I bought an 1 1/8" Crust Clydesdale fork, but don't have a frame
I got a good deal on it, and have always wanted a little lite truck style cargo bike. However, I didn't expect the easter egg hunt that would accompany the purchase in trying to find a compatible frame.
It seems like the broad swath of vintage hardtail mountain bike frames came with 1" steerers. In my amateur research digging up old catalogs, it appears that by the time -- say, Specialized -- started using 1 1/8" steerers they were also using suspension forks. Regarding that, I have a hard time parsing this part of the Crust product page:
Can anyone help me wrap my head around what I should be looking for? It feels as though buying the 1 1/8" size fork severely limited my options for hardtail MTB conversion candidates. Should I be avoiding vintage suspension MTBs in the first place, or is not that big of a deal? I find bike geometry difficult to understand, haha.
For those of you looking to throw one on your early 2000's Big Hit:
Ok, so what if your axle-crown measurement is far off from 400mm? Then your head tube angle, seat tube angle, and bottom bracket height are going to change. Generally, frame angles will all change by about 1 degree per 10mm of axle-crown length difference, and your bottom bracket height will change by about 5mm per 10mm axle to crown. If your original fork is longer than 400mm, then the resulting angles with The Cargo Fork installed will be steeper and the bottom bracket will be lower. If your original fork is shorter than 400mm, then the resultant angles with The Cargo Fork installed will be slacker and the bottom bracket will be higher.
Quoted: 4547 Post(s)
Liked 1,693 Times
I bought a high end mountain bike in 1995 and put a rigid fork on it (1 1/8"). It is a little quick handling, but not in a bad way because my fork is probably shorter than the suspension fork it was designed to accept.
Trek, Giant, Diamond Back and many, many others made mid-to-high end rigid fork MTBs with 1 1/8" steerers from at least 1992 on. Boulder, ATX 770, Trek 930, DB Ascent, etc. They are out there. 1" kept going for a big with lower models for longer - Trek 830, Giant Iguana, etc.
Quoted: 581 Post(s)
Liked 921 Times
The 1-1/8 age started in the early 90s. Far more bikes from then and forward came with 1-1/8 than 1". There was a span of time (c. 1991 - 1995) where 1-1/8" threaded steerers were the norm. Up until the late 90s, many bikes were available with either suspension or rigid fork, and the suspension forks were all short travel so generally speaking, a rigid fork wouldn't be a terrible fit.
Note the comment from the vendor you posted specifically referenced a long-travel freeride or DH bike (a 'Big Hit') not a run-of-the-mill hardtail with a 50 or 75mm travel fork.
Quoted: 2026 Post(s)
Liked 1,096 Times
I had a 1992 Trek 7000, a bonded aluminum frame hardtail with a 1-1/8" threaded fork. A similar frame with a change of headset should be compatible with your fork. I hope the original owner didn't cut the steerer too short for you.
BTW, what you did seems similar to renting a Tuxedo and then looking for a woman to marry.
Likes For HillRider:
Likes For alcjphil:
Quoted: 454 Post(s)
Liked 104 Times
1 1/8" MTB frames should be super easy to find, it doesn't matter if they were threaded or threadless when new if replacing the fork.
1" had a short life time for MTB frames (as long as you not looking at BSO or entry level bikes), although far longer than 1 1/8" threaded, which was last seen in 1995, 1994 was the last year for all but a few holdouts, look at you Marin, almost anything older than 1993 should be 1 1/8", a few exceptions from experience are Bontrager and Univega (Steel, not Alu), sure there will be a few more, but these are not the norm.
Quoted: 445 Post(s)
Liked 478 Times
400mm axle-crown seems pretty typical of a suspension-corrected rigid fork, no? You might be off by a few mm but that won't affect the head angle too much. Plenty of 1 1/8" frames around on the used market - I would say the majority.
https://www.modernbike.com/soma-curv...-1-1-8---black
Liked 1,096 Times
The axle-crown measurement on the Soma suspension corrected fork for 26 inch MTB's with 80 mm suspension fork travel is 440 mm. If I understand correctly, the 40 mm difference in axle-crown distance will steepen headtube angle by 4 degrees according to Crust. That's significant. Steepening the head tube angle will quicken the steering. I'm not sure you'd want that when you plan to carry significant weight on the fork mounted rack.
The Soma fork I referenced is rigid. It does not collapse to 400mm. It is designed to replace a suspension fork with 80 mm of travel and not alter the bike's front end geometry. Are you saying Soma is wrong? Help me to understand.
(Side gripe: What is *with* bike sellers on CL/Facebook and not noting *any* kind of size info? It's absurd to me how often I'll have to ask for a seat tube measurement.)
Liked 1,693 Times
Okay, this broadly confirms what I had suspected. Now, here's the question: As I search for a project bike (or just a frame), is there an easy way to tell at-a-glance if the bike has that 1 1/8" headtube compatibility? Current, I'll check the pic and see if it has a quill stem or not. If not, move on. Is that ill-advised? Am I missing something?
So youve been missing a bunch of candidates.
Is there a go-to way to determine the difference in headtubes? Asking sellers to "let me know the steerer size" just causes confusion. Should I just be meeting and measuring myself?
Better question: What's the OD of quill stems that went in these 90s 1 1/8" quills?
Thanks for your help on this, sincerely.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12888 Post(s)
Liked 7,804 Times
Liked 1,693 Times
Bummer! But this new knowledge just means I'll have an easier time finding a nice base bike for my project.
Look at pictures of both kinds and get a feel for the fatness of the quill and the headset.
AFAIK, all of the suspension fork models are 1 1/8" without fail. Safe to say the same goes for the rigid fork M2? I'd post the link but I can't yet due to my forum post count. It's on page 4 of the 1991 Specialized catalogue on Retrobike. Looks just like it, too, like it hung in a storage unit for 30 years.
Likes For johnexcept:
Liked 1,693 Times
So I found a 1991 (maybe 92) M2 Stumpy in museum piece quality -- purple! -- and I'm stoked to grab it, but it's a bit of a schlep to travel for it.
Got it in one -- unfortunately. The seller measured for me and the stem is 22.2. Hard to let this one go, but I can only handle one bike project at a time.
Old bikes, Older guy
Location: Fiscal Conservative on the Lefty Coast - Oregon
Bikes: A few modern, Several vintage, All ridden when weather allows.
Quoted: 254 Post(s)
Liked 171 Times
Hi,
Do you have a bike co-op or similar near you? These folks can be very helpful in suggesting a frame for you at a reasonable price. Personally, I’d go with a mid level frame from a reputable company. Just make sure it fits you before the modification. If they will answer your questions, Craig’s List sellers are OK, but I’d stay away from ebay or Facebook.
Cheers & good luck,
Van
Cheers & good luck,
Van
Remember: Real bikes have pedals.
...and never put a yellow tail on a Red, White and Blue kite!
Quoted: 395 Post(s)
Liked 896 Times
johnexcept - where are you located and what size frame are you looking for? I have a couple 90s mtb frames that may fit the bill, located in New England. Others may also be able to help source something with this info.
Okay, here's a fun twist to the story. The seller hit the stem with calipers, measures 7/8". Bummer, right? Well, on a lark I ask him to measure the headtube OD and it's 1 1/2". What do you reckon the odds are that the bike has a 38mm headtube OD, 34mm ID, but a 1" headset (somehow)?
Quoted: 254 Post(s)
Liked 171 Times
How about a little more info on your location? There are co-ops, bike kitchens or coalitions all over the west even in some small towns. Portland, OR has 1/2 dozen.
Cheers,
Van
Liked 1,693 Times
