Campagnolo 10 sp cassette on 11 sp hub?
Hello everyone,
I just bought a brand new wheel set with dt swiss 350 hubs and campag 11 sp freehub body. I also bought a 10 speed veloce casette for the new wheels as it should be compatible with the 11 sp hub.
When I tried to slide the cogs on the first 3 was so extremely tight the sprocket actually carved the freehub body and removed quite a bit of aluminium (like 0.3-5 mm).
At the end I managed to fit the casette but the whole process dis not feel right.
Any advice on this? I have been googling all day but I didn’t come across anything.
Thanks in advance if anyone has got some advice on this.
Quoted: 6193 Post(s)
Liked 4,809 Times
Did you check Campy's spec on that. I didn't think their 10 spd hubs would work with 11 spd campy cassettes. But I don't use campy, so you'll have to do the footwork and go to their support site and read their doc's.
Or wait for someone that know's for certain <grin>
Quoted: 101 Post(s)
Liked 49 Times
Campy freehub from 9 through 12 speed are compatible with all cassettes in that range. May need to watch out for lock ring compatibility with both the freehub and the smallest cog.
Thanks, that’s right. My issue is everything was brand new and when I lined up the first cog it simply stucked right at the start. I had to use considerable force to push it on ( took me half an hour). As I forced it along the way the cog was carving off some of the aluminium off from the freehub body. (4 lines along the splines)
Is it possibly that tight?
The lockring came with the new casette and fit just fine.
Jedi Master
Something is wrong. All the campy freehubs and cassettes are interchangeable, and the cassettes should slide on and off with almost no force at all.
Likes For kingston:
Liked 4,809 Times
Being bored, stuck at the house, and curious, I went to Campy's website and Ronsonic appears to be correct. Also I totally agree with kingston The correct parts shouldn't be doing what you describe. However if they were put on cockeyed and you didn't correct that before going any further, then possibly the correct parts might have done that.
Didn't drop your freehub on the floor and step on it when trying to retrieve it did you? Might be out of round. <grin>
Thanks,
I tried to post photos but I’m not allowed yet. Newbee🤪!
Could it be the number of arms on the sprockets?
I was googling around and come across 4 arm and 8 arm sprockets for campag freehubs, but couldn’t find anything reassuring.
The larger sprockets in my veloce 10 sp casette have 8 arms (tight ones) and the smaller sprockets have 4 arms and fit perfectly.
The 8 arm sprockets are causing the problem but I could not find anything about this on the internet.
Anyone could advise on that?
Thanks a lot
Thanks a lot
Liked 4,809 Times
Jedi Master
From that picture everything looks fine. To offer any suggestions we would need to see the freehub and the back of the cassette.
Photos
Ok. Now I can upload the photos.
The lockring and the first cog removed. Showing the smaller cogs with 4 arms. They fit perfectly.
The larger cogs have 8 arms and they are the ones really tight. I could not found anything specific about sprocket arms.
The brand new freehub body after a forced the cassette on.
Am I missing a point here? Or I am just plain st¥pid..
Liked 4,809 Times
No, not if you stopped at the first sign of resistance and double checked what you were doing. Then checked again.
I can't say I've never forced something. However sometimes I have found that it was because I was in a moment of temporal stupidity. Hopefully it was only temporary. <grin>
On the serious side though, is that a Campagnolo made free hub or just a compatible made by another mfr?
But I'm still out of my element. I've never used or worked on Campy hubs or cassettes.
thanks for the replies
https://www.stradawheels.co.uk/produ...-fella-deluxe/
I just bought this wheel set above.
They are built on dt swiss 350 hubs.
Now I have taken the photos I will email it to the guys at the work shop.
Honestly I am still expecting someone to come along and call me an idiot because I did something silly.
It's a DT freehub body that is Campy compatible, correct? Maybe the DT isn't machined to the greatest tolerance.
Also. it appears that the gouges are in spots that don't contribute to driving the wheel.
Jedi Master
It doesn't look like you did any real damage, but the cogs should just slide on easily. A good rule of thumb is to never force anything unless you really know what you're doing and/or don't care if you break something.
You put them on one at a time like you have in the picture and they bind like that? You weren't trying to jam the whole cassette on in one go? I had a problem once trying to put a Miche campy cassette on a velocity campy freehub, but it was loose and sloppy not too tight. The velocity freehub works with campy cassettes and the miche cassette woks with campy freehubs, but they don't work with each other. Don't suppose you have another campy cassette you could try to see if the problem is with the freehub or the cassette? It seems more likely to me that a veloce cassette would be slightly out of spec than a DT freehub.
You put the largest sprockets on incorrectly. Use the very small protrusion of the spline pattern as your guide.
Those large sprocket teeth should make the same spiral pattern as the others.
It is not possible to install the large sprockets onto the freebody that far if the splines are not correctly aligned. It looks like the sprockets may be a little off tolerance. Take a file to them if desired, but overall that tight fit won't harm anything.
Thank you everyone
Thanks for all the replies.
I contacted the work shop and they said it is a case of very tight fitting cassette on this particular freehub body as the freehub body is campagnolo compatible but not made by campagnolo.
As long as I have the whole cassette on with a tight lock ring it should be ok.
Thanks a lot again👍
Thanks a lot again👍
