What is my sealed bottom bracket? NOT shimano
Bikes: Miyata six-ten, Miyata Grand Touring, Univega Sport Tour, Univega Gran Turismo, 80's Trek MTB, 2008 Dahon Mariner
Quoted: 85 Post(s)
Liked 83 Times
This is a "sentimental" bike restoration of a bike that was custom built for my good friend, Doug's, father. This bike was custom built in the late 70's. It has all the state of the art components of the time. I finally got the cranks off with a TA puller I ordered.
Lots of Campy components
TA Cranks
It does have a sealed bottom bracket, and it probably not original. When I tried the Shimano BB tool, it doesn't line up, though it looks very much like it would. I checked carefully.
It is not Campy.
What other style of sealed bottom bracket could it be? And yes,this bike is beat up, it is a labor of love for a very dear friend.
Photo is of drive side, same on other side.
Sealed bottom braket. ISO square taper for TA crank
TA Cranks
It is not Campy.
Give thanks, for unknown blessings are already on their way.
~Native American Prayer
Quoted: 823 Post(s)
Liked 1,396 Times
Looks like a Phil Wood unit to me!
Likes For rustystrings61:
Likes For Murray Missile:
Circa the late 70s, a TA crank and Phil Wood BB was the hot setup for touring, or for someone who wanted a triple or other non race gearing. Older bike shops will still have the remover for those if you don't want to buy one. Phil will rebuild them for a modest fee if it has gotten crunchy in the last 40+ years.
Shimano copied Phil, not the other way around. Just to make that clear...
Likes For Salamandrine:
Old fart
Quoted: 3594 Post(s)
Liked 3,407 Times
I concur; looks like a Phil mounting ring (N.B. Phil rings do fit other cartridges, so there's a small, but non-zero chance that the cartridge itself might not be Phil).
But not closely enough to use the same tool as Phil
Likes For JohnDThompson:
Quoted: 1088 Post(s)
Liked 1,206 Times
Yep, Phil Wood. I had a pleasant surprise like that on one of my bikes, too!
Quoted: 3464 Post(s)
Liked 2,831 Times
Quoted: 638 Post(s)
Liked 1,302 Times
Likewise. Took an '88 GT Karakoram in trade that had a TA triple. Pulled the crank and it was, "Hello. 🤔 What have we here?". Then.... 😲😎😎😎😎😎 It's safely stashed away for the right bike.
Quoted: 823 Post(s)
Liked 1,396 Times
One of the tricks bandied about 15 years ago or so was to run a Shimano UN-72 BB with French or Swiss mounting rings to get a relatively affordable BB setup. Then Shimano went to permanently affixed mounting rings on their BBs and spiked that move. I remember a friends's Mondia being set up that way.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,056 Times
Likes For clubman:
Quoted: 85 Post(s)
Liked 83 Times
While this is a "sentimental" restoration, it is being done on a budget. My friend Doug really doesn't want a "restoration" per se, he wants it to be functional so that his grown son can take it on an occasional ride. Doug has a shortened lease on life, and is clearing things out of his life. His son worked with Ibis and did about 15K miles on his aborted solo around the world trip.( Siberian roads and massive trucks made him value his life more than the ride.) Son will only ride occasionally and the bike will probably live in garage, a momento, not a daily (sigh). So I am doing what I can to make it ride-able.
The BB bearings are a tiny bit crunchy, but rotate without binding at all. I am afraid that removing it may be really difficult, as the rings look like they are rusted solid to the shell.
But thanks so much.
The wheel hubs look like PW also, stainless steel, with signature press in bearing, high flange, BUT there is no red "phil Wood" lettering on them. Did they make them without the signature?
Thanks again. I am lucky to be a member of this community.
Nubra
Quoted: 823 Post(s)
Liked 1,396 Times
Don't give up on the Phil mounting rings; PowerBlaster is your friend. See if you can carefully start infiltrating the stuff right where the rings join the BB shell, without getting too much into the bearings themselves. If it freed up the bolts holding the bed of my '97 Ford Ranger in place, it'll probably work for this, too!
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,704 Times
The older ones have the logo just either painted or screened on, and it does come off.
Commence to jigglin’ huh?!?!
Likes For The Golden Boy:
Quoted: 85 Post(s)
Liked 83 Times
THANKS
Likes For Nubra:
Quoted: 85 Post(s)
Liked 83 Times
I found a LBS mechanic, in his 60's, who has a PW BB removal tool. He works one day a weeks for fun. He will lend it to me. Also, really nice community here in Santa Cruz.
Cheers!
Nubra
Likes For Nubra:
Quoted: 85 Post(s)
Liked 83 Times
The bike is in pieces, and I didn't take a pre-photo. Apparently, the bike builder is Albert Isentort, a legend in the Bay Area ( I am just learning this) He is still building bike frames in his 80's. If you want a photo of just the frame, I can offer that if you like?
Liked 1,206 Times
Albert Eisentraut. Frame pic, yes please! We love Eisentrauts here.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4687 Post(s)
Liked 5,827 Times
Naw, OP sez Isentort, famous Bay Area lawyer at that time.
Quoted: 85 Post(s)
Liked 83 Times
I did some research on what Doug thought was an Eisentraut: it probably is NOT! Sigh, still a very nice bike, and custom made, but after comparing with Eisentraut's signature lugs on his website, this is not one of his.
Cheers!
Nubra
Cheers!
Nubra
Quoted: 4520 Post(s)
Liked 6,406 Times
I wouldn't rule him or one of his tribe out, he cast a very wide net, many variations over a very long timeline.
Bikes: Indeed!
Quoted: 1508 Post(s)
Liked 3,483 Times
The one photo you have posted looks like the bottom bracket shell used in the Eisentraut "Limited," a less expensive frame than the signature but still a very nice frameset. Please post more photos.
There is a small chance that I sold that frame to your friend's father. In the late seventies I worked in a Santa Cruz shop that sold Eisentraut frames.
Brent
Brent
Likes For obrentharris:
Phil made two tools, I never got the one with lever arm attached. Great bottom bracket, I think they use the same tool since 1971.
Likes For klasse:
Quoted: 85 Post(s)
Liked 83 Times
He went through many transitions, had many students, apprentices, disciples, etc. including Bruce Gordon and others, he did production and spec frames as well.
Brent
Brent
