA hubs, oil in, oil out unless you are careful and measure. It's a tough hub to kill. Just keep it oiled. Easy enough to keep clean if that is a real issue.
One more note on SA hub oil. It is important to make sure that the oil is not too heavy or tacky. I always used Phil Woods oil and it works well. However, I have worked on SA hubs that have had heavy motor oil (or some other heavy oil) added. The tackiness of the heavy oil provided too much resistance for the springs in the hub to overcome and the hub performed poorly when shifting. After I gave it a good cleaning and added lighter oil (Phil Woods), then the hub performed well.
Bikes: Fuji S-12s, Trek Navigator 200, Dahon Vitesse D7, Raleigh Sprite Touring ('70's)
Just curious how a little 5w-20 Mobil 1 would work.
Quoted: 16 Post(s)
Liked 24 Times
I tried it once, back when I was just getting into the Sturmey hubs. I also used Phil grease in the channels at the cones. Being new to SA lore I made the mistake of putting in the recommended 2 tablespoons. Unlike brown automotive wheelbearing grease, Phil grease can be dissolved by oil and there was too much oil.
The whole rim and tire got coated. Then it rained and I got a flat, 1/2 way around Lake Pepin. Amazingly the KoolStop Salmon brake pads still worked. I assume only because I was using alloy rims. Mobil 1 on wet chrome would probably have a negative coefficient of friction.
Since that experience, I haven't tried it again, but I suspect it might be the best choice. Especially on the bikes I ride in winter. At -9F, with 10w-30 in an S5, things get pretty sluggish unless you are in Direct. Next overhaul I'll try it again. But the durn SA hubs are so maintenance free that could be years off.
BTW I use it for chain lube in the winter. It really makes a significant difference in drivetrain efficiency on my 2WD winter trike with, it's 3 chains.
BTW I try to remember to add 6-8 drops to all my hubs every 3-4 months. For someone who uses more lube, it might not be a good choice.
Good tip: When building wheels with SA hubs, line up the tire valve hole with the oil port. Then it's easy to see if you've parked or hung the bike with the port facing downward.
stringbreaker
Bikes: specialized crossroads hybrid 2006 Raleigh Cadent 2 1971 Schwinn Varsity, 1972 Schwinn Continental, 1977 Schwinn Volare (frame)
Quoted: 9 Post(s)
I used Boelube in my daughters Raleigh Sports and it makes that nice well lubed tick. I had filled it up with some degreaser I got from the LBS and let it work for a few days and then let it drain on an old towel the a few drops I don't remember how many and then when they start sounding dry a few drop does the trick. Shifts like a dream and its a 1968
(Life is too short to play crappy guitars) 2006 Raleigh Cadent 3.0, 1977 Schwinn Volare, 2010 Windsor tourist. ( I didn't fall , I attacked the floor)
